Is the glueball the only stable physical particle in pure Yang-Mills theory?
In summary: QCD?In summary, according to the author, only one physical state exists in asymptotic free theories: a glueball. The author also notes that the perturbation theory is well-defined for this case, at the level of rigor required by physicists.
petergreat
267
By "physical particle" I mean color-singlet particles which have asymptotic [itex]T=\pm \infty[/itex] states. How many stable particles exist in the theory? Only one? SU(2), SU(3), and SU(N) gauge groups can all be discussed.
My understanding was the following: Those theories are asymptotically free. So, for scattering at sufficiently high momentum transfer, any state would be a physical in- and out-state for scattering. Even ones with non-zero colour-charge. E.g. you could consider scattering betwen single glouns.
However, at low momentum transfer, it makes more sense to choose colour-neutral asymptotic in- and out-states. E.g. glueballs, but I wouldn't think that an exhaustive list of the different glueball-states exists. You can find a small list on Wikipedia of conjectured SU(3) glueball masses obtained from lattice calculations:
http://en.wikipedia.org/wiki/Glueball
Check out [Actor, Reviews of Modern Physics, 1979] for many interesting classical solutions of SU(2) YM, both wave-like and topological solutions like the BPST instantons.
The webpage lists three conjectured glueball states. The lightest one must be a stable particle, since it has no decay channel (we are talking about pure YM, no electroweak decay considered). But are the two higher mass glueballs stable?
Under the assumption that those indeed are possible states, at least the lowest energy states with nonzero angular momentum would necessarily be stable, since that is a conserved quantity at least in the continuum theory.
But I believe that this is a very difficult problem, so I don't think much is known about it. I'm happy to be corrected, though! :-)
That's not correct (even if nobody has told you so far in standard QFT lectures).
There is a strict law in QCD (any gauge theory) which enforces color-neutrality, i.e.
Qa|phys> = 0
except for classical, non-dynamical background fields.
The derivation in QED is rather simple: take the Gauß law
div E - j° = 0
integrate over 3-space and drop the surface term (which would generate a non-dynamical surface charge)
Q = 0
This equation translates into
Qa|phys> = 0
for SU(N) quantum gauge theories.
b/c the Gauß law acts as generator of infinitesimal time-independent gauge transformations (using A°=0 gauge) violating the condition Q=0 is only allowed in the non-physical sector.
Qa|phys> = 0
div E - j° = 0
Q = 0
Qa|phys> = 0
I would appreciate it if you would comment on the following statements, because I'm not completely convinced and I would love to learn more because I see that I'm not completely confident with this matter. Hopefully it will also be relevant to the question in the OP:
At very large energy, the smallness of the renormalized coupling constant, due to asymptotic freedom, makes the single free gluons appropriate as a in- and out-states in perturbative calculations. By this statement I do not mean that they qualify as "physical states", but only that the perturbation theory is well-defined in this case (at the level of rigour required by physicists).
I guess by a "physical state" one means a state that is a) on-shell and not negative-norm, and b) gauge-invariant, at least up to a constant complex phase factor?
Doesn't your use of Gauss' law only imply that the total charge of the system is conserved in time? For example, if the in-states at t=-infinity had a non-zero total colour charge, yoo would get a non-zero boundary contribution, so Q would differ from 0? The distribution of the charge is determined by j^0, and wouldn't think that it was correct to call it a "surface charge", just because Gauss' law can relate the value of the integral of the charge distribution to the value of the integral of a gauge field at infinity? I mean, the charge is not located on any surface?
How would you argument go for a scattering process in QED with two incoming free electrons at T=-infinity?
Would you know a good reference for these matters...? After wading through Peskin-Schröder, Weinberg & Kaku just now I didn't find a clear explanation. I guess I could have been more thorough, though.
Correct.
If you use a physical gauge (i.e. A°=0 + Coulomb gauge condition) you never deal with negative norm states. And yes, physical states are gauge invariant.
