willydavidjr
- 66
Can someone give me an idea how to compute or how to get the work done by the battery if there is a circuit given with resistor and a capacitor?:grumpy:
Hurkyl said:Power relates to work, right? ...
Hurkyl said:Presumably he can figure out the power dissipated by the resistor, and get the amount of work done through that component of the system.
Hurkyl said:Right. But you already covered that part, and I didn't have anything to add to it.
Matter of fact you could!Hootenanny said:Oh right, I thought I was missing something, like you could just work out the problem by considering power dissapated by the resistors. Thanks
~H
It's clear that when the battery is disconnected, the power subsequently dissipated by the resistor will be exactly the energy stored in the capacitor.tehno said:Matter of fact you could!
The energy dissipated during the charging of a capacitor equals the energy stored in the capacitor at the end of the process.
I don't CARE what work the battery is doing, the battery needs to get its smelly arse back to Mexico! :tongue2:willydavidjr said:Can someone give me an idea how to compute or how to get the work done by the battery if there is a circuit given with resistor and a capacitor?:grumpy:
No!You are missing the point.willydavidjr said:Meaning the energy that occurs in the capacitor is also the same as the energy use by the battery?
That's right.willydavidjr said:Techno you mean, if the energy in capacitor is 20 joules, the energy in the battery is 40 joules? Am I right?
The work done by the battery is the amount of energy transferred from the battery to a circuit or device. It is measured in joules (J) and is equal to the product of the voltage (V) and the charge (Q) passing through the circuit.
The work done by the battery is directly proportional to the voltage and current in a circuit. This means that as the voltage or current increases, the work done by the battery also increases.
No, the work done by the battery cannot be negative. This is because work is defined as the transfer of energy, and energy cannot be transferred in a negative direction. However, the work done by the battery can be zero if there is no circuit or device connected to it.
The amount of work done by the battery is directly related to the amount of energy available for a device to use. A higher work done by the battery means more energy is being transferred to the device, which can result in better performance. However, the design and efficiency of the device also play a significant role in its performance.
No, the work done by the battery is not the same as its capacity. Battery capacity refers to the amount of energy that a battery can store. The work done by the battery is the amount of energy that is actually transferred from the battery to a circuit or device.
