How do physicists use redshift to determine the expansion of the universe?
In summary, most of the galaxies are moving away from our galaxy, and it is believed that the universe is expanding.
hitchiker
31
by measuring redshift physicist conclude
1.most of the galaxies are moving away from our galaxy
2.universe is expanding
if we ride alongside a train on a motorbike with relatively same speed , do we don't hear the doppler effect . it is effective if one is static
like wise our galaxy must be moving alongside or in line with other galaxies so shouldn't there be blueshift on the direction of our galaxy heading and redshift on opposite side, but we see redshift every where :confused:
how physicists concluded universe itself is expanding by judging the outward movement of galaxies :confused: universe is infinite ,isn't it? so how does universe expand .if space itself is expanding from a concentrated state stretching stuff within it, then one has to admit space is finite ,if space is infinite it must not be expanding.
if galaxies are moving away from each other ,well they are moving relative to each other but how does it prove space/universe is expanding
Astronomy news on Phys.org
There is, but only with galaxies close enough to us that the expansion of the universe is not the dominant source of redshift. For example, the Andromeda galaxy is highly blueshifted (for a galaxy) and is currently moving towards us. However, the overwhelming majority of galaxies are too far away to be bound to us and as a result the expansion is carrying them away and causing them to be redshifted. This expansion happens in all directions and affects everything. Everything in the universe that is not bound by gravity or another fundamental force is moving away from everything else.
A couple of things here. First and foremost, when we say that the universe is expanding, what we mean exactly is that objects within the universe are moving away from each other. That's it.
Second, even an infinite universe can expand. This may seem silly and counter-intuitive, but it is the truth. You are imagining the universe as a giant bubble or something related and that the universe itself is expanding into pre-existing space. This is not what we mean by expansion, nor is it required that something be outside the universe for it to expand into.
So, everything we see that is not bound to us is moving away from us due to expansion. Whether or not the universe is finite or infinite us currently unknown, yet either can be true and still be compatible with current models of cosmology.
hitchiker said:
... ,if space is infinite it must not be expanding.
Why do you say that if space is infinite it must not be expanding?
1. All of the galaxies in the local group are moving in the same general direction at a speed of about 600 km/s. There are additional peculiar motions of the individual galaxies, but, of lesser magnitude. Only the Andromeda galaxy is actually approaching the Milky Way - at the blistering speed of about 60 km/s. The are a few dwarf galaxies that are also blue shifted, but, are orbiting other larger galaxies so their blue shift is a temporary effect due to their orbital direction relative to the Milky Way.
The Hubble constant is about 70 km/s/Megaparsec. Assuming the velocity of the local group relative to the CMB [~600 km/s] is typical, it appears unlikely any galaxy more than about 9 Megaparsecs [~30 million light years] distant will ever be blueshifted.
2. The observable universe is definitely finite and has steadily increased in size for the last 13.7 billion years. Since, by definition, the observable universe is limited by the finite speed of light - it will forever be finite.
Is the pioneer anomaly in proportion to Hubble contant dividec by c ?
methinks there's something yet to be figured out about this apparent expansion, redshift, and all that...
I see absolutely no reason why the unobservable universe cannot be finite. Unobservability certainly doesn't preclude finiteness. It merely means that it is beyond our observation. For all we know the unobservable universe could be an exact replica of the observable one including the observable one's finiteness albeit larger. The real difference is that the unobservable universe's finitness might very well be a real one instead of one based on our inability to see beyond a certain point. Actually, saying that the visible universe is finite based on that reason is tantamount reaching conclusions about a land area' size because we can't see beyond a certain mountain range.
Not even close. The Hubble constant is only 70 m/s per Megaparsec. Our best guess for now is the pioneer anomaly is merely a thermal effect.
Radrook, keep in mind the unobservable universe is causally disconnected from the observable universe.
Interesting! Can you elaborate a little on that.
You can't observe anything older than the observable universe.
infinity is not an ongoing process, it is a fundamentality
Causality
Causality (also referred to as causation[1]) is the relationship between an event (the cause) and a second event (the effect), where the second event is understood as a consequence of the first.[2]
http://en.wikipedia.org/wiki/Causality
So how would observation be a causation?
I agree 100%! If it can be increased then it wasn't infinite to begin with. The infinitely large cannot be made larger because there is nothing larger than the infinitely large. The same holds true for the infinitely small. If indeed it can be smaller larger then it had spatial or numerical limits. Limits and infinity are mutually exclusive.
Infinity is a logical construct and yields logical contradiction when treated as if it possesses any physicality. Is the set of all integers more 'infinite' than the set of all even numbered integers? There are any number [an infinite number, to be precise] of calculus problems that use infinity as a limit, yet, yield a finite solution.
If light cannot reach us from the unobservable universe, then nothing can. Therefore, nothing we ever do can have any effect on the unobservable universe, and vice versa.
Are you familiar with Cantor's work on the cardinality of infinite sets? It is possible to construct infinite sets of different size.
It doesn’t have to for both universes to be causally connected. As the definition of causation shows, causal connection simply means that one universe would need to affect the other in a cause and effect manner. Does the visible universe do anything that affects the invisible one in a cause-effect manner? well, please note that it feeds matter to the other making it larger in the process. Also note that such matter can be assumed to interact causally with whatever it encounters on the other side of the boundary that separates one from the other from a human perspective.
BTW
I agree that humans are causally disconnected from that universe. But that doesn't justify a blanket statement that would imply that both universes are causally disconnected.
I don't believe matter is being fed from the observable universe to the unobservable universe.
BTW
The border isn't a brick wall, its a barrier in time. Anything beyond that barrier CANNOT affect us yet. Objects just on the other side can and have been affecting objects on our side, we just haven't been able to observe this effect yet. Therefor we are not causally connected to it yet.
