Michelson–Morley experiment: Did it disprove the existence of ether?
  • Thread starter cragar
  • Tags
    Experiment
In summary: This means that the path the light takes is different than the path the other beam takes, which causes interference.
  • #211
At this point what I understand is that, in words, the reason for this device that I drew, to act exactly the same, no matter what velocity is, would be:
True, there is time dilation, but the speed of light in one way, is not the same between two frames, it is even not the same (the one way speed of light) within one frame, under certain conditions.
Correct?
  • #212
If you are using inertial reference frames then the one way speed of light (in vacuum) is always c under all conditions.
Did you not read my explanation above?
  • #213
Correct?
I don't know what you mean with "not the same within one frame, under certain conditions". But I answered those questions more or less in #112 and #128.
Usually people mean with "frame", a single frame of measurement. According to special relativity (which is only valid at constant gravitation), the speed of an undisturbed light ray is everywhere the same.
Moreover, the laws of special relativity are made for a special kind of frame: clocks must be set in such a way that the measured one-way light speed is the same everywhere. This is being discussed in the thread on relativity of simultaneity. Do you understand the train example? If not, please ask your questions there!
  • #214
Dalespam,
Of course I read your explanation.
And then I thought, that you were talking about the one way vs. two way speed of light.
Did you refer by de-synchronization to something else, e.g. a result of moving the light detector clocks apart, so that 'moving them apart' movement, no matter even if slow, creates de-synchronization, which amounts exactly to the time dilation created by the frame velocity itself?
  • #215
I understand your diagram to have light going in only one direction, so the two-way speed of light is not relevant.
Exactly. If you have two clocks which are not at the same location and they are synchronized in one frame then, by the relativity of simultaneity, they will not be synchronized in any other frame.
In your drawing you show that the detector clocks are separated by a distance of ~1/3 the total length of the lower path, so if the detector clocks are synchronized in the rest frame they will not be synchronized in the moving frame. This desynchronization will exactly compensate for the time dilation on the upper path.
  • #216
roineust said:
[..]so that 'moving them apart' movement, no matter even if slow, creates de-synchronization, which amounts exactly to the time dilation created by the frame velocity itself?
Only slow clock transport allows to keep the synchronization (in good approximation).
Consequently, if clocks are synchronized in a moving frame and then slowly moved apart along the direction of motion, then in the stationary frame the clocks will look de-synchronized. And that effect is due to time dilation.
Is that what you meant?
  • #217
roineust said:
What you are saying is, that it is actually not the moving apart of the clocks, but the acceleration (or is it also, or only, the constant speed) engaged on clocks, while and because they are not measuring at the same place, even inside the same frame, although they are both experiencing in that frame the exact same acceleration (or constand speed), right?
There is no acceleration involved. I was assuming that your device was purely inertial and that the reference frames were also purely inertial.
The desynchronization is inherent in the definition of the inertial frames themselves (Einstein synchronization convention) and is not related to mechanical acceleration.
roineust said:
And also you are saying that there is no 'mechanical' or 'by words' explanation, from this point on, and at that phase of understanding further, but only a mathematical description available further, right?
And that this barrier, of 'the end of spoken words ability to describe', is maybe, the exact historical and major point of departure, of modern science from classical science?
I can make lots of spoken words on this topic. The words are merely a translation from math to English, but that is true of Newtonian physics too.
  • #218
roineust said:
Dalespam, harrylin, ghwellsjr, anyone else:
For me, at least for a while, it is the end of my investigation on the subject, although I don't know if for the right reasons…
So can you please take one last look at this rephrased description and tell me if you agree:
What you are saying is, that it is actually not the moving apart of the clocks, that is actually, absolutely possible to synchronize in the stationary frame, but the difference of constant speed between the frames, engaged on the clocks, while and because they are not measuring time at the same place, although both inside the same frame, although they are both experiencing in that frame the exact same constant speed , right?
And also, you are saying that there is no 'mechanical' or 'by words' explanation, from this point on, and at that phase of understanding further, but only a mathematical description available further, right?
Otherwise, why would the exact same velocity on the two clocks would de-synchronize them? 'Just' because while at the same frame, they are some distance apart? It is because it is because, 'because' means: math says so and verified by experiments, and there is no middle way between the math and the experiments...?
