Coefficient of friction and static friction
In summary: In most cases, the coefficients of friction are approximately the same. However, there are cases where the coefficient of static friction is higher. This happens when the surfaces of the two materials are rough.
p.tryon
51
If an object slides down a slope at a constant speed is the coefficient of static friction the same as the coefficient of dynamic friction? If yes, is this true in every situation?
I'm afriad that I don't understand the question. Static friction occurs when two bodies are stationary relative to each other, whereas kinetic friction occurs when the two bodies are in relative motion.
When two bodies moving relative to each other are in contact, there is said to be no static friction.
Imagine a box of weight W sliding at a constant speed down a slope at an angle of 45 degrees. Imagine the same box at rest on the same slope. The two types of friction are different (static and kinetic) and the two coefficients of friction should be different (or should they?)
According to the following calculations they are the same
From here on:
Coefficient of friction C
Frictional force F
Normal Force Fn
F = C.Fn
Therefore
C = F / Fn
1. At rest:
F = WSin45 and Fn = Wcos45
Therefore
C = WSin45 / Wcos45
2. Sliding at a constant speed:
Since F is equal to the opposite component of gravity (WSin45) - Newton's first law! the equation and therefore answer is exactly the same for the coefficient of dynamic friction:
C = WSIn45 / Wcos45
In general, they would be different.
From here on:
Frictional force F
Normal Force Fn
F = C.Fn
Therefore
C = F / Fn
The relationship F = μN is only true for kinetic friction.
For static friction, μN represents the maximum value, so F ≤ μN. Big difference!
This would only imply that the slope angle and coefficient of dynamic friction were "balanced" such that they resulted in equal and opposing forces from gravity and dynamic friction (therefore no acceleration), and that dynamic friction was independent of speed within the speed range experienced, excluding a speed of zero. The constant speed (not including zero speed) case occurs when tan(slope angle) = coefficient of dynamic friction.
If the speed were zero, then the friction would be due to a normally higher coeffcient of static (than dynamic) friction, and the slope could be increased without the box moving. If the box was pushed, then the box would accelerate down the steeper slope instead of sliding at constant speed.
There are pairs of surfaces where static and dynamic friction are about the same, such as teflon on teflon.
What is the coefficient of friction?
The coefficient of friction is a dimensionless quantity that represents the amount of resistance between two surfaces in contact with each other. It is calculated by dividing the force required to move one surface over the other by the weight of the object.
How is the coefficient of friction measured?
The coefficient of friction is typically measured by conducting experiments in which one surface is placed on top of the other and a force is applied to move the top surface. The resulting force required to move the surface is then divided by the weight of the object to determine the coefficient of friction.
What is static friction?
Static friction is the force that prevents two surfaces from sliding past each other when there is no external force acting upon them. It is a type of friction that occurs when two surfaces are in contact but not yet moving.
What factors affect the coefficient of friction?
The coefficient of friction is influenced by several factors, including the roughness of the surfaces in contact, the pressure between the surfaces, and the materials the surfaces are made of. Additionally, the presence of any lubricants or contaminants can also impact the coefficient of friction.
How does the coefficient of friction affect motion?
The coefficient of friction plays a crucial role in determining the amount of force needed to move an object over a surface. A higher coefficient of friction means more force is required to move an object, while a lower coefficient of friction means less force is needed. It also affects the speed and efficiency of an object's motion.
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanics
