Titled reference frame, N2L with position and velocity
In summary: sorry, the equation for y is?' y= tan(\phi)x= (sin(\phi)/cos(\phi))x ' is because when you graphed the equation for x, it looks like a parabola.
  • #36
dx = vocos[tex]\vartheta[/tex]t + (1/2)(-g)t^2sin[tex]\phi[/tex]
dy = vosin[tex]\vartheta[/tex]t + (1/2)(-g)t^2cos[tex]\phi[/tex]
  • #37
i have a feeling this is wrong for dy...
  • #38
Looks right to me. So now you want to find the range...
  • #39
range?
  • #40
Oblio said:
range?
the question asks for the range...
  • #41
which is really just the displacement up the plane?
  • #42
yes, maximum displacement... the object is thrown at an angle, then hits the incline eventually... the displacement up the plane when it hits is the range...
  • #43
is this the same kinematics equation?
  • #44
use these equations to find dx when dy = 0... that gives the range.
  • #45
solve for... vo? and insert into dx?
  • #46
no, you want to eliminate t... so solve for t and substitute into dx.
  • #47
without simplifying yet..
dx = vocos (theta) (vosin (theta) / (-1/2)gsin(phi)) + (1/2)(-g)cos(phi)((vosin(theta)/(-1/2)gsin)^2)
ya?
  • #48
ya?
hmm... close but some mistakes... can you post what you got for t?
  • #49
t = vosin(theta) / (-1/2)gsin(phi)
  • #50
setting dy = 0, and solving for t will give you something different... it should be cos(phi) and the - shouldn't be there.
  • #51
oops! little pen and ink mistake over here..
t = vosin(theta) / (1/2)gcos(phi)
yep!
  • #52
yep!
cool. plugging that into dx should work.
  • #53
dx = vocos(theta)vosin(theta)/(1/2)gcos(phi) - (1/2)gsin(phi)vosin(theta)/(1/2)gcos(phi)
  • #54
you missed t^2... didn't square t.
  • #55
oops.
man I am bad..
  • #56
dx = vocos(theta)vosin(theta)/(1/2)gcos(phi) - (1/2)gsin(phi)(vosin(theta)/(1/2)gcos(phi))^2
on the right side i can cancel out the (1/2) on the bottom and top, as well as the g, giving,
dx = vocos(theta)vosin(theta)/(1/2)gcos(phi) - sin(phi)(vosin(theta)/cos(phi))^2
  • #57
careful the 1/2 and g are squared...
  • #58
oops again.
so I am left with
dx = vocos(theta)vosin(theta)/(1/2)gcos(phi) - sin(phi)(vo^2 sin(theta) ^2 / (1/2) g (cos(phi)^2)
  • #59
Oblio said:
oops again.
so I am left with
Looks good... try to simplify and use a trig identity to get it to look like the formula they gave for the range...
  • #60
will trig identities apply since theta and phi are present?
  • #61
im confused how one would ever get, for example : cos (theta + phi) through simplifying
  • #62
try a little factoring of your equation also... look up the identity for cos(A+B)...
  • #63
i found that cos (a+b) = cosacosb +/- sinasinb... but i don't have that relationship anywhere
  • #64
first write everything over 1 denominator... then compare what you have to the formula you need to get... a little factoring will give you the answer.
  • #65
k I am at
dx= vo^2sin(theta)*(cos(theta)-sin(phi)) / (1/2)cos(phi)^2(sin(theta))
  • #66
Oblio said:
k I am at
factoring out the sin(theta) was correct... but you made a mistake somewhere...
  • #67
i can't factor out a vo^2?
  • #68
yes you can... I was referring to the sin's cos's... check your work... your denominator should only have [cos(phi)]^2
  • #69
i edited that in by mistake. i meant to put that in the numerator.
dx= vo^2sin(theta)*(cos(theta)-sin(phi)sin(theta) / (1/2)gcos(phi)^2
  • #70
almost there... should be cos(theta)cos(phi) in the numerator... I think you forgot to multiply the top by cos(phi) when putting everything over 1 denominator.
