Calculate when displacement are equal
In summary: Then, while the first stone falls for say 1 second, the the second stone would fall for 1 + 0.5 seconds. That's just not correct.
ahmedb
One stone is dropped from the the top of a tall cliff, and a second stone with the same mass is thrown vertically from the same cliff with a velocity of 10.0 m/s [down], 0.50seconds after the first. Calculate the distance below the top of the cliff at which the second stone overtakes the first?
v=0
d= -1/2(a)(t)^2
v=10
d=10(t)-1/2(a)(t)^2
we have two unknowns, how can we solve it??
v=0
d= -1/2(a)(t)^2
v=10
d=10(t)-1/2(a)(t)^2
The time in this equation should be (t - 0.50), if t is the time in the previous equation .
Two equations in two unknowns.
i still don't get the answer, can you explain the steps please
First rewrite the second equation,
d=10(t)-1/2(a)(t)2 ,
using (t - 0.5) in place of t. (This is because the second stone is in the air for 1/2 second less time than the first stone.)
Then "FOIL" the (t - 0.5)2, multiply out everything in the expression and then collect terms.
See what you have then.
so after you foil, you make the displacement equal to each other, and then solve for t, and then plug "T" into the original equation?
ahmedb said:
so after you foil, you make the displacement equal to each other, and then solve for t, and then plug "t" into the original equation?
Yes.
SammyS said:
Yes.
can you also do: d= -1/2(a)(t+.5)^2
cas the ffirst stone is .5 seconds in air longer than the second stone
You can do either
t for the first stone and (t - 0.5) for the second stone,
OR
(t - 0.5) for the first stone and t for the second stone,
but not both (t + 0.5) and (t - 0.5).
SammyS said:
You can do either
OR
don't you mean "t for the first stone and (t "+" 0.5) for the second stone,"?
No. No matter how you express the time for each stone the time for the second stone is always 0.5 s less than the time for the first stone.
Therefore, the time for the first stone is always 0.5 s more than the time for the second stone.
for that cas the time for the first one is 5 less than the time for the second stone.
so is this correct "(t + 0.5) for the first stone and t for the second stone,"?
ohh lol, now i get it, thanks :D
What is the concept of displacement?
Displacement is the distance and direction of an object's change in position from its starting point.
Why is it important to calculate when displacement are equal?
Calculating when displacement are equal can help determine the point where two objects meet or cross paths, which can be useful in predicting collisions or interactions between objects.
How do you calculate when displacement are equal?
To calculate when displacement are equal, you need to set the two displacement equations equal to each other and solve for the variable. This will give you the point where the two displacement values are equal.
What is the formula for displacement?
The formula for displacement is final position minus initial position, or Δx = xf - xi. This calculates the change in position of an object.
Can displacement ever be negative?
Yes, displacement can be negative if the final position is less than the initial position. This indicates that the object has moved in the opposite direction from its starting point.
