How can we tell if a given tensor is a curvature tensor?
In summary, the curvature tensor is a 2-form that corresponds to a metric in a given gauge. It is Abelian if the gauge group is Abelian, and non-Abelian if the gauge group is non-Abelian. It is possible to solve the equation R=dA + A^A for A, but this is not always straightforward.
schieghoven
85
Under what circumstances do we know whether a given tensor of 4th rank could be the curvature tensor of a manifold? For instance, if I specify some arbitrary functions R_{ijkl} (with the necessary symmetries under interchange i<->j, k<->l, and ij<->kl), is it necessarily the case that there is a manifold for which R_{ijkl} is the curvature? I guess that satisfying the Bianchi identities is a necessary precondition.
And if so, is there any way to construct the metric explicitly?
Thanks,
Dave
I'm in a hurry so I'll give you a very dirty answer to decode.
The Riemann tensor is a gl(N,R) Lie-algebra valued 2-form, just like the field strength in Yang Mills theories (there, the algebra is su(N)). In the latter case, one may impose the recover the gauge connection from the field strength in a particular gauge, namely the Fock-Schwinger gauge (the calculation is done here: http://www.physics.thetangentbundle.net/wiki/Quantum_field_theory/gauge_theory/gauge_fixing )
Now, if you have some experience dealing with gravity as a gauge theory (see e.g. Nash & Sen, or Nakahara), then you have a connection from which you have enough data to reconstruct almost anything else.
Hi lbrits,
Thanks for the pointer to differential forms, it certainly seems to offer a new angle to the question. However, it seems to me that the link you provided about Fock-Schwinger gauge assumes the gauge group is Abelian, since it constructs a potential A which satisfies F=dA. For Yang-Mills or the gauge formulation of gravity, the field strength/curvature is related to the connection by R = dA + A^A.
In the non-abelian case, the problem is how to solve the equation R=dA + A^A for A, which I don't know how to do. I'm not even sure what condition to put on R to guarantee that a solution exists. (dR=0 is not generally true. Contrary to my earlier post, the Bianchi identities can't even be applied since we need A to do this.)
Cheers,
Dave
The trick is that [tex]x^\mu A_\mu = 0[/tex], which is the actual gauge condition. Thus the equation presented is both Abelian and non-Abelian.
You had me worried there for a second =)
Brilliant! Thanks! Following your lead, I've also located a few papers which have set me moving again. For anyone following the thread, [1] appears to be the paper which first demonstrated this solution, and it's very understand-able. [2] is where I found [1], although I didn't understand much of it.
Dave
[1] Cronstrom, Phys Lett B90 (1980) 267
[2] Kummer & Weiser, Z. Phys C31 (1986) 105
Strange, the Fock-Schwinger gauge is ancient... it is, after all, named after Fock and Schwinger =)
Perhaps you're right there, I'm not sure. Well, it's a reference, if not the original reference.
It occurred to me that I'm not even sure if the set of admissible curvatures forms a vector space. By this I mean that if R and R' are curvature tensors corresponding to metrics g and g' respectively, it's not clear to me that R+R' is also a curvature tensor, and if so, how its metric relates to g and g'. Perhaps its possible to prove or disprove this using the Fock-Schwinger gauge - I'll see whether I can get anywhere with it.
This is quite a contrast to electromagnetism, because in that context the sum of two EM fields also satisfies Maxwell's equations, and the set of EM field configurations is a vector space (a Hilbert space). I was interested to see whether a similar analysis can be done for gravitation; but this one may not go through quite as cleanly as I hoped!
Dave
1. What is a tensor?
A tensor is a mathematical object that represents a generalization of vectors and matrices. It is used to describe physical quantities that have both magnitude and direction and can be expressed in multiple dimensions.
2. What is a curvature tensor?
A curvature tensor is a type of tensor that describes the curvature of a space or manifold. It is used in differential geometry to study the curvature of spaces and is an essential concept in Einstein's theory of general relativity.
3. How is a curvature tensor different from other tensors?
A curvature tensor is different from other tensors because it describes the curvature of space, while other tensors may represent physical quantities such as forces or velocities. It also has specific mathematical properties that allow us to determine the curvature of a space.
4. What are the components of a curvature tensor?
The components of a curvature tensor are known as the Riemann curvature tensor, and they are written in terms of the metric tensor, which describes the distance between points in a given space. The components represent the curvature of different directions in the space.
5. How can we tell if a given tensor is a curvature tensor?
A given tensor can be determined to be a curvature tensor by checking if it satisfies certain mathematical properties, such as the Bianchi identity and the symmetries of the Riemann curvature tensor. Additionally, if the tensor is used in the context of studying the curvature of a space, it is likely a curvature tensor.
