Verifying Fourier Series In MATLAB
In summary: Instead of fs=fs+... you could write fs = fs + a0/2 + an*cos(n*x)+bn*sin(n*x);In summary, we have a conversation discussing a code for calculating the sum of a series and a Fourier series. The code has some errors, which are pointed out and suggestions for improvement are given. The final code includes simplified calculations and a more efficient loop.
Jovany_17
HI please help me this could someone verify it for me please find attachement
clc;
clear all;
k=0;
s=0;
N=inf;
for i=1:N
s=s+(1/(k^2+1));
k=k+1;
end
syms x n
a0=1/pi*int(cosh(x),-pi,pi);
an=1/pi*int(cosh(x)*cos(n*x),-pi,pi);
bn=1/pi*int(cosh(x)*sin(n*x),-pi,pi);
fs=0;
for l=0:100
fs=fs+(an*cos(l*x)+bn*sin(l*x))
end
fs-fs+a0/2;
clc;
clear all;
k=0;
s=0;
N=inf;
for i=1:N
s=s+(1/(k^2+1));
k=k+1;
end
syms x n
fs=0;
for l=0:100
end
fs-fs+a0/2;
The calculation of s looks OK. It could have been done slightly easier.
N=inf;
s=1;
for k = 1:N
s=s+(1/(k^2+1));
end
The Fourier series sum has a couple of errors. I would do the following:
fs = a0/2;
N = inf;
for n = 1:N
fs=fs+(an*cos(n*x)+bn*sin(n*x));
end
Thanks
A further simplification: Except for a0, the values of an and bn can be calculated inside the loop, so they don't have to be stored in advance.
The code provided appears to be verifying the Fourier series for the function cosh(x) in MATLAB. It calculates the coefficients a0, an, and bn using symbolic integration and then uses a for loop to calculate the series up to a certain number of terms (in this case, 100). Finally, it verifies the series by subtracting it from itself and adding the constant term a0/2. This code seems to be a valid way of verifying the Fourier series, but it would be helpful to include comments and a clear explanation of the code for better understanding. Additionally, it would be beneficial to include a plot of the original function and the Fourier series approximation for visual verification.
1. "What is a Fourier series and why is it important?"
A Fourier series is a mathematical representation of a periodic function as a sum of sine and cosine functions. It is important because it allows us to break down complex signals into simpler components, making it easier to analyze and manipulate them.
2. "How do I verify a Fourier series in MATLAB?"
To verify a Fourier series in MATLAB, you can use the "fft" function to compute the Fast Fourier Transform of the function and compare it to the series representation. You can also use the "fouriercoeff" function to calculate the coefficients of the Fourier series and plot the resulting series.
3. "What is the difference between a Fourier series and a Fourier transform?"
A Fourier series is used to represent a periodic function as a sum of sine and cosine functions, while a Fourier transform is used to represent a non-periodic function as a sum of sine and cosine functions with different frequencies. In other words, a Fourier transform is a generalization of a Fourier series for non-periodic functions.
4. "Can I use MATLAB to verify a Fourier series for a non-periodic function?"
No, you cannot use MATLAB to verify a Fourier series for a non-periodic function. However, you can use the "fft" function to compute the Fourier transform of the function and verify its representation in the frequency domain.
5. "What are some applications of Fourier series?"
Fourier series have many applications in various fields such as signal processing, image and sound compression, data analysis, and solving differential equations. They are also used in practical applications such as image recognition, speech recognition, and audio processing.
  • MATLAB, Maple, Mathematica, LaTeX
  • Topology and Analysis
  • Math POTW for University Students
