How the voltage of very high magnitude is obtained in a tubelight?
In summary, a fluorescent light does not need extremely high voltage to start the discharge. You need a starter circuit and a high voltage to start the discharge.
Faraz Murtaza
32
i have a doubt regarding the starting of a tubelight that whenever we switch on the light then we require a very high voltage to create the arc for the continuous flow of current, then how do we get such a large amount of voltage to produce this arc
I assume you are referring to a fluorescent tube light ?
if so, there is no need for extremely high voltage, there is no discgharge arc formed as in a long spark
very basically...
when, for example, mains voltage (120V/240VAC) is applied to the 2 filaments one at each end of the tube the filaments heat up and an electron cloud is formed. Since mercury vapor is a good conductor, these electrons make their way along the tube between the two filaments.
The electrons "colliding" with the mercury vapor atoms cause ultra violet light to be emitted. This UV light is absorbed by the phosphor coating on the inside of the tube and visible white light is emitted.
The Ballast in the circuit is used as a current limiter.
regards
Dave
Likes 1 person
thank you so much
Without some help from the 'starter circuit' you would need a high voltage for a metre of low pressure gas to 'strike'. It is virtually, an open circuit. Once the mercury has become ionised, that same column becomes a very low resistance path. As Davenn says, you need a way of limiting the current or a fuse will blow. An inductive choke is mostly used these days but, in the past, it was not uncommon to use a filament lamp in series, to limit the current.
as you are saying that without the need of starter we will require a high voltage, so my question is how do we get this high voltage? as the supply is of 240V and as i found to create an arc for current flow we require about thousands of volt. So, how do we get such a large amount of voltage?
Those big fluorescent bulbs we use for overhead lighting use thermionic emission from filament to get electrons going (hot cathode), so no need for really high V.
Back in the day, we used cold cathode tubes (CCFL) to backlight our LCD panels. More efficient since we are not heating a filament, but required high voltages.
Even though the bulbs were only couple inches long they required 1500V of strike voltage and then 400Vrms of sustaining voltage at 30KHz (we used Royer inverter). Got a nasty jolt more than once working in the vicinity of that. Don't miss them.
You do need a starter and no one uses a high voltage to start the discharge these days.
If you want a design for a high voltage supply for another purpose then that is a different issue. You won't get one from a fluo tube supply.
Look up 'fluorescent tube starter circuit'.
Likes 1 person
1. How does a tubelight generate such high voltage?
The voltage in a tubelight is generated through a process called fluorescent lighting. Inside the tube, there is a mixture of gases, including mercury vapor. When electricity passes through the tube, it excites the gas molecules, causing them to release ultraviolet light. This light then reacts with the phosphor coating on the inside of the tube, producing visible light. This process requires a high voltage to generate the necessary energy.
2. What is the typical voltage of a tubelight?
The voltage of a tubelight can vary depending on the size and type of tube, but it is usually between 600-800 volts. This high voltage is necessary to ionize the gas molecules and create the necessary energy for the fluorescent lighting process.
3. How is the high voltage maintained in a tubelight?
A tubelight has a built-in device called a ballast, which helps to regulate and maintain the high voltage needed for the fluorescent lighting process. The ballast is responsible for controlling the flow of electricity and preventing the tube from overheating or burning out.
4. Can the high voltage in a tubelight be dangerous?
Yes, the high voltage in a tubelight can be dangerous if proper precautions are not taken. It is important to always handle and install tubelights with caution and ensure that the electricity supply is turned off before making any changes. Additionally, it is not recommended to touch the tube while it is on, as the high voltage can cause electric shocks.
5. What happens if the voltage in a tubelight is too low?
If the voltage in a tubelight is too low, the gas molecules will not be ionized enough to produce the desired amount of ultraviolet light for the fluorescent lighting process. This can result in dim or flickering lights, and the tube may eventually burn out. It is important to ensure that the voltage is properly regulated to maintain the longevity and efficiency of the tubelight.
  • Electrical Engineering
  • Classical Physics
