What Is the Maximum Horizontal Force to Apply Without the Upper Block Slipping?
  • Thread starter barthayn
In summary: The top box cannot have a force higher than 1.715 N and the bottom box has to overcome 2.95 N of friction. Therefore, to have a maximum force that the top box will not fall will be both frictional forces added together. The top box will have a constant speed of 0 m/s while the bottom box will be accelerating at 1.14m/s/s. I truly, so not see where you are getting at with the top box is moving at constant speed. The top box is sliding on the bottom box, together they are moving. The top box is moving with respect to the ground, so it has a kinetic friction. The bottom box has static friction with the top box and kinetic friction
barthayn
87
A 0.5kg wooden block is placed on top of a 1.0kg block. The coefficient of static friction between the two blocks is 0.35. The coefficient of kinetic friction between the lower block and the level table is 0.20. What is the maximum horizontal force that can be applied to the lower block without the upper block slipping?
FNET = ma = 0
FK = 1.5 * 9.8 * 0.20
FK = 2.94 N
FS = 0.5 * 9.8 * 0.35
FS = 1.715
FNET = FS = FA - FFK
1.715 N = FA - 2.95 N
1.715 N + 2.95 N = FA
4.655 N = FA
4.7 N = FA
Therefore, the maximum horizontal force that can be applied is 4.7 N without the upper, 0.5 kg, block moving.
Is this correct?
yup, assuming you did your math right.
If I understand well, you calculated the force which would move the boxes with constant velocity. The question was to find the maximum force applied so as the two boxes move together, which means the same velocity and acceleration.
ehild
ehild
I think that's why he/she added the 1.715 N, this is so that two boxes move together with same velocity AND acceleration
The horizontal forces acting at the lower box are:
F, to the right;
The kinetic friction between the lower bock and the ground Fk, on the left;
The force of static friction between the boxes, Fs , on the left.
The resultant force is F-Fk-Fs=F-2.94-1.715 N. If F= 4.655, the resultant force on the lower box is zero, so it does not accelerate.
This applied force is the minimum that keeps the boxes in motion with constant velocity.
F, to the right;
Ah, absolutely 4.655 isn't the maximum. I should really be careful when I look at these late at night.. *angry face* :/. F needs to be maximized such that the top box doesn't fall off.
The maximum acceleration so that the top box doesn't fall of is: 1.715 N = 0.5 kg * a, then use that a for Fnet= ma= F-2.94-1.715 N. Careful what m is.
sorry about that.
F, to the right;
How would this be the minimum force that keeps the boxes in motion with a constant velocity? Wouldn't it be the frictional force of the lower block? The answer I got was for the upper block not to move on top of the lower block. Therefore, in order to overcome the bottom frictional force and not overcome the top I had to add both of the frictional forces together to get the maximum force. This should be the maximum force because if you subtract the applied force by the kinetic frictional force you will get the static frictional force.
Yes, that force, 4.665 N is equal to the net frictional force on the lower box. What is the acceleration of that box then?
ehild
ehild
The acceleration of the whole system is 3.10 m/s/s. So, my maximum applied force is correct?
You said that the maximum static friction on the 0.5 kg box is 1.715 N. This allows 3.43 m/s^2 acceleration. How did you get that 3.1 m/s^2?
ehild
I'm guessing that should be 3.43m/s^2? Rounding error perhaps? How did you get this?
Now [tex] ma_{net}= F - F_k -F_s [/tex], remember you are applying the force on the lower box, so you should know what the value of m is from that.
**edit:
Ok i see how you got 3.10. You did 4.655/1.5; however, you are forgetting the two frictional force on the lower box that's in the opposite direction of F, which also has a total magnitude of 4.655. Hence, the net acceleration is 0 if the applied force is 4.655N. Does that make sense?
**edit:
No, it doesn't make sense. The top box cannot have a force higher than 1.715 N and the bottom box has to overcome 2.95 N of friction. Therefore, to have a maximum force that the top box will not fall will be both frictional forces added together. The top box will have a constant speed of 0 m/s while the bottom box will be accelerating at 1.14m/s/s.
I truly, so not see where you are getting at with your answer. I am completely confused. :grumpy:
Ok, before I attempt to explain it again.. I'll try to show the flaw in your logic (bear with me here).
"The top box cannot have a force higher than 1.715" - this is true
"the bottom box has to overcome 2.95 N" - This is not true. Draw your free-body diagram for the lower box, and you will see that there is not only the kinetic frictional force of 2.95, but an additional frictional force due to the top box in the opposite direction to F <--- This is key!
"The top box will have a constant speed of 0 m/s while the bottom box will be accelerating at 1.14m/s/s. " -This is obviously not true. How could the top box have constant (or 0 m/s) speed while the bottom one is accelerating? They need to be moving(accelerating) in unison.
Edit:
Here are a couple of things that might help you understand the problem better:
1. Draw out the free body diagrams carefully (paste it here if you want)
2. Consider what is actually moving the top box (The frictional force is moving the box and its pointing in the direction of its motion. This might seem contradictory at first at first)
What is the concept of "Two boxes on each other"?
The concept of "Two boxes on each other" refers to a scenario where two boxes are stacked on top of each other, with the bottom box supporting the weight of the top box.
What is the purpose of stacking two boxes on each other?
The purpose of stacking two boxes on each other can vary, but it is often used for storage or transportation purposes. By stacking boxes, more items can be stored or transported in a smaller space.
What factors determine the stability of two boxes stacked on each other?
The stability of two boxes stacked on each other is determined by several factors, including the weight and size of the boxes, the placement of the boxes, and the strength and condition of the boxes themselves.
What precautions should be taken when stacking two boxes on each other?
When stacking two boxes on each other, it is important to evenly distribute the weight between the boxes, as well as to ensure that the bottom box is sturdy enough to support the weight of the top box. Additionally, caution should be taken when stacking boxes too high, as this can increase the risk of them toppling over.
What are some potential risks associated with stacking two boxes on each other?
Some potential risks associated with stacking two boxes on each other include the boxes toppling over, causing injury or damage, and the boxes becoming damaged due to the weight or pressure being placed on them. It is important to take precautions and use proper techniques when stacking boxes to avoid these risks.
12K
