Is the group velocity necessarily slower than light (STL)?
In summary: From Jackson (page 319 in the second edition):"The general usage is to take the group velocity of the dominant frequency component as the signal velocity and velocity of transport. This suffices in most circumstances, but with sensitive enough detectors the signal velocity can evidently be pushed close to the velocity of light in vacuum, independent of the medium."
lalbatros
1,256
It is well known that phase velocities can be FTL (faster than light).
It is often said that group velocities cannot be FTL.
But I doubt this last one.
Starting from the Lienart-Wiechert delayed potential, what can be said for sure?
For sure a response to a step signal cannot be FTL.
But what about group velocity?
And what about "signals" generally speaking?
From classical (relativistic) physics, what can be precisely said about "signals" speed limitations?
And what is usually meant by a "signal"?
If, as I guess, group velocities can be FTL, I would appreciate some examples.
If, in some circumstances, group velocities cannot be FTL, I like to know more about the conditions.
I would like to become more precise about all these things.
Thanks for your suggestions.
Science news on Phys.org
GV can't be FTL. It is the velocity of a constructive interference from a group of waves, each wave traveling at c so the fastest possible GV is c. This holds for the observable universe.
If you would like to make up a system of waves that are faster than c, say 2c, then you could have a GV that is FTL in your made up system.
The standard formula for the group velocity is v_G=dw/dk.
This formula is derived as the first term in a Taylor series for w(k).
If the index of refraction is changing rapidly with frequency, this formula can give a v_G that is greater than c. But then the approximation that gave v_G breaks down, so that
dw/dk is not the velocity of a wave packet. Instead the wave packet breaks up.
It can be shown that the velocity of the front of the wave packet still cannot exceed
c in any case.
Do you mean that the concept of group velocity isn't well defined for rapidly changing refractive index?
clem said:
It can be shown that the velocity of the front of the wave packet still cannot exceed c in any case.
How? (Is the front just defined as the first point where the amplitude isn't exactly zero?)
Yes, and paradoxes arise if this is forgotten.
That is, the formula v_g=dw/dk still exists but it is not related to the speed of the packet.
The next derivative relates to the spread of the packet, and if the higher terms in the Taylor series are important, the packet distorts and breaks up.
Yes.
Note that in the NEC experiment from several years ago using an anomalous medium, the group velocity exceeded c considerably. Still, no part of the wave travels faster than c.
Zz.
Zz.
Greg Egan has written an applet that nicely illustrates this,
http://gregegan.customer.netspace.net.au/APPLETS/20/20.html.
Egan's pulse propagates without distortion because Egan has used a frequency dependence for the index of refraction that "is unlikely to hold true over a broad range of frequencies in any real medium, but it can be approximately correct for a limited range."
In Egan's example, speed of information is not the same as the group velocity. Interestingly, in real media, speed of information transfer is usually close to the speed of light even when the group velocity is less than the speed light.
What is group velocity?
Group velocity is the speed at which a group of waves or particles move through a medium. It is the average velocity of all the individual components within the group.
Is the group velocity always slower than the speed of light (STL)?
No, the group velocity can be equal to or even faster than the speed of light in certain mediums, such as in a vacuum or in some specialized materials like photonic crystals.
Why is the group velocity sometimes slower than STL?
This is due to the fact that the group velocity takes into account the average speed of all the individual components within the group. In some mediums, these individual components may have different velocities, causing the overall group velocity to be slower than the speed of light.
Can the group velocity be faster than STL in any medium?
Yes, in certain mediums, the group velocity can be faster than the speed of light. This is known as superluminal group velocity and is observed in some specialized materials like photonic crystals.
How does group velocity relate to the concept of faster-than-light travel?
The concept of faster-than-light travel is based on the idea of traveling at a speed faster than the speed of light in a vacuum. Group velocity, on the other hand, is a property of waves or particles in a medium. While the group velocity may be faster than the speed of light in some mediums, it does not violate the fundamental principle that nothing can travel faster than the speed of light in a vacuum.
  • Science Fiction and Fantasy Media
  • Optics
