Listing all forces on someone swimming in a pool
In summary: F=ma is a simple equation that you can use to calculate the force and motion of a body in a fluid. You will need to use a finite set of equations to solve for the body's motion.
sauri
51
I have this assignment where I am supposed to list all the forces acting on someone who is swimming in a standered olyimpic sized pool.
The obvious force to me was the mass of the swimmer acting downwards and presuming the guy was swimming forward there would be a drag force acting backwards. Also as he is swimming, there will be the force of the water pushing his hands forward. (Action reaction force). This is al the forces I can think of...is there anymore? and am I correct so far?
You need something to counter the gravitational force on the swimmer. Why does he stay up?
how about the viscosity of the water, the forces are man, gravity, water (resistance). The man burns calories, the Earth has gravity, and water acts as resistance to man going from one end to the other. I would think it possible to derive more specific forces from those three. buoyancy would be the the difference between man and water, man can drowned though.
ok, so to oppose the downward gravitational force we have the upward force provided by the water, which gives us buoyancy. Can we call this the normal force?. So apar from this are there any other force that need to be accounted for?
Swimming is mostly about lift and drag (in addition to the buoyancy balancing your weight). The force that a fast swimmer generates with their hands is not just "pushing" the water back. It's using your hands as wings or propeller blades, to generate lift. You shape your hands like wings, with the back of your hands rounded a bit. Your pull moves your hand through the water in a path that generates the most lift off your hand (water going over the rounded top of the hand goes faster than under the flatter palm area, generating lift just like a wing).
When you swim fast, the movements of your body in the water up and down and in rotation are very important to optimizing your speed. In butterfly, for example, the better your dolphin kicking motion and body movement up and down, the smoother and faster your overall stroke is. So from a force perspective, you are applying forces to the water with your hands, arms, body, legs and feet that aren't directly for pushing you forward, but are very necessary for a good stroke. Another example is how getting a lot of rotation into your freestyle stroke is important for good medium and long distance speed and endurance.
Also don't forget that you do get a little propulsion from your feet, although mostly the kicking motion is for upper body balance (except for short sprint races). Finally, remember that part of the body is out of the water, so you will get some very small air (drag) forces too.
That helps a lot thanks..one other thing though. If we were to fnd the speed of the swimmer, is it still applicable to use the linear equations of motion?
What do you mean by linear equations of motion? Lift and drag are not linear...
Well i was wondering what kind of calculations could be counducted on a swimmer and how they could be resolved?
Yoiks! That would be a pretty complex set of calculations! Worse than any boat calcs, since the body is moving and changing so much through each stroke.
You need to simplify the heck out of the situation, I would think, before you can do any calculations. The simplest version would be some boat-like body in the water that does not change shape, has some drag, and has some constant means of propulsion (like a rear-facing water jet). The next more complex model would still keep the constant drag body, but model a propeller's hydrodynamics (lift and drag) in the water as the means of propulsion. The next step would be to make the propulsion a mix of pulsed lifts, with changing drags (kind of like the hands and feet produce). The next step would be to modulate the drag to start to simulate the changing body shape with the stroke motion.
Are you using hydrodynamic equations for this motion in the water? Or are you wanting to just use simple F=ma kinds of equations? Are you looking for closed-form equations, or will you be using finite element analysis (FEA) software for the analysis?
1. What are the different types of forces acting on someone swimming in a pool?
There are three main types of forces that act on a person swimming in a pool: buoyant force, drag force, and weight. Buoyant force is the upward force exerted by the water on the person's body, which helps to keep them afloat. Drag force is the resistance force caused by the water as the person moves through it. Weight is the force of gravity pulling the person towards the bottom of the pool.
2. How does the shape and size of a person's body affect the forces acting on them while swimming?
The shape and size of a person's body can affect the forces acting on them while swimming. A larger body will experience more drag force due to its increased surface area, while a smaller body will experience less drag force. The shape of the body can also impact the distribution of weight and buoyant force, affecting the person's overall buoyancy and ability to swim efficiently.
3. Do the forces acting on a person while swimming change with depth?
Yes, the forces acting on a person while swimming do change with depth. As a person dives deeper into the pool, the pressure of the water increases, which can impact the buoyant force and drag force acting on them. Additionally, the weight of the person may also change due to the difference in gravitational pull at different depths.
4. How do external factors, such as waves or wind, affect the forces acting on a person while swimming in a pool?
External factors, such as waves or wind, can affect the forces acting on a person while swimming in a pool. Waves can create additional drag force on the person's body, making it more difficult to move through the water. Wind can also create waves and may impact the direction and speed of the person's movement in the pool.
5. Can the forces acting on a person while swimming be manipulated or changed?
Yes, the forces acting on a person while swimming can be manipulated or changed. For example, by changing their body position or stroke technique, a person can reduce drag force and increase their speed. Additionally, using floatation devices can decrease the impact of weight and increase buoyant force, making it easier for a person to stay afloat and swim.
  • Classical Physics