The Gauß law annihilates physical states
[tex]G^a(x)|\text{phys}\rangle=0[/tex]
In addition it acts as the local generator of time-independent small gauge transformations leaving A°=0 invariant:
[tex]U[\theta] = e^{-i\int d^3x\,\theta^a(x)\,G^a(x)}[/tex]
A gauge trf. is then generated by
[tex]\mathcal{O} \to \mathcal{O}^\prime = U[\theta] \mathcal{O} U^\dagger[\theta][/tex]
which can be applied tofermionic operators and to gauge field operators like Aa and Ea.
b/c the Gauss law annihilates physical states one sees immediateky that for each physical state we have
[tex]U[\theta] |\text{phys}\rangle = \text{id}|\text{phys}\rangle[/tex]
Yes, The Gauß law commutes with H (where both H and G are defined in the kinematical Hilbert space as in the physical one G ~ 0), i.e.
[tex][H,G^a(x)] = 0[/tex]
(strongly as a Heisenberg equationof motion, not only when acting on physical states).
This is a much stronger condition than charge conservation b/c it holds locally!
torquil said:
For example, if the in-states at t=-infinity had a non-zero total colour charge, ...
This calculation does not makes sense in the physical Hilbert space; it can be done in the kinematical Hilbert space before implementing the Gauß constraint, but there is no good reason to do that.
By surface charge I mean the following:
[tex]\nabla E - \rho = 0[/tex]
No using integration and Gauß's theorem on gets
[tex]\oint E - Q = 0[/tex]
Therefore one cannot argue that Q=0 unless one imposes "physical conditions" on E or assumes that space is compact. But usually we do not believe that there is something living on the boundary of the universe spoiling this argument ;-)
In QED due to missing confinement one could be interested in this process even if it violates charge neutrality. If you want to do this calculation you must deal with unphysical states. If you want to restrict to physical states the calculation is meaningless.
Quantum Mechanics of Gauge Fixing
Annals of Physics
Vol. 233, No. 1 (1994), p. 17-50
QCD in the Axial Gauge Representation
Annals of Physics
Vol. 233, No. 2 (1994), p. 317-373
1. What is a glueball in pure Yang-Mills theory?
A glueball is a hypothetical particle predicted by pure Yang-Mills theory, a theory that describes the strong nuclear force between quarks. It is composed solely of gluons, the particles responsible for holding quarks together. In contrast to other particles, which are made up of quarks, a glueball is a bound state of gluons.
2. Is the existence of glueballs confirmed by experiments?
No, the existence of glueballs has not been confirmed by experiments. This is because pure Yang-Mills theory is a theoretical framework and has not yet been fully tested or proven by experiments. However, there have been some indications of glueball-like states in particle accelerators, but further research is needed to confirm their existence.
3. Why is the glueball considered the only stable physical particle in pure Yang-Mills theory?
In pure Yang-Mills theory, gluons interact with each other through the strong nuclear force, and this interaction becomes stronger as the distance between them increases. As a result, gluons cannot exist on their own and must form bound states with other gluons. Glueballs, being composed solely of gluons, are the only possible stable bound state in this theory.
4. Can the existence of other stable particles in pure Yang-Mills theory be ruled out?
Theoretically, other stable particles may exist in pure Yang-Mills theory, but they would require a different mechanism for their stability. Glueballs are the only stable particles predicted by the theory as it stands, but this could change with further developments or modifications.
5. What are the implications of the glueball being the only stable particle in pure Yang-Mills theory?
If the existence of glueballs is confirmed, it would have significant implications for our understanding of the strong nuclear force and the fundamental particles that make up the universe. It would also provide further evidence for the validity of pure Yang-Mills theory, which is still a subject of ongoing research and debate among scientists.
  • High Energy, Nuclear, Particle Physics
  • Beyond the Standard Models
  • General Discussion
