Soumalya
- 183
- 2
Hello,
It is said that any process accompanied by dissipating effects is an irreversible process.For instance, a piston cylinder arrangement undergoing an expansion of a gas with heat lost as friction between surfaces is an irreversible process.Here the system does work on the surroundings with heat being rejected to the surroundings as a result of friction.The process can be summed up as:
Work transfer for the system= -W
Work transfer to the surroundings=+W
Heat lost from the system=-Q
Heat gained by the surroundings=+Q
Then logically the process could be reversed at any stage if external work is done by the surroundings on the system equal to W and heat lost as friction be added to the system so that both system and surroundings are restored to their initial conditions.So why it's still called an irreversible process?