Correct?
Thanks,
Roi.
Hmm.. I think that you now have it wrong, because you jumped to (wrong) conclusions.
The exact same velocity on two clocks can not de-synchronize them; but two clocks can only move apart if they do not have the exact same velocity.
The difference in time dilation causes the de-synchronization.
And note that such a de-synchronization does not happen on distant clocks during acceleration: then you must change the clocks yourself (or keep them together during acceleration, and move them slowly apart afterwards).
  • #219
harrylin,
I have made a few more small changes and added a diagram, please take a look if this is what you meant.
  • #220
roineust said:
What you are saying is, that it is actually not the moving apart of the clocks, that is actually, absolutely possible to synchronize in the stationary frame, but the difference of constant speed between the frames, engaged on the clocks, while and because they are not measuring time at the same place within the moving frame, although both are inside the same moving frame, although they are both experiencing in that moving frame the exact same relative constant speed , right?
I can't make heads or tails of this paragraph.
All of physics is mathematical and experimental. For instance, what is force absent Newton's law f=ma?
  • #221
roineust,
Using SR synch method, A sets clocks 1 & 2 to match his central clock, without knowing his speed through space. The round trip transit times are equal.
U and anyone else who does not have a velocity equal to A, sees c1 & c2 out of synch.
If the clocks were moved from the center in opposite directions,each would move at a different speed.
  • #222
Roi, I have no idea what your diagram is depicting but I don't really care. You should not be trying to question the ideas of Special Relativity or trying to find experiments that you can understand that will prove Special Relativity to you. You should be learning Special Relativity. After you understand it and the reason why it is a useful theory to understanding reality, then you probably won't care about your diagram either.
Let me just emphasize some points that you have consistently questioned:
*There is no way to detect an absolute rest frame.
*There is no way to build an absolute clock.
*Time dilation is a real phenomenon.
*Only clocks that are at rest with respect to each other can be synchronized.
*Length contraction is a real phenomenon.
OK?
I have tried to help you learn what relativity is all about without using any mathematics, just animations, but your last comment to me on your thread was:
roineust said:
ghwellsjr,
Ok,
It seems you added quite detailed clarifications here,
So, it will take me some time now, to get familiar with the new post.
And then you went off on this long side track asking for experimental proof of length contraction and time dilation, and finally ending in more of your diagrams that nobody can understand.
This is not the way to make progress. I still believe I can help you understand Special Relativity without getting into math through the use of animations. I urge you to forget asking questions about your own ideas and focus on what I have presented to you and ask questions only about what you don't understand in my animations and my descriptions of them. I would suggest that you go back and read all my posts on the above linked thread and make sure you understand those animations and ask any question you may have about them. Are you willing to do this?
  • #223
Can you please take one last look at this attached diagram, and rephrased description, and tell me if you agree: (please note that synchronization is always done before the clocks are apart, and that, in the diagram example, the clocks [A,B] are synchronized and moved apart, only when they are in the stationary frame).
What you are saying is, it is absolutely possible to keep them synchronize (A,B) in relation to one another, after they are moved apart, within the stationary frame. What it is, that makes the device, with the exact same configuration, work the same, in both the moving and stationary frames (in contrast to the diagram) - has to do with what happens in the moving frame, which is: Time dilation in the middle clock (C), within the moving frame, coupled with the fact, that both clocks (A,B) are measuring time, at different positions, within the moving frame. The same different positions (A,B) as in the stationary frame, now in the moving frame, makes the difference.
So the difference that compensates for C clock time dilation, and makes the device work always the same in both frames, can occur in two ways: 1. When acceleration occurs - if the clocks are first synchronized and moved apart, in the stationary frame (as in the above example and diagram), Or: 2. While the action of moving the clocks apart occurs (relatively to the stationary frame, and not to each other), if synchronization is done in the moving frame. Is that correct?
Thanks,
Roi.
  • #224
Yes. This is known as the relativity of simultaneity.
roineust said:
So the difference that compensates for C clock time dilation and makes the device work always the same in both frames, can occur in two ways: 1. When acceleration occurs - if the clocks are synchronized, and moved apart, in the stationary frame (as in the above example and diagram), Or: 2. While the action of moving the clocks apart occurs (in relation to the stationary frame), if synchronization is done in the moving frame.
