Hypothesizing on photon mode of travel in double slit or similar experimental setups
In summary, the conversation discusses the delayed choice experiment using a half silvered mirror or double slit. It raises questions about the interference pattern disappearing if a detector or obstruction is placed on either path after the photon has passed, and whether the interference disappears if the detector is placed after the photon has hit the final detector but not been measured yet. The conversation also discusses different hypotheses about how the photon may travel through the experiment, and whether the split in the wave function can be measured or if interference also works with larger particles.
  • #106
DrChinese said:
I think the context of the entire experiment is relevant. Not just the "first" detection. How you interpret the results is dependent on that context, and that will not be known until later - when all of the results can be brought together into a single place. And then it will in fact appear "as if" the past was dependent on the future.
You can interpret this in different ways. And there are other delayed choice experiments which evidence the same thing. Consider Zeilinger et al:
http://arxiv.org/abs/quant-ph/0201134
From middle of page 5:
"Such a delayed-choice experiment was performed by including two 10 m optical fiber
delays for both outputs of the BSA. In this case photons 1 and 2 hit the detectors delayed
by about 50 ns. As shown in Fig. 3, the observed fidelity of the entanglement of photon 0 and
photon 3 matches the fidelity in the non-delayed case within experimental errors. Therefore,
this result indicate that the time ordering of the detection events has no influence on the
results..."
interesting...it will take me a few days to understand the paper...thanks for the link and your post
cthugha do you want to take a stab at this and summarize it...?
  • #107
To save some time and re-typing efforts, you may also want to have a look at this thread:
https://www.physicsforums.com/showthread.php?t=376225
DrChinese and I have been hashing out two points of view on this work which don't quite agree interpretation-wise ... we have worked through some of the details of the experiment there.
  • #108
sanpkl said:
ok. now let's say we detected the signal photon position and its at (x, y) = (1.5, 120) and it lies on figure 3.
actually y does not matter..its just a count (that can be converted to probability).
so, let's assume, we are reasonably sure (after pattern formed by gazillion photons prior) that signal photon position lies on figure 3.
Ok, so we have a detection at x=1.5 and have recorded the coincidence patterns for a while, right?
sanpkl said:
1. if we choose which way info...are we likely to detect idler at D1?
No, if you choose to destroy which-way info, you are likely to detect the idler at D1. If you keep which-way info you will see a detection at D3 or D4 with equal probability.
sanpkl said:
2. if we do not chose which way info...are we likely to detect idler at?
See above.
sanpkl said:
2b) the signal is on fig 3, suggesting interference and no which way..however if we make which way experiment on idler...then won't signal be saying interference and idler which way?
Well, "signal is on Fig.3" is a sloppy formulation and strictly speaking wrong. You can only be sure that it is likely to end up on fig. 3 if you will erase which-way info on the idler side. Otherwise the corresponding coincidence count cannot end up on Fig. 3 (Fig. 3 are the D0-D1 coincidence counts - if the idler does not go to D1, you are not on Fig. 3). The signal alone does not give you any possibility to choose which-way or interference. In a nutshell the detections on D0 alone are never on a figure. Just the coincidence counts are. However, you can predict where the coincidence counts will end up if you already measured the coincidence count pattern for a while and already decided whether to perform a which-way or interference experiment beforehand.
sanpkl said:
Please give example of kind and amount of information one can gain (about idler?) from knowing the position of where signal was detected. this will help me understand better.
What I meant was the phase information as seen in the coincidence count interference pattern. This information cannot be gathered by looking at the signal detections alone and it is impossible to get this information by looking at the idler detections alone. It is just present if you have both informations present. However, you can choose to discard this kind of information to get which-way information of the idler instead. However, doing so does not change what happened at the signal side.
Well, I often post on topics on delayed choice quantum eraser experiments because it helped me understand coherence, the quantum mechanical meaning of photon bunching and interference of two-photon probability amplitudes in general back in the days of my diploma thesis. Therefore I am quite familiar with that experiment. Regarding the Zeilinger paper you refer to, there are for sure lots of people around here who are able to summarize it much better than I could do.
At first sight it is a different kind of delayed choice experiment. You have two entangled photon pairs and can perform entanglement swapping. Accordingly you can detect two of these photons and can afterwards choose to project the other two photons into a state which should result in also entangling the two photons which are already detected and will find violations of the Bell inequalities if you look for them in the earlier detected photons and do coincidence counting with the other two photons. Although this might seem counterintuitive (from a classical point of view), it is fully consistent with QM. But as I said before: I am sure DrChinese and some others around here will be able to give a much more precise summary of Zeilinger's work.
