Is there always at least one irrational number between any two rational numbers?
In summary, the conversation is about proving that there is at least one irrational number between any two rational numbers in an interval. The first attempt at a proof involved assuming the result and using circular reasoning. The second attempt involved using 1/root2 as an irrational number, but it was pointed out that it may not lie within the given subinterval. The final attempt used the Archimedean property to show that there must be an irrational number between any two rational numbers in an interval, and since there are an infinite amount of subintervals, there are also an infinite amount of irrational numbers.
JG89
728
and, consequently, infinitely many.
I am new to proofs so could you please check if this proof is correct?
Let x be an irrational number in the interval In = [an, bn], where an and bn are both rational numbers, in the form p/q.
Let z be the distance between x and an, So:
x - an = x - p1/q1
= x + (-p1/q1)
But an irrational number (in this case x) + a rational number is also an irrational number. Therefore distance from an to x, which is z, is irrational.
The distance from x to the origin, is an + z. But again, an irrational number plus a rational number is also irrational. Therefore, there is always at least one rational number between any two rational numbers. However, the same proof can be applied to an infinite amount of subintervals within In, therefore there is an infinite amount of irrational numbers as well.
Mathematics news on Phys.org
The first thing you did was to assume the result that you wanted to show. If you want to show that there is an irrational in an interval [a,b], then you can't assume there's one in there.
There's no need to use the subscript a_n (or b_n).You can prove this result in many ways. An elegant way that I just thought of (it's not new, just not the one I first thought of) is to show that one can reduce the question to the case of showing there is an irrational in the interval [0,1].
Well, in ~assuming~ the first step you seem to have a decent conclusion for the second. If we assume q, p does follow, but as MG points out you first assumed q to prove p, and then used p to justify q. (with q as "there exists at least one irrational number between a,b, and p as that there therefor exists infinitely many.)
I was afraid that was the mistake I made. Thanks for the suggestion.
Okay, here is another try at me trying to prove that between any interval [a,b], there is at least one irrational number:
Let there be an interval I = [0,1]
An irrational number in I is 1/root2.
1) For any other interval that is not [0,1], but encompasses interval I, then 1/root2 is also an irrational number in that interval.
2) For any other interval [a,b] where 0 < a < 1 and 0 < b < 1 and a < b (basically a subinterval of interval I), 1/root2 must also be an irrational number in that interval because there are an infinite amount of subintervals within that interval.
3) For any other interval which is not [0,1], does not encompass [0,1], and is not a subinterval of [0,1] (the interval is "shifted" over), then let that interval be I_2 = [a,b], where a and b are both rational numbers in the form p/q. The distance between the left end point of I and I_2 is: a - 0 = a = p/q. Therefore, an irrational number in I_2 is 1/root2 + p/q.
Therefore, within any interval [a,b], there is at least one irrational number.
And, also, since there are an infinite amount of subintervals within any interval, with each subinterval having at least one irrational number, then there are an infinite amount of irrational numbers in any interval.
1/sqrt(2) is about 0.7, right? So how does that lie in, say, the subinterval [0, 1/2]?
I should say that for any interval [0,b], where b is < 1, then let there be a rational number p/q = |b - 1|.
An irrational number in the interval [0,b] is then 1/root2 - p/q.
The same thing can be applied to an interval where a is not 0 but b = 1
Hope you didn't see my solution I posted prematurely here.
Why are you letting p/q = |b-1|? There's no need to write fractions, and by assumption 1-b is positive. Notice that if b=0.1, the 1-b=0.9, and 1/sqrt(2) -0.9 is not in the interval [0,0.1] as you claim: it isn't even positive.
The traditional way is to use the Archimedean property. Say a is the first rational and b is the second with b > a. Then there is an n in N such that 1/n < b - a. Also, you can find an irrational number x < a. Then letting S = {x + k/n | k is an integer}, you see that there must be an element, y > x, in S such that y - b < 1/n, therefore, y - 1/n < b. And since b < y and 1/n < b -a, b - (b - a) < y - 1/n, which means a < y - 1/n. Therefore a < y - 1/n < b. Since y - 1/n is irrational, the proof is complete.
What a mess! Thanks Matt and Werg for spending the time and helping me with this. This is something else I came up with, hopefully it works:
root2 is an irrational number. There is always some constant k, which is rational, to which you could add to root2, resulting with a number, c, such that a < c < b for some other interval and c is irrational (since a rational + an irrational is an irrational).
