plouffle
- 3
In this exercise we want you to apply your knowledge of Relay Logic Instructions to
design a program which will control the ProSim-II Door. The Door System includes a
Reversible Motor, a pair of Limit Switches and a Control Panel, all connected to your
PLC. The program you create will monitor and control this equipment while adhering to
the following criteria:
In this exercise the Open and Close pushbuttons will be used to control the
movement of the door. Movement will not be maintained when either switch is
released, and therefore the Stop switch is neither required nor used in this
exercise. However, all other available Inputs and Outputs are employed in this
exercise.
Pressing the Open Switch will cause the door to move upwards (open) if not
already fully open. The opening operation will continue as long as the switch is
held down. If the switch is released, or if limit switch LS1 opens, the door
movement will halt immediately.
Pressing the Close Switch will cause the door to move down (close) if not already
fully closed. The closing operation will continue as long as the switch is held
down. If the switch is released, or if limit switch LS2 closes, the door movement
If the Door is already fully opened, Pressing the Open Switch will Not energize the
motor.
If the Door is already fully closed, Pressing the Close Switch will Not energize the
motor.
Under no circumstance will both motor windings be energized at the same time.
The Open Lamp will be illuminated if the door is in the Fully Open position.
The Shut Lamp will be illuminated if the door is in the Fully Closed position.
