Why aren't all overtones integer multiples of the fundamental?
In summary, when plucking a string on an instrument, not all overtones are produced by the string itself and many are generated by the instrument itself. Plucking the string without muting the others can make a significant difference in sound, depending on the instrument and the note being played. The overtones are not always integer multiples of the fundamental frequency due to the string's stiffness and the effects of resonance from other strings.
cscott
782
When plucking a string on an instrument, are all the overtones heard produced by the string itself (assuming all other strings are muted)? Would plucking the string without muting the others make a significant different? Another thing, why aren't all overtones integer multiples of the fundamental?
Thanks.
Because real-world strings aren't idealized strings.
No. Not all are heard, and many of the overtones are produced by the instrument itself; this is one reason why a cello sounds different to a banjo, for instance.
'Significant' here isn't really quantifiable. I can hear the difference between a plucked string with the others open, compared with a plucked string with the others muted, on a guitar. Some people might not be able to. It also depends which note is being plucked; if you pluck the bottom E on a guitar, it will cause the top E to resonate too. Same with a piano, except there are a lot more strings to set in motion.
Just to be sure, you are aware that the usual scales are essentially exponential in frequency? I.e., the 2nd harmonic (at the 12th) is in fact an integer multiple - thrice the frequency of the fundamental, or 1/3 the wavelength. The pure harmonics are all at integer multiples of the fundamental frequency.
we would call that the "3rd harmonic". some might called it the "2nd overtone" or "partial". but it's a pretty solid convention that the "1st harmonic" is the fundamental.
true, but not perfectly true. when we use the term "harmonic" we mean an overtone or partial with instantaneous frequency that is virtually an integer multiple of the fundamental frequency at the same instant of time. but in "quasi-periodic" tones, the phases of the harmonics (relative to the fundamental) might well be changing in time (as well as the amplitude) which will detune them slightly from their perfect harmonic frequency value.
"partial" means any sinusoidal component of a tone (including possible subharmonics) and "overtone" means a partial with frequency that is higher than the frequency perceived to be the pitch (which is usually the fundamental). "harmonic" means any sinusoidal component with instantaneous frequency that is virtually equal to an integer times the fundamental frequency.
you can look up "Additive synthesis" at wikipedia to get a little more.
The stiffness of the string causes overtones to be slightly sharper (higher frequency). Please see page 4 of
"[URL
That document is about piano but the same principle should apply to all string instruments.
Wai Wong
for most stringed instruments, the string generates very little sound on it's on. It's purpose is to vibrate the instrument, like the sound board on a guitar or the frame of a piano. In the case of an electric guitar, the pickups sense the vibration of a string and this electronic waveform is amplified. In the case of a midi guitar, a pulse is sent through the string and back (at the pickup end), and is timed to determine the desired frequency, the actual string frequency is ignored in this case.
Wow, thanks alot. That cleared up every freaking misconception I had :P
Guitarist Point of view
I'm an amateur with physics, but an expert on guitars. The main reason that a guitar string sounds different if the other strings are muted is simply that unmuted strings are resonating, which apart from possible mathemtaical models for estimating the results, is just a fancy way of saying that every action has an equal and opposite reaction. Vibrating molecules that bump the other strings will cause them in turn to vibrate, primarily at their own tuned note, thus they in turn create their own sound vibrations. Incidentally, some modern virtual instrument synthesizers, especially grand piano samplers, add the reasonant sounds of other strings to the note played in order to more accurately simulate the real instrument.
1. Why do overtones not always follow integer multiples of the fundamental frequency?
Overtones are created when a sound wave vibrates at a frequency that is a multiple of the fundamental frequency. However, in real-world scenarios, there are factors such as material properties, shape of the object, and external forces that can alter the frequency of the overtones. This results in the overtones not always being exact integer multiples of the fundamental frequency.
2. How do overtones affect the quality of a sound?
Overtones play a significant role in determining the quality or timbre of a sound. The presence and strength of overtones can alter the perceived pitch, loudness, and tone color of a sound. Different combinations of overtones create distinct timbres, which is why different instruments or voices can produce different sounds even when playing the same note.
3. Can overtones be manipulated or controlled?
Yes, overtones can be manipulated or controlled through various techniques such as changing the shape of the vibrating object, using different materials, or adjusting the external forces acting on the object. This is how musicians are able to produce different timbres and create a variety of sounds on their instruments.
4. Are overtones important in music theory?
Yes, overtones are crucial in music theory as they are the building blocks of harmonics. The relationship between overtones and the fundamental frequency is used to create scales, chords, and intervals in music. Understanding overtones is essential in creating and analyzing music.
5. How do overtones affect the sound of human speech?
Overtones play a significant role in the sound of human speech. They help to create the distinct voices and accents of individuals. The manipulation of overtones through the vocal cords and mouth shape also allows for the production of different sounds and tones in speech. Without overtones, human speech would sound flat and monotone.
  • Other Physics Topics