Ah silly of me, the method I explained is too strong : it's used to prove that between any two real numbers there is an irrational number.
matt grime said:
... to show that there is an irrational in an interval [a,b] ...
JG89,
You're getting closer, JG!
However, your last argument wold normally be considered more like "the idea of a proof" rather than a proof.
Here are two possiible next steps.
1) Take your argument above and flesh it out. For example, it would be fair to assume that it is "well known" that for all epsilon greater than zero, there exists a rational number f such that |x-f| < epsilon. This fact could be combined with your idea to make a real proof.
2) Try to find the "elegant" argument that Matt Grime suggested. Here's a hint. Write down the equation of a linear function f:R->R such that f(0)=a and f(1)=b.
DJ
I thought about it a bit. Here is what I have now:
Consider the interval I = [a,b], where both a and b are rational numbers. For all epsilon > 0, |x-f| < epsilon.
Using x = root2 as an irrational number, |root2 - f| < epsilon. However, a < epsilon < b
So, |root2 - f| < b
|-f| < b - root2
f > root2 - b
Considering the other end point, a:
|root2 - f| > a
|-f| > a - root2
f < root2 - a
Therefore, for any rational value f, where (root2 - b) < f < (root2 - a), (root2 - f) will yield an irrational number in interval [a,b].
JG,
Well, that's not exactly what I had in mind.
(In fact, you're now getting further away from a correct proof. Please let me see if I can help you out a little bit.)
I had in mind (for Option 1) starting out something like this.
Since the rational numbers are dense in the set of real numbers, for every epsilon greater than zero, there exists a rational number, g, such that |g-squareroot2|<epsilon.
In particular, let epsilon = (b-a)/4.
Since the rational numbers are dense in the real numbers, there is a rational number that we will call "f" such that |f-squareroot2|<(b-a)/4.
Now let k = -f + (b+a)/2.
[Since you might be a student asking for a solution to a homework problem, and I am not supposed to give full solutions, please try to complete this argument for yourself. Please feel free to ask forum members for help if you want to.]
More Hints:
1) If f is greater than zero, then
"|f-squareroot2|<(b-a)/4" <==> "-(b-a)/4 < f - squareroot2 <(b-a)/4".
2) What you have to prove by the end of your proof is that a < c < b.
Another possibility is to try Matt Grime's suggestion. It is much more elegant than "Option one". Please note that my previous post gave you a hint to get you started in working out Matt's solution. Option one has the advantage that it is your idea (or at least it is based on your idea), but Option two has the advantage that it is a lot easier to work out the details.
DJ
Deacon, I have to think about this more for a while. But, could you please explain what was wrong with the proof that I just posted?
What you wrote does not make any sense.
Giving you a "kind interpretation," I'm guessing that what you meant was:
"Consider the interval I = [a,b], where both a and b are rational numbers. For all epsilon > 0, there exists a rational number "f" such that |x-f| < epsilon.
"Let x = root2. Let epsilon be a positive number between a and b. In other words, let epsilon be a number greater than zero such that a < epsilon < b."
Now what's wrong with that?
Well first, a and b might be less than zero, so, there might not be any positive numbers between them.
But, that doesn't really get to the heart of the matter.
Epsilon is supposed to be a "small" positive number because it is supposed to force "f" to be close to "root2".
"a" and "b" might be very large numbers. Your choice of epsilon might yield a very large value for epsilon.
Compare this with the choice that I suggest for epsilon. Sure, (b-a)/4 might be large, but I could have chosen epsilon = (b-a)/x for any x>4 and the proof I suggest will still work. I could have chosen epsilon to be very small no matter what the value of a and b are. Your choice does not have this property.
I didn't work through the rest of your argument. Better that you should come up with a correct proof and then try to find the mistake in your old proof.
It's not so easy always to pinpoint another's mistake. And your doing it yourself would be a lot more profitable for you than me doing it for you.
One more hint to help you find a correct argument. Go back and look at what i called your "outline" for a proof in the spirit of what I am calling "Option 1." Your outline was correct.
DJ
[tex]a+\frac{\pi}{4}\left(b-a\right)[/tex]
I like Matt's idea more. But please bare with me once more while I try to fix my old proof (I know you recommended against this, but I think I have something simple that makes sense this time).
