Need help being assessed on basic programming questions
  • Thread starter Jamin2112
  • Tags
    Programming
In summary: Reverse a string: char* revString(string str) { unsigned int len = str.length(); char* newStr = new char[len+1]; for (unsigned int i = 0; i < len; i++) { newStr[i] = str[len - i - 1]; } newStr[len] = '\0'; return newStr;} The first function calculates the length of the string and creates a new character array of the same size, then uses a for loop to reverse the characters and add them to the new array. Finally, a null character is added to the end and the new array is returned.4. Write a function to
  • #36
jbunniii said:
6. (C++, easier) Let's write a simple complex number class, with various useful operators.
Ok. This is me going through it very fast. We'll see which simple mistakes I make.
Code:
#include <iostream>
#include <math.h>
class Imaginary {
     public:
     Imaginary(double, double);
     ~Imaginary();
     Imaginary operator + (Imaginary);
     Imaginary operator * (Imaginary);
     Imaginary operator ' (); // complex conjugate
     void print();
     double a, b;
     double abs();
Imaginary::Imaginary(double newa, double newb) {
    a = newb;
    b = newb;
Imaginary::~Imaginary() {
    delete *a, *b;
Imaginary Imaginary::operator + (Imaginary nextguy) {
     Imaginary sumguy(a + nextguy.a, b + nextguy.b);
     return sumguy;
     Imaginary productguy(a * nextguy.a - b * nextguy.b , a * nextguy.b + b * nextguy.a);
     return productguy;
Imaginary::operator ' () {
    b = -b;
double abs() {
    return sqrt(a*a + b*b);
void print() {
    cout << a << " + " << b << " * i" << endl;
Technology news on Phys.org
  • #37
Code:
#include <iostream>
#include <math.h>
class Imaginary {
     public:
     ~Imaginary();
     void print();
     double a, b;
     double abs();
First, a mathematical remark: "imaginary" means a number of the form ##0+bi##, whereas "complex" has the more general form ##a+bi##.
This class is a reasonable start and I probably wouldn't demand more operations in an interview, except I might ask you to implement a copy constructor and an assignment operator, and ask you under what circumstances each one would be called.
Obviously in a real implementation you would override additional operations such as /, -, +=, ==, etc., and also provide versions that allow you to do, for example, complex + real.
You should also have a default constructor, and you should also know why you should have a default constructor. (Hint: what happens if you want an array of complex numbers? Do you need a default constructor for that? Will the compiler create one if you don't provide one?)
a and b shouldn't be public. Better to provide real() and imag() to give access to these.
Code:
    delete *a, *b;
No, this is wrong. a and b are plain old data (POD). You didn't allocate them using new, so you shouldn't delete them. Additionally, a and b are not pointers, so *a and *b are syntax errors. Bottom line: you don't need a destructor for this class.
Code:
     return sumguy;
The right prototype for this is
Code:
Imaginary Imaginary::operator+(const Imaginary& nextguy)
(No need to make a copy of nextguy.)
Code:
    b = -b;
There's no ' operator in C++, so you can't override it. You can implement this as conj() ,for example.
Code:
double abs() {
This is OK. Its usage would be mag = z.abs(); You may also want to provide a static version so you can use the more natural idiom mag = abs(z); (But keep it within the class to avoid namespace pollution.)
  • #38
Code:
Ok, I need to study operator overloading.
  • #39
jbunniii said:
8. Without using any standard library functions, how might you go about calculating pi to arbitrary precision?
Would this really be asked in an interview? lol. I'd have to remember some sequences that converge to pi.
  • #40
Well, you can use a series expansion if you know any. Probably the easiest one to remember is
$$\frac{\pi}{4} = 1 - \frac{1}{3} + \frac{1}{5} - \frac{1}{7} + \cdots$$
It doesn't converge very quickly, but it's good enough for an interview. If someone doesn't remember the expansion I usually just write it on the whiteboard and say, OK, use that.
