Is it Possible to Travel Faster than the Speed of Light?
In summary, the conversation discusses a hypothetical scenario of two individuals traveling at .75 times the speed of light towards a sign. The conversation delves into the logic behind the scenario, with one individual arguing that the other must be traveling at a faster speed based on the observed distance between them and the sign. However, the other individual explains that this is not how relative velocities work and that the fastest the other individual could possibly be closing with the sign is less than 0.25 times the speed of light. The conversation also touches on the topic of relativity and the importance of logic in understanding it.
  • #141
Doc Al said:
From the ground frame only, the closing speed is 1.5c.
You are switching frames all over the place.
I am not switching frames AT ALL. THERE IS NO OTHER FRAME involved. What other frame are you thinking of??
  • #142
James S Saint said:
From the frame of either observer, the distance of 2Ls vanished in 1.333secs = 1.5c
There is no "stationary".
There is stationary when you're talking in the context of a single frame.
  • #143
James S Saint said:
The time dilation involved at merely .75c is minuscule to the 1.5c measurement realized. Neither travelers clock would slow by 25%.
The 'time dilation' factor at 0.75c is about 1.5 (not minuscule), but it has nothing to do with the 1.5c closing speed. At .96c, the relative speed of the moving ships, the time dilation factor is even greater: about 3.6.
  • #144
James S Saint said:
The theory concerns the ability to observe anything travleing faster than light. It is irrelevant as to whether anything actually was with respect to some absolute frame, because it is accepted that no absolute frame exists.
The ONLY frames that have any observer are the travelers. But the travelers make no measurement as they travel, they merely measure before and after and conclude a speed of 1.5c. There is no one else there to tell them how it occurred, thus THEY must perceive a 1.5c occurrence.
If the only measurements they make are before and after then the only measurements they actually have are there own times for their own travel from beginning to end. They have no observations of any kind regarding the other system while in motion. Therefore they can only derive their own velocity of .75c from actual observation.
You do understand that the observations from ground observers, if any , of 1.5 c closing speed has no physical meaning I hope?
  • #145
You seem to want to state that the speed of one ship in the moving frame of the other is somehow 1.5c. Not so.
If you stay in the ground frame, then there's no problem. The ships move at 0.75c and they close at 1.5c. Done!
  • #146
jcsd said:
Stick to measurements tkaen in the same frame. The distance and time measured byu a gorund based observer is not the distance and time measured by our two traveling observers.
Relatvity is specifically constructed so that an object traveling at c travels at c in all inertial frames. One of the side effects of this is that objects traveling at less than c in some inertial frame always appear to be traveling at less than c in all other inertial frames.
You seemed to have missed a point somewhere. The only measurements made are in the "initial/ground" frame.
The measurement is made of 2Ls at t(0), travel is made. When they meet, they stop and look at their clocks. Both clocks read that they traveled for 1.333secs.
All measurements are from the initial frame.
  • #147
Wrong. Look at the diagram. The time elapsed on the worldline clock is simple to calculate.
  • #148
There are 3 frames involved here, the ground frame and the frame of each observer. Don't let the symmetry of the situation fool you these are 3 very distinct frames.
  • #149
There is no measuring going on as they move. They take ALL measurements together at the beginning and end while they were not moving with respect to each other. Thus there is no frame changing involved in any measuring. But from the PERSPECTIVE of each, the other seems to have come to them at 1.5c.
  • #150
Okay, but in the ground frame, neither of the travellers is traveling at greater than c. We started by specifying that each was traveling at 0.75 C in opposite directions in that frame.
We cannot apply measurements made in one frame to another, so in order to work out what was going on in the other frames we'd either need to take new measurements in those frames or alternatively use the Lorentz transformation to convert our previous measurements into the other frames. And lo and behold when we do this we find that neither traveller obserevrs the other traveling at greater than c.
  • #151
The worldline clock?
They each have a clock of their own. Both clocks measure 1.333secs. They have to use their own clocks as it is an issue of what they each observe for themselves.
  • #152
The only frames that matter are the ones used to measure. Only one is used to measure anything.. and everything.
  • #153
If both observers start from not moving then they must've accelerated, even if we assume that acceleration is instantaneous they are not inertial observers. In this case it is the travellers themselves who are changing between inertial frames and what has been said so far only applies for inertial frames.
  • #154
But see above, this is not an inertial frame. Rather it is two inertial frames 'stictched' together.
  • #155
When they meet, they stop and look at the clocks that were at rest in the ground frame all along. Not the clocks that were moving along with the ships. Their ship clocks would not agree with those measurements.
  • #156
There
Are
No
Other
Frames that are used.
  • #157
But they make no measurement as they move. Frames only matter to the measurements involved. Both measurements are made from the same initial frame.
  • #158
Can you explain how it is not an "inertial frame" without presuming an absolute frame?
  • #159
It is not. Here, I'll do the calculation for you!
Distance to sign in ship frame: 1Ls/(γ(.75c))=1Ls/1.5=0.66Ls
Time until arrival at sign: 0.66Ls/0.75c=0.88s
From a spacetime diagram you can see that A will observe B to be 0.19Ls away from the sigs when the race starts.