Let there be an interval I = [a,b], where both a and b are rational.
let x = root2
let f = a rational number
If we want to add f to root2 so that the result is in the interval, then we can say that
root2 + f < b
f < b - root2
we also know that:
root2 + f > a
f > a- root2
Therefore, f is a number in the following interval: a - root2 < f < b - root2
Now, since the "rational points are dense on the number axis" (quoting this from my book), this implies that there are an infinite amount of other rational numbers between (a - root2) and (b - root2), so there is no problem finding a value f that is between (a - root2) and (b - root2), that is rational, and as I have shown through the inequalities, can be added to root2 to yield an irrational number between any interval [a,b].
JG89, Sorry JG, this is taking too much time. I've got to pass the baton on to someone else. I noticed Maze just posted a real beaut. DJ
P.S. : "pass the 'baton'" as in a really race. "Baton" comes from the French. It is the French word for "stick." In english, we call the thing in a relay that is passed on, the "baton." The city Baton Rouge, Louisiana is (literally) "Red Stick, LA."
This result you're citing is arguably harder than the one you want to prove: you realize you're proving that the irrationals are dense in the reals too? There's nothing wrong with an elementary constructive proof, e.g. see maze's post.
So I've come across this thread while researching for my own homework assignment, and ya'll gave me an idea here... try this one on for size...
Let {a, b} exist in the rationals s.t. a < b
Prove that there exists an {x} in the irrationals s.t. a < x < b
First, I'm going to shift my interval by a magnitude of root2:
[a - root2 < b - root2]
Second, i apply the Denseness of Rationals Theorem (Between any two real, there exists a rational r):
because {a - root2} and {b - root2} are both real, i can state that there exists an {r} in the rationals s.t.
[a - root2 < r < b - root 2]
Third, I'm now going to shift my interval back to where it was originally:
[a < r + root 2 < b]
Therefore i have proven the existence of a rational + root2, namely {r + root2}, to exist inside my given interval. This is my {x}. All i need to do now is prove that a rational + root2 is irrational...
How about using the geometric mean. Given a,b rational a<b prove there exists c:a<c<b, and c irrational. (ab)1/2will always be between a, b. If ab are not squares then (ab)1/2 is irrational. But say a,b are squares then take the geometric mean of a and (ab)1/2. This is still between a and b and equals a3/4b1/4. If a or b are not fourth powers then a3/4b1/4 is irrational. But say that a and b are fourth powers, or greater powers. Say that the greatest power of a or b is k,that is, say a=uk then you can continue the process of repeatedly taking the geometric mean until you have a(2n-1)/2nb1/2n where 2n>k, then a(2n-1)/2nb1/2n will be irrational because it is an nth root of a less than nth power.
Those proofs seem very difficult to compared matt grimes/mazes idea. If we can show there exists some irrational number [itex]I \in (0,1)[/itex] then the theorem follows by the example [itex] a+ I(b-a)[/itex].
This is almost exactly how I proved in some time ago when i had this very problem for a homework assignment in an intro analysis class. Your last part is the easiest also: if a rational plus an irrational was a rational, how could we write the sum?
We demonstrate things in different ways to shed light on more abstruse aspects.
Prove that between any two rational numbers lies an irrationel number.
Proof
Let x,y be to rational numbers where x<y. By the Archimedian property there must exist a positive number n such that n*(y-x) > √(2). This we can rewrite
y-x > √(2)/n [itex]\Leftrightarrow[/itex]
y > x + √(2)/n
We then pick r to be r=x+√(2)/n
It is then clear that r < y and r > x (Since r is x+something), and r is an irrational number i.e x < r < y
q.e.d
This thread is way too old.
1. What is an irrational number?
An irrational number is a real number that cannot be expressed as a ratio of two integers. This means that it cannot be written as a fraction or a terminating or repeating decimal.
2. Can you give an example of an irrational number?
One example of an irrational number is pi (π), which is approximately 3.141592653589793. Other examples include the square root of 2 and the golden ratio.
3. How can you prove that there is always at least one irrational number between any two rational numbers?
This is known as the "density property" of real numbers. It can be proven using a proof by contradiction, assuming that there is no irrational number between two rational numbers and then arriving at a contradiction.
4. Is there a specific method for finding an irrational number between two rational numbers?
No, there is no specific method for finding an irrational number between two rational numbers. However, one way to approximate an irrational number is by using a decimal expansion or by using a computer program.
5. Why is it important to know that there is always at least one irrational number between any two rational numbers?
Knowing this fact helps us understand the concept of real numbers better and also has practical applications in fields such as mathematics, physics, and engineering. It also helps to reinforce the idea that there is an infinite amount of numbers between any two numbers.
  • General Math
  • General Math
