Coletrain12
- 16
A proton has mass 1.7x10-27 kg. What is the magnitude of the impulse required in the direction of motion to increase its speed from 0.995c to 0.998c? Where c is the speed of light.
Im not quite sure of what equation is supposed to be used. I tried using (momentumfinal)=(momentuminitial) + Fnet*(changeintime)
Ok my attempt at the problem is the only way i can think of it and the answer is still wrong. I first multiplied the speeds by the mass to get a momentum. Then used the two momentums and plugged them into the equation above and solved for Fnet*(changintime) which equals Impulse if I am not mistaken. I got the number 1.53e-21 for my answer.
The only problems i can think of is maybe those speeds are speeds(needs to be velocity).. and can't multiply by the mass to get a momentum but i don't see why that would cause a problem. Overall I am stumped on this problem and not sure why what I've done doesn't work. I even have talked to others in the class and no one can figure it out.
Thanks for all the help in advance guys.
