Do all which-way attempts/techniques introduce phase difference between the waves ?
In summary, attempts to determine the which-way information in a double slit experiment introduce a phase difference between the waves, but alternative techniques such as weak measurement and entanglement are being explored to avoid this disturbance. It is not possible to detect a photon without causing some level of disturbance.
San K
911
do all which-way attempts/techniques introduce phase difference between the "waves"?
In a double slit experiment
One hypothesis (or fairly well accepted theory?) is:
If we try to find which-way via Quarter Wave Plates (QWPs), we add a phase difference (between the "waves that seems to have traveled" from each slit).
The phase difference results in the waves not being coherent which in turn spoils/distorts the interference pattern.
Interference pattern is the (neatest and) cleanest when the waves are coherent.
Even in the (modified) Mach–Zehnder experiments, attempts to get which-way cause phase difference between the "waves that seem to travel" both the arms simultaneously.
Are there any alternate techniques/methods (other than QWPs) to get which-way without causing any phase difference in the "waves that seem to travel" both/numerous paths?
Wheeler had as a very hypothetical/thought-experiment, suggested telescopes. But I guess telescopes cannot be used.
Also can we ever observe/detect a photon (position, spin etc) without disturbing it?
I can confirm that the use of Quarter Wave Plates (QWPs) or any other method to determine the "which-way" information in a double slit experiment does introduce a phase difference between the waves. This is due to the fact that in order to determine the which-way information, we must interact with the particles/waves in some way, causing a disturbance and altering their original state.
However, there are alternative techniques that have been proposed and are currently being researched in order to obtain the which-way information without causing a phase difference. One such technique is called weak measurement, where the interaction with the particle/wave is very small and does not significantly alter its state. This allows for the determination of which path the particle/wave took without affecting the interference pattern.
Another approach is using entangled particles, where the which-way information of one particle is correlated with the other particle, but without directly interacting with it. This has been demonstrated in experiments using entangled photons.
As for Wheeler's suggestion of using telescopes, it is not a practical method as it would require a very large and precise telescope to detect the individual particles/waves in a double slit experiment. Additionally, the act of observing with a telescope would also cause a disturbance and alter the state of the particles/waves.
In terms of detecting a photon without disturbing it, it is not possible according to the principles of quantum mechanics. The act of measurement inherently disturbs the state of the particle/wave being measured. However, as mentioned before, techniques such as weak measurement or entanglement can minimize this disturbance.
1. How do "do all which-way" attempts or techniques introduce phase difference between waves?
When a "do all which-way" attempt or technique is used, it introduces an additional element to the wave system, such as a detector or observer, which can alter the phase of the waves. This results in a phase difference between the original waves and the altered waves.
2. What is the significance of phase difference between waves in "do all which-way" experiments?
The phase difference between waves in "do all which-way" experiments can provide information about the interference pattern of the waves. It can also indicate whether the wave has undergone any changes or interactions with its environment.
3. Can the phase difference between waves be controlled in "do all which-way" experiments?
Yes, in some cases, the phase difference between waves can be controlled by manipulating the environment or the experimental setup. This can be done by adjusting the position or properties of the detector or observer.
4. How does the introduction of phase difference affect the results of "do all which-way" experiments?
The introduction of phase difference can alter the interference pattern of the waves, leading to different results in "do all which-way" experiments. It can also provide insights into the behavior of the waves and their interactions with the environment.
5. Are there any limitations to using "do all which-way" attempts/techniques to study phase difference between waves?
Yes, there are limitations to using "do all which-way" attempts/techniques to study phase difference between waves. These techniques may not accurately reflect the behavior of the waves in natural or real-world scenarios, and the results may be affected by external factors or experimental setup.
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