  • #109
correct.
does this mean the signal photon has a higher probablity of being on figure 3? when its is later correlated with idle
can the probablities of idler striking d1, d2, d3, d4 be, now, calculated
given that: signal was detected at x=1.5?
if we leave the "choice" (of "which way" or not) upto the idler photon..(as in the kim scully experiment)...is it likely to be detected at D1 ...instead of d2, d3, d4?
given the context above...i.e. ...signal photon was detected at x = 1.5 mm
  • #110
sanpkl said:
if we leave the "choice" (of "which way" or not) upto the idler photon ...is it likely to be detected at D1 ...instead of d2, d3, d4?
maybe its possible to calc the probalitities?
Yes, that is possible. Whether a photon goes to D1/D2 or D3/D4 depends on the splitting ratio of the beamsplitters BSA and BSB (see the setup in the Kim paper). Assuming they are 50/50 beamsplitters, 25% of all photons will go to D3 and another 25% will go to D4. The remaining 50% will go to either D1 or D2. How many of these 50% go to D1 and how many go to D2 can be extracted from figures 3 and 4. Having a look at position x=1.5 again, you see that there are roughly 120 coincidence counts for D1 (fig. 3) and roughly 40 coincidence counts for D2 (fig. 4). so for that portion of the total counts you have a distribution of 75% D1 and 25% D2.
So in total you get:
D1: 75% of 50% =37.5%
D2: 25% of 50% =12.5%
D3: 25%
D4: 25%
  • #111
D3: 25%
D4: 25%
Cthugha,
at x= 1.5mm ,
figure 3 = 120, fig 4 = 40
why are fig 5 and fig 6 (not shown) not 80 each?
given that the paper says this is 50/50 beam splitter...
Answer: not all idler photons were able to be collected...fig 3 and 4 are comparable to each other but not comparable with fig 5 and 6
why would figure 6 have a small shift of center relative to figure 5? are the path lengths not same?
  • #112
That can have lots of different reasons: beamsplitters, which are not perfect, small absorption of the mirrors, not exactly equal quantum efficiency of the detectors, bad alignment, not ideally chosen time windows for coincidence counting and so on and so on...
What makes you think figure 6 would show a shift compared to figure 5?
  • #113
D3: 25%
D4: 25%
Continuing with the above experiment...for the millionth plus one signal and idler..where signal photon has been detected at D1..
Case 1: now if we change the beam splitters to 100/0 (where 100 is no which way), what are the probablities?
D1= 0, D2 = 0, D3 = 50, D4 = 50?
Case 2: we add a quantum eraser (the polarizer kind) in the path of idler where we change to no which way. what are the probablities?
Would adding a quantum eraser (in which we control the choice), say of the polarized kind, in the kim scully experiment work?
  • #114
Do you mean D0?
Do you mean that 100/0 is complete which-way information (No which-way means you get the interference pattern, complete which-way info means no interference pattern)? Then your reasoning is correct.
In principle you can add a polarizer kind quantum eraser. The results will then of course depend on your choice of settings.
  • #115
Cthugha said:
Do you mean D0?
yes, i meant Do, typing error..sorry
1. thus essentially the signal photon randomly chooses its position on Do and idler's path is determined, in a probabilistic way, by it.?
or better still
the signal and idler are in a balance (momentum balance/conservation)...as a single entity in a sense...as two faces of the same coin...
when the signal strikes Do the information (about signal's "choice/state") is instantaneously transmitted to idler
2. we don't know what the signal photon "decided/choose" ...till we compare with idler?
3. the idea that idler path is influencing the signal photon position on Do (at the moment of impact on Do or even after impact) is wrong?
  • #116
Entanglement Hypothesis
Hypothesis (just a hypothesis):
Entanglement of the photons (say signal and idler) happens outside space and time.
Thus some of their "properties" are really not separated by space and time.
Every particle (mass/energy) has waves associated with it. In case of particles larger than a few atoms the wave effect is negligible.
  • #117
Dr Chinese
i am reading the paper you sent..will get back in 2 days...
yes, good point. agreed. look forward to your comments on the below:
however half of the experiment is done when signal photon strikes D0?
At that moment in time the signal photon has made it's "choice/mark/determination/frozen" of its position.