It is more basic than that. Neither acceleration nor moving the clocks apart is essential since you can construct scenarios without acceleration or moving the clocks apart. The point of the relativity of simultaneity is that different reference frames disagree about whether or not two spatially separated events are simultaneous. It has more to do with the definition of simultaneity (aka the Einstein synchronization convention) than with the movement of the clocks.
roineust said:
And also, you are saying that there is no 'more mechanical' or 'only one ideal spoken words' explanation, from this point on, but at that phase of understanding further, only is a mathematical description available.
This is rather irritating. You have asked this exact same question twice already and I have responded twice already. Please don't repeat your same question a third time, instead respond to my answers. If there is something about them that you don't understand then ask for clarification. Repeating yourself a third time will get the same answer a third time (or an irritated response like this). This form of conversation seems to be a bad habit with you as I have often had you repeat questions that I already answered. Frankly, it is a bit rude.
  • #225
No problem,
Consider the last section just a leftover.
I took it out.
Thanks a lot.
Roi.
  • #226
Can you please take one last look at this attached diagram, and rephrased description, and tell me if you agree: (please note that synchronization is always done when the clocks are not apart, and that, in the diagram example, the clocks [A,B] are synchronized and moved apart, only when they are in the stationary frame).
OK then, this is for me the last time that I reply to this in this MMX thread.
Your clocks A and B are synchronized and moved apart when the system is in rest, and next the whole system with clocks is brought to a certain speed - I will assume a speed parallel to the drawing.
Then the one-way speed of light will not appear isotropic in that moving system because the clocks are not synchronized according to the standard SR convention.
[edit:] If you mean, if they are moved apart, they will remain in sync according to the frame in which they are in rest? Yes. That is however relative, not absolute.
What it is, that makes the device, with the exact same configuration, work the same, in both a moving and stationary frame (in contrast to the diagram) - has to do with what happens in the moving frame, which is: Time dilation of the time delay of the middle clock (C), within the moving frame, coupled with the fact, that both clocks (A,B) are measuring time, at different positions, within the moving frame. The same different positions (A,B) as in the stationary frame, now in the moving frame, makes the difference.
Huh?! No, the main point of relativity is that you can choose which frame you call "moving" or "stationary"! Correcting your errors, we get:
The difference that compensates for C clock time dilation and makes the device work always the same in both states of motion, can occur in several ways, for example:
1. If the clocks A and B were synchronized, and moved apart before acceleration (as in the above example and diagram), and then re-synchronized by means of light signals.
Or:
2. If those clocks are synchronized and equally moved apart relative tot the system after the acceleration, they will remain synchronized according to the synchronization convention.
Is that correct?
Thanks,
Roi.
No, of course not- just read what we wrote, none of us were saying that!
Success,
Harald
  • #227
Or:
Success,
Harald
1. agree
2. If they move within the rest frame, they are no longer a part of that frame.
The frame has an unknown velocity which will not be zero, therefore each clock will move to its destination at different speeds and be out of synch.
  • #228
phyti said:
1. agree
Clocks that are equally moved apart will remain in sync as measured in the frame in which they were (and are again) in rest. Obviously that means that they must then be out of sync as measured in a frame in which they are moving.
  • #229
I don't like this phrasing. They are material objects and as such they cannot be "a part of that frame" to begin with. Frames are essentially just coordinate systems, so material objects do not go in or out of frames and they are never a part of a frame. I would have said it:
"If they move within the rest frame, they are no longer stationary in that frame."
  • #230
I didn't know we had to submit our posts for review or editing.
On examining your statement, there seems to be redundancy (red or blue).
Sorry you were not appointed a role model for society, but keep trying!
Coordinate systems have at least one reference object (the origin), right? A frame has a system of clocks, right? Aren't clocks objects?
In the frame with its origin at Earth center, is there a clock at Alpha Centauri, no. Do we need one there, no.
A single observer with a single clock and laser is sufficient to make measurements where feasible.
The point being made was physics, not grammar.
If the object is moving relative to the frame or any object that is at rest in that frame, its clock rate will be different, until it arrives at its destination in that frame. It will run at its previous rate but will be out of synch with the master clock which did not move. Synchronization is used here as equal simultaneous readings, which is the purpose of the method used in SR.