Where is it all going from your standpoint then-tra la la land?
I never said that we are causally connected as human beings to anything that happens beyond that horizon. I never said that the horizon blocks all influences between these regions. Your misunderstanding is that you are focusing on people in relation to that horizon and I am talking about the two distinct regions themselves in relation to one another and people are totally irrelevant from the point of causality between these two areas.
Radrook said:
1.Your last statement is self-contradictry and and places in serious doubt the reasoning ability of anyone who would express it. Are you aware of that or are you just jesting?
2. I never said that WE are causally connected as human beings to anything that happens beyond that horizon. Actually, and on second thought, after reviewing your blatantly self- contradictry statements , I decided that as far as I am concerned this discussion between us is over. Maybe when the arguments you present begin making at least a little bit of sense to me we might resume. Until then, no dice! This type of communication is extremely disagreeable. Yikes!
Your statements are confrontational and rude, Radrook. Drakkith is merely trying to engage in constructive discourse (the brick wall reference I'm sure was meant facetiously, as I know Drakkith to be a thoughtful commenter.) I'll advise you to read the PF rules on this kind of attitude -- this is a place to learn, not pick fights.
If we look back to z=6, we see galaxies as they were when the universe was about a billion years old. Those same galaxies can be seen from the other side at the same redshift by astronomers in galaxies far beyond our horizon. Thus can it not be said that parts of what we call the "observable universe" are causally connected to events we call "unobservable".
Yes, it can. And it IS. Correctly.
Amounts of the universe beyond our current horizon WERE causally connected in the early universe (read about the CMB uniformity) but they are NOT at present.
redshift varies with distance, if you mean astronomers in galaxies that lies in our 'forward horizon' redshift would be much greater
it is like driving a car on highway.. horizon in front of you will become connected and rear horizon shrinks
we may never see more past as we can see now ,as everything is moving away from its origin forward
I am talking of astronomers in a galaxy who observe the universe to be 13.7 billion years old as we do and at a co-moving distance of 57.5 billion light years from us. Call it "C".
The galaxy in the young universe, seen at a redshift of 7 by both the distant galaxy and us, is midway between C and us, call it "B". The causal connection from B to C is similar to that from B to us even though we consider B is observable but C is not.
Yes, that's correct. Are you asking if the statement quoted here makes sense, or what?
EDIT: This response is based on "half-way". I did not consider the red-shift and I assume that hitchiker's comment below on the red shift is correct.
redshift 7 is within 14bly which is not halfway between C and us in your example
I was giving a counter-example to message #8 in this thread, posted by Chronos.
(Note that #8 is not equivalent to post #10, the latter is valid.)
Ned Wright's cosmology calculator is very useful:
http://www.astro.ucla.edu/~wright/CosmoCalc.html
Put in z=7 then press "flat". It will tell you that the comoving distance is 28.756 Gly. That's how far away the galaxy we can see is now.
I should perhaps clarify that what I mean by now is at a time in the history of the galaxy when the age of the universe determined from the CMBR is 13.7 billion years.
The page also tells you that the angular size distance is 3.5945 Gly. In a flat universe, that is how far away the galaxy was when the light was emitted (at that time, the age of the universe was 778 million years).
3.5945 * (z+1) = 28.756
Another galaxy equally far beyond it would also see that one at a redshift of 7 and would now be at a distance of 57.512 Gly.
Next, put in z=1089 which is the redshift of the surface from which we receive the CMBR and press "flat". The comoving distance is 45.647 Gly. That is the current location of the most distant matter we can see which is a fair candidate for being "the edge of the observable universe".
Sorry if I was too economical in my previous posts, hopefully this makes it clearer.
I like this view of time. Everyone, everywhere would measure the age of the CMBR to be the same correct?
thanks,
my calculation was wrong
  • #31
But, is there such thing as infinite in physics?
  • #32
only one thing is infinite, that is universe...the emptiness
physics is to deal with singularities like matter energy stuff like that which spawned out of nowhere in the emptiness
Bigger picture of universe go beyond physics
  • #34
FAQ: How do physicists use redshift to determine the expansion of the universe?
1. How does redshift provide evidence for the expansion of the universe?
Redshift is a phenomenon observed in light from distant galaxies, where the wavelength of the light is stretched or "shifted" towards the red end of the spectrum. This is due to the expansion of the universe, which causes the space between galaxies to increase, stretching the light as it travels. The amount of redshift observed in light from distant galaxies can be used to determine the rate of expansion of the universe.
2. What is the relationship between redshift and the distance of galaxies?
According to Hubble's Law, there is a linear relationship between the redshift of a galaxy and its distance from Earth. This means that the further away a galaxy is, the greater its redshift will be. This relationship is a key factor in using redshift to determine the expansion of the universe.
3. How do physicists measure redshift?
Redshift is measured using a device called a spectroscope, which separates light into its component wavelengths. By comparing the observed wavelengths of light from a distant galaxy to the expected wavelengths, physicists can determine the amount of redshift and therefore the galaxy's distance and rate of expansion.
4. Can redshift be used to measure the expansion of the universe in all directions?
Yes, redshift can be observed in light from galaxies in all directions. This is because the expansion of the universe is happening in all directions, causing the light from all galaxies to be stretched as it travels towards Earth. However, the amount of redshift may vary depending on the direction and distance of the galaxy.
5. Are there any limitations to using redshift to determine the expansion of the universe?
While redshift is a useful tool for measuring the expansion of the universe, there are some limitations to its accuracy. For example, the presence of dark matter and dark energy can affect the amount of redshift observed in light from distant galaxies. Additionally, the accuracy of redshift measurements may be affected by the distance and orientation of the galaxy being observed.
11K