- the wave-function of the signal photon has collapsed
- this past (signal photon detection position) does not changed ever
- and it will (probabilistically) effect how the idler photon behaves when choosing paths? i.e. the idler gets the information regarding the frozen state of the signal photon (instantaneously)
  • #118
sanpkl said:
cthugha, eagle,
all of the below might have been answered before but i just wanted to go over it again...with a different rephrasing...
with reference to the delayed choice quantum eraser...http://arxiv.org/abs/quant-ph/9903047
1 a) when a signal photon has been detected on Do, has not the pattern of signal photon (Though *unknown* to us, till we compare with idler in coincidence counter) already been fixed/sealed? does that mean same as "experiment is over"?
i understand that a single photon not a pattern make, i am referring to the direction/potential
1. b) once the signal photon is measured is the fate/path of the idler also "somewhat" sealed (with a high probability)?
this would resolve/invalidate the "past can be changed" hypothesis/misunderstanding, i guess
2. once the signal photon is measured, we till don't know which figure 3,4,5,6 would it fall, until we compare with idler?
this would resolve/invalidate the "faster than light information travel" hypothesis/misunderstanding, i guess
3. the position of the signal photon on Do has nothing to do with what is what we are doing to the idler at that point in time (i.e. at the exact time the signal strikes Do). if i remember correctly cthugha said similar.
this would help resolve/invalidate the "past can be changed" hypothesis/misunderstanding, i guess
cthugha wrote
<In the DCQE experiments the measurement is different. You gain phase information. And once you do so on the side of D0 you get a well defined phase and can therefore predict what will happen on the other side - as phase is the property which determines what happens in a Mach-Zehnder interferometer. However in most cases this will be a probabilistic prediction like "with 70% probability that photon will go to D1">
for me the "70% (or higher than 50%) probablity" explains a lot...
4. i guess that this would also help reduce the need for "many worlds" hypothesis
5. wave function collapses (for both twins-- idler and signal) when either the signal or idler photon is detected?
My response was to the original post which referred to a single photon experiment. Your questions now concern an entangled two-photon experiment. The paper you cite is not an easy read. (At least I did not find it so.) There is a more understandable, non-mathematical, discussion in Walborn et al, arXiv:quant-ph/0503073v1 and also in Roussel and Stefan, arXiv:0706.2596v1. I hope this helps.
Best wishes
  • #119
Best wishes
thanks eagle...
from the walborn cunha paper...
they write..
”Bob, that is amazing! You have control
over the past! While you are at it, can you go back
change my lottery ticket from last week to 67-81-138?,”
Alice asks with a look of awe in her eyes. Bob is loving
the moment, but he is not the greatest magician, and
cannot keep his mouth shut about the secret to his tricks.
”No Alice, look, the photons I gave you were actually entangled
with photons that I kept for myself. I did a series
of polarization measurements, and recorded my results.
My polarization measurements tell me how to divide up
your experimental results so that we can see interference
or not, but I cannot change the position at which any
photon actually landed,” Bob explains. He shows her by
plotting all of the results for which he measured horizontal
OR vertical (orthogonal directions) and they observe
the large mountain peak. He then does the same with
all results of +45◦ and −45◦, and they observe the same
mountain peak. Of course plotting all of the results together
regardless of polarization also gives the mountain
peak, as Alice had already observed. So Bob was not able
to alter the past, it is just that he had more information
than Alice.
thanks eagle...the above confirms/reassures what i said per my understanding of the experiment ...past cannot be changed...
however, in this particular paper/page, they left out the second point...it seems
i.e. the information that Bob has cannot be sent to Alice faster than the speed of light..
the Stefan paper quotes wheeler...and i agree only partially with wheeler...
It
is wrong to speak of the ”route ” of the photon in the experiment of the beam splitter. It is wrong to
attribute a tangibility to the photon in all its travel from the point of entry to its last instant of flight.
the "partial" tangibility is introduced by the fact that we can spot/stop the photon at any point on its path by using the formula time = distance/velocity of light
  • #120
perhaps there is a "dimension" in addition to time-space, through which quantum mechanics operates? the "probability wave function" operates in that dimension.
when we try to measure a photon's position, the wave function collapses, the photon moves back into the time-space dimension
  • #121
Your word “perhaps” says it all. We are forced to speculate about what is “really happening” because Quantum Mechanics tells us nothing about how the photon gets through the apparatus.
A quantum experiment consists of the entire apparatus, including the photon and the measuring device, as well as the experimental result. Everything is set up in space-time.
Photon detection is a real event that we do observe. But, we have no evidence for any other dimension that might help us understand “what is really happening” to the photon before it is detected. Any discussion of photon behavior prior to detection is pure speculation.
We do know that the wave function is defined in a Hilbert space. But as far as we know, it is not a part of the experiment; no one has ever observed the wave function “moving through” the apparatus. Nor has anyone observed its collapse when the photon is detected.
Please forgive me for being so harsh, but it does seem futile to suggest explanations that have no verifiable evidence to support them. But, you are not alone. There are lots of other bright people expending much time, effort, and brainpower in such endeavors.
Best wishes.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