An even better question is to compute ##e## (the natural logarithm base). This has three advantages over the ##\pi## question: (1) more people probably remember its Taylor series
$$\sum_{n=0}^{\infty} \frac{1}{n!}$$
(2) the Taylor series converges pretty rapidly, and (3) the interviewee has to do something intelligent to deal with the factorial.
  • #41
That's the series for arctan(1), I'll list a few of these here:
pi/4 = arctan(1)
pi/4 = arctan(1/2) + arctan(1/3)
pi/4 = 4 * arctan(1/5) - arctan(1/239)
pi/4 = 6 * arctan(1/8) + 2* arctan(1/57) + arctan(1/239)
[tex]{arctan}(x) = \frac{x}{1} - \frac{x^3}{3} + \frac{x^5}{5} - \frac{x^7}{7} + \cdots [/tex]
  • #42
I'm going to start my final answers to a few questions. Make sure these are right so far.
1. Neither is correct because str is of scope local to function and as such is destroyed after function is finished doing its business. The way to do this correctly is to new the string so it survives the function exit:
(From the C++ standard string class http://www.cplusplus.com/reference/string/string/)
Code:
cost string* GetString(void) {
    string* str = new string("Hello");
    return str;
3. FINAL ANSWER for reversing a string:
Code:
void ReverseString(string &str) {
     unsigned int length = str.length();
     for (unsigned int i = 0; i < length / 2; i++) {
        char temp = str[i];
        str[i] = str[length - i - 1];
        str[length - i - 1] = temp;
  • #43
Obviously you create a factorial function that uses a recursive algorithm:
Code:
unsigned int factorial(unsigned int n) {
    int product;
    if (n <= 1) return 1;
    product = n * factorial(n - 1);
    return product;
And then an extremely elegant but inefficient way of calculating e would be:
Code:
unsigned long double sum = 0;
unsigned long int n = 0;
while (sum + 1/factorial(n) > sum) {
    // while condition tests whether 1/factorial(n) is bigger than machine epsilon
    sum += 1/factorial(n);
    n++;
But the efficient way of doing the entire procedure is just:
Code:
unsigned long double sum = 1;
unsigned long int n = 1;
unsigned long double product = 1;
while (sum + 1/(product * n) > sum) {
    sum += 1/(product * n);
    n++;
    product *= n;
const unsigned long double EulersNumber = sum;
  • #44
Note that string literals such as "Hello" are supposed to be static. In the first example, although str is destroyed, the returned pointer to the static literal string "Hello" should still be valid.
  • #45
Code:
    n++;
    product *= n;
I don't think you want both (product * n) and product *= n in the loop. Think about the second iteration of the loop. At the start of the loop, product = 2 and n = 2, so you just want 1/product, not 1/(product * n).
The rest is OK, except there is no "unsigned long double" type, just "long double". And you might get into trouble with the exit condition for the loop. You will stay in the loop until the sum doesn't change anymore, but that might be longer than you want to wait. Maybe better to compare 1/product to some epsilon.
  • #46
This is correct. The initializer
Code:
const char *str = "Hello";
will create a local pointer called str, and that pointer will point to an address somewhere in static memory where "Hello" is stored by the compiler-generated startup code, which is executed before main() is called. There is no problem returning str in this case. The variable str itself disappears when the function returns, but the function returns a copy of it, and the address it contained is still valid, and "Hello" still resides at that address.
So the original GetString1() function is the correct one.
Code:
const string* GetString(void) {
    return str;
This solution will work, but it wasn't one of the options. One problem is that "string" doesn't exist in C, so this only works in C++. The other problem is that this function allocates new memory, and now it becomes someone else's responsibility to delete that memory when the string is no longer needed. This is usually a really bad practice, because it invites memory leaks. If you must create and return a new string, then do it this way:
Code:
string GetString() {
    string str("Hello");
    return str;
This will return a copy of the local variable str. The local variable disappears at the end of the function. The copy (return value) will be valid until it goes out of scope, at which point its destructor will automatically free any memory associated with it.