Since they arrive at the same time, B is traveling at 0.19Ls/0.88s=0.21c wrt the sign, giving a relative speed of 0.96c to A. The same result is found by Lorentz velocity addition.
  • #160
And they each have a worldline, so we're saying the same thing. I can't explain any better why you're wrong. If we start with the velocites defined in the ground ( signpost ) frame, then you will see your twin approaching at 0.96c, not 1.5c. As has been said many times - 1.5c is not the velocity of anything in this scenario. The signpost observer is adding two velocites, but it's not what is observed by you or your twin or from any frame.
I'll leave you to it now.
  • #161
In which case allmeasurements are made in the gorund frame, but as I said earlier we started by stating that in this frame both observers we're traveling at 0.75 c (in opposite directions).
What you've done is construct an eccentric frame from an obserevrr who undergoes two bouts of instaneous acceleration. The coordinate time in this frame (as measured by you) does not even correspond to the proper time experinced by the observer, it's the time experinced in the ground frame.
I wouldn't even call that a non-inertial frame, I'd just call it some sort of parameterization.
  • #162
Ok, so what would their ship clocks read if we secretly knew that they were traveling at .75c with respect to their initial frame?
  • #163
If you see your brother off in the distance 2ls away, and you want to meet up at a clock half way between you, you can get there in a time less than 2s (according to that clock) no problem, because it is only 1ls away. The only way to BOTH meet up there is to BOTH accelerate towards the clock. Any problem with that? The only measurements made are made in the initial ground frame.
  • #164
In special relativity velocities are relative, but accelerations are not. The value of an accleartion can change from frame to frame, but an object is either accelerating or it isn't.
  • #165
The clock on the ground would read 1.333secs. And they could easily just look over at that one rather than their own, but I'm curious.
  • #166
Consider Gallilean relativity in that velocities are also relative, whilst accelerations are not.
  • #167
The problem with using a centered clock is that it gives clue to the travelers. If perhaps we strung 10,000 clocks across the flight path (the ground), they would read the 1.333secs, no matter which clock they stopped at and not know that they had each traveled the same distance.
But even if they use their own clocks, I think you will find that their time dilation doesn't make up the difference.
  • #168
Even if you use a ground clock, so all of your measurements really did come from one frame, you'd still come to the conclusion everyone keeps telling you: according to the ground measurements, the closing speed between the two ships was 1.5c. If you come to the incorrect conclusion that someone must have moved at 1.5c from that, then it's your own fault for not having enough data and for not thinking, "Hm, I guess both moved at .75c."
Relativity only says that you won't see someone coming at you at >c. That's it. It doesn't say that you can't take measurements in the ground frame, move toward each other, and then conclude that the closing speed was >c. If all the measurements are from the ground frame, then we get a result according to the ground frame. This result isn't anything special.
  • #169
Emm.. that doesn't seem to ring true. An acceleration is merely the rate of change of a velocity thus if the velocity was changing relative to two parties, the acceleration would have the opportunity to change. It wouldn't have to be different.
  • #170
"Seeing" IS taking measurements. No one ever actually sees light travel at all. When we say "observe travel" we MEAN "by the measurements". The only measurements are saying that a distance of 2Ls vanished in 1.333 secs. Now it is speculated that the travelers clocks will read different than a ground clock. So what will their clocks read.
We ONLY care about what is apparent to the travelers at the end of the travel, not during.
  • #171
That was already answered multiple times. For example, post #24: The moving ship would measure the time to reach the sign to be about 0.88 s.
And that speed is hardly a secret; you used it to set up the problem.
  • #172
Now it is speculated that the travelers clocks will read different than the ground clock. So what will their clocks read.
170 posts in and you finally realize that the travellers' clocks will disagree with the ground clock. Landmark. You've been told how to calculate the time on the travellers clocks.
Reading off the first graph I get tau = 0.937 s.
  • #173
See, what relativity forbids is for you to measure your brother as coming towards you faster than light while you're traveling towards each other. You're not taking measurements when this happens, thus relativity isn't being violated. All of your measurements are coming from the ground frame, so you get a ground frame result. According to that frame, the closing speed is allowed to be 1.5c. There is no problem. You seem to think this goes against relativity, but it doesn't.
  • #174
Draw a straiggtht line (assume length doesn't enter into it as you can always extend a straight line), you can rotate and translate that straight line into any other startight line. Now draw a curve that isn't a straight line, you cannot rotate and translate that curve into any other curve without deforming it. You cannot roate and translate that curve into any otherb curve.
The straight lines and curves we're talking about here are the worldines of observers on a spacetime diagram, the staright lines are inertial obserevers, the curves that are not staright lines are the non-inertial observers.
  • #175
Post #24 doesn't say anything about the time of the travelers clock. I have been watching for that.
Now, what equation did you use to claim that the time dilation caused a 1.333 time to be reduced to .88? That is like 33% reduction.
Secret from the travelers, NN. :rolleyes:
