When moving at the speed of light time stops
In summary: Suppose you have a nice standard plane polarized...In summary, time doesn't freeze for photons traveling at the speed of light.
  • #36
Moonraker said:
even if the Lorentz transformation does not apply to photons.
Be careful here... The Lorentz transforms never apply to things, be they photons moving at the speed of light in all frames, or massive particles and observers moving at less than the speed of light in all frames. They apply to the coordinate systems that we use to assign (x,t) values to events such as "the thing is at point x at time t"
  • #37
Doc Al said:
You do realize that the time dilation formula is just a special case of the Lorentz transformation, don't you? So if the LT doesn't apply, neither does the time dilation formula.
My opinion as well as yours needs to be proved. The fact that one formula is a special case of another does not exclude an extension of its field of application.
The Lorentz transformation does not apply due to a division by 0. The time dilation formula does not share this problem.
In other words: We get no information about proper speed and distances for photons, and there is even no inertial frame of photons, but we get information about the proper time of photons.
There is no reason not to apply the time dilation formula (if there is please let me know), and there are many reasons in favor of application.
  • #38
The time dilation formula and the Lorentz transformations depend upon the basic assumptions of relativity, one of which is that the speed of light is invariant and equal to c in all frames. Applied to a frame co-moving with photon, such a statement is gibberish.
  • #39
Yes it does. Time Dilation means a time interval is getting larger for a moving object in a given reference frame. You have to divide by zero to find how long any interval is for a photon.
In Special Relativity, Einstein defines time as that which a clock measures. A clock cannot be made out of just photons, it requires massive particles. Massive particles cannot travel at the speed of light. Therefore a clock cannot travel at the speed of light and there is no definition for time at the speed of light. It's a meaningless concept.
  • #40
If I may...
It might be semantics but it could be more appropriate to say that time comes into existence when "things" move slower than the speed of light rather than saying time "freezes" at c. That time itself is related to this slowness and things that move sub-c.
While the math may go all screwy when t'=0, the concept that light comes into existence, is absorbed/transformed and passes through the points in between on "it's" straight line all simultaneously is hugely interesting. There are implications on a photon's behaviour since it is limited to experiencing it's entire existence with no time even though we observe it to have traveled for potentially billions of years. That the conditions that allow a photon to be created and absorbed in it's frame must be correlated to those in ours in order for us to experience light(radio, gamma, etc) at all.
I know I'm wandering into philosophy but a simple div/0 error should not stand in our way to understanding all of this.
  • #41
TomTelford said:
If I may...
It's not just an issue of dividing by zero. Did you read my previous post or the rest of this thread? There is no meaningful definition for time applied to a photon. A photon has no experience of any kind. A photon has no frame. You need to read before you write.
  • #42
TomTelford said:
... a simple div/0 error should not stand in our way to understanding all of this.
It doesn't
Read what that simple math is saying. In fact take it a step further, and consider what the measured phenomena is.
geometrically the div/0 error makes sense...and...yup...we're still discussing geometry, not trying to identify what nothing is.
  • #43
That is not precise:
1. Lorentz transformation depends upon the basic assumptions of relativity, one of which is that the speed of light is invariant and equal to c in all inertial frames. However, a photon may be considered as a frame but not as an inertial frame.
2. Time dilation (and also Lorentz contraction) should not be confused with Lorentz transformation.
3. Do not confuse the case v>c with v=c. v>c is ruled by a general principle, v=c is "only" ruled by the problem of division by 0.
4. Applying time dilation and Lorentz contraction to photons is not gibberish but leading to clear positive results.
  • #44
Time dilations and length contractions are special cases of a general lorentz transformation. I'm not sure how to respond to #4 because I don't see what your argument is in support of the (meaningless) concept of applying time dilation or length contraction "to photons". You just keep repeating that statement over and over without any physical justification.
  • #45
The so-called time dilation formula compares proper time of two frames. The photon has a proper time, the observer has a proper time, they are comparable, and no time is divided by 0 (see above-mentioned formula). Sure, please do not climb onto the photon for measuring the time of the observer! This will not work (division by 0). The photon is not an inertial frame.
For photons, their life time is an instant of 0 seconds, and in their frame space is contracted to zero. This is fitting harmoniously with the rest of the special relativity.
  • #46
If not, then elaborate, but that seemed to be the point upon which this thread was piling up on.
Yes and yes, and many others on this topic.
I disagree. We may not have a transformation function that produces a singular result but that is not necessarily a restriction on the term "meaningful definition". What I am proposing is that if the Lorentz transform cannot "define" time "meaningfully" then other methods should be developed. These terms have a natural ambiguity so ask if I am using them a certain way before telling me I'm wrong, thank you.
We must allow a photon to have an "experience" as there are defined changes in its existence which can be correlated to observed changes. The whole point is to attempt to rationalize change without time.
It most definitely has a "frame" of some kind even if it is difficult to define mathematically.
I have read a great deal, thank you, on a great many subjects. You need to know when to make suggestive commentary and when not.
Now, to reiterate: I was suggesting that instead of assuming a frame that includes time as the "normal" case and attempting to understand the "timeless" state of a photon we could attempt the exercise from the opposite direction. It could be that time itself is somehow anomalistic.
If I was not clear, I apologize.
  • #47
TomTelford said:
While the math may go all screwy when t'=0, the concept that light comes into existence, is absorbed/transformed and passes through the points in between on "its" straight line all simultaneously is hugely interesting.
When the math goes all screwy, that's the math trying to tell us that we're misusing it; and the way to advance our understanding is to stop torturing the math in an effort to force a confession out of it.
We got here in two steps. First, a previous poster has tried plugging the value v=c into the time dilation formula, without recognizing that the time dilation formula is derived from the relationship between the x and t coordinates in one frame to the x' and t' coordinates in another frame moving at a speed of less than c relative to the first frame. The result is seductive but altogether meaningless nonsense.
The second wrong step (easy to take, because the nonsense of the first step is indeed very seductive) came when you allowed the s-word, in boldface above, to lead you further astray. We all agree (I hope) that "simultaneous" means "at the same time"; but what exactly does THAT mean? Here's a slightly oversimplified definition:
If two events have the same Minkowski t coordinate in some reference frame, then we say that they are simultaneous in that frame.
(footnote 1: I specified "Minkowski" because I don't want to go anywhere near the rathole of GR and simultaneity conventions and coordinate time. Please, please, please don't send this thread down that rathole? Please?
footnote 2: This definition works just fine for classical Newtonian physics as well; I'm not making up some weird non-intuitive definition of simulataneity here)
But note that according to this more precise definition of "at the same time time", the emission, passage, and absorption of a light signal is NEVER simultaneous.
  • #48
Frames don't have Proper Time, they have Coordinate Time. The Time Dilation formula compares the Proper Time of a material object to the Coordinate Time of an Inertial Reference Frame in which the object is moving at some speed. If you transform the coordinates of events from one IRF to another one moving with respect to the first one, you can get a different Time Dilation for the same object. Events associated with a photon will always transform between frames such that the photon continues to have a speed of c in all IRF's. Material objects can have different speeds in different IRF's and therefore different Time Dilations. The concept of Time Dilation is meaningless for photons. I can point you to numerous examples of how this works in other threads.
If you don't agree with this, then please show me an example of what you mean when you say "The so-called time dilation formula compares proper time of two frames."
The propagation speed of light (or photons) is fundamental (it's the second postulate) to Special Relativity. But, as I said before, a precise definition of time and space are also fundamental and your ideas of time and space applied to photons are not defined and do not fit harmoniously with the rest of SR nor is there any need for them. It's not like there is a hole in SR that needs to be filled in. The track you are going down will lead you astray to understanding SR. Furthermore, it is speculation that is not permitted on this forum and if you continue, you will likely get banned.
  • #49
>nitsuj - Exactly. Which is what I have been pondering for quite some time. I have been looking at this time/no time dilemma from the perspective of an (infinitely) many to one relationship that occurs in data analysis from time to time. There are methods of reconciliation and I'm trying to apply them in this instance although my knowledge level in physics and related maths is not yet strong enough... getting there. It does indeed make sense at least as far as I have been able to poke at it. But there are implications of "no time"; it isn't simply a dead end.
>Nugatory - Agreed, that math seemed not to be applicable.
... the "S" word huh? Okay. I didn't know how else to express what I was thinking. However even if "simultaneous" means as much to a photon as time itself, it does permit a certain view of our frame from the photon's perspective which does involve simultaneity. Time may not be defined for the photon but location is not defined for us from it's perspective. Things are and are not at locations (or locations are or are not... very confusing). I'm not sure if this relates to the idea of d=0 which I am very skeptical of. Any readings in this direction would be appreciated.
  • #50
I did elaborate in my previous post. Here, read this:
The Lorentz transform does not define time at all. It was defined by Einstein in a two-step process. First, as I said before, it's what a clock measures at a particular location. Then to define time at a remote location a second clock is placed and the two clocks are synchronized using the definition of light propagating at c. This process, along with rigid (material) rulers define the concept of an Inertial Reference Frame. None of this can apply to a photon. And there is no need for it to. You are creating a problem where none exists. Furthermore, your proposal is against the rules that you agreed to when you signed on to this forum and I don't want to be part of this kind of activity. This forum is to learn relativity, not to add to it with your own personal concepts. I'm warning you to stop or you will likely get banned.
It is not possible to observe a traveling photon or the propagation of any light, let alone, observe any changes. Where did you get the idea that there are "defined changes in its existence"? What do you mean by "The whole point is to attempt to rationalize change without time"? I doubt that you will get up to ten posts before you get banned.
Unless you can do it, how can you say that it can definitely be done? (I see a ban coming on.)
I'm making a strong warning: stop this nonsense or you will get banned.
Instead of apologizing, I suggest you delete all your posts quickly before you get banned so that you can continue to learn what relativity is all about. If you do it quickly enough, I will delete mine and hopefully others will too. Maybe you can still survive.
  • #51
Moonraker said:
The “clock” of the photon shows 0 seconds, according to the above-mentioned time dilation formula:
T‘ = T * sqrt (1-v2/c2),
You have been given some good advice, which you seem reluctant to take, so let me try as well.
The Lorentz transform is (in part)
[tex]t=\frac{1}{\sqrt{1-v^2/c^2}}\left( t' - \frac{vx'}{c^2}\right)[/tex]
In this equation t and t' are coordinate times in the two frames and v is the relative velocity between the primed and unprimed frames. Since both frames are inertial this v is constrained by -c<v<c.
When you make the simplification x'=0 then you get the equation you posted above:
[tex]t'=t\sqrt{1-v^2/c^2}[/tex]
Here v is still the relative velocity between the primed and unprimed frames. The simplification does not change that in any way, so it is still constrained by -c<v<c. It isn't a matter of whether or not the equation has a division by zero or not, it is simply that doing a little algebra does not change the valid domain of a variable.
Also, t and t' are both coordinate times, not proper times, so they remain coordinate times after the simplification. However, this is a rather minor point. For a clock at x'=0 we have [itex]\tau = t'[/itex], so we can easily make that substitution when we make the simplification, giving: [itex]\tau=t\sqrt{1-v^2/c^2}[/itex], where t is still a coordinate time but now [itex]\tau[/itex] is a proper time. But even so, -c<v<c.
I hope you agree that the above qualifies as a good reason not to apply the time dilation formula.
  • #52
In some respect it is, continue to imagine the photon doesn't experience time. It also doesn't experience length. To that end it is a dead end for geometry from the perspective of the photon.
The only implication I intuit for "no time" in a continuum is no geometry. Note the difference between no time & time stops (edit: oppps i guess you know the difference). Perhaps it is better said there is no observable time at c, as opposed to implying it exists but merely doesn't continue "ticking" for that particular "object" compared to me.
  • #53
Teach yourself to think in terms of points in spacetime (aka "events"), not times and locations (aka "coordinates"). It's natural to use locations and times to say something like "at ten minutes past the hour, on my lab table - the light signal hit the detector", but I could keep them out of the description by saying "the point where the path of the light signal through spacetime intersected the path of the detector through spacetime" instead.
This approach is more cumbersome (enough that we tend not to use it except when necessary) but enormously helpful when the more traditional view is confusing. The value of this approach is that the events, the relationship between them, and the distances between them are the same - gloriously and beautifully and simply the same - no matter whose notions of position and time you use to attach numbers to them. All of this "at the same place/not at the same place" confusion never even enters into the picture.
Of course, once you have attached numbers to an event ("ten minutes past the hour, six inches above the left-hand corner of my desk") you can use the Lorentz transforms to convert your numbers/coordinates into someone else's numbers/coordinates; and you can calculate stuff like time dilation and length between you and someone else by comparing the differences between your time and space coordinates for two events and their time and space coordinates.
However, this recipe cannot be applied to a "someone else" who is moving at the speed of light relative to you - there's no such thing, the Lorentz transforms generate nonsense if you pretend that there is, and if you take the nonsense seriously you'll be back to being confused.
  • #54
I think that's a perfect way to interpret these "distances". It's well said.
  • #55
There is a sense in which √(1-v^2/c^2) does apply to a photon. Time dilation is normally defined as the ratio of proper time to coordinate time for path. In this sense, the given factor is just a direct consequence of the metric for any inertial frame. Used for a photon in any inertial frame (not a photon frame), it just expressed the fact that a photon path is a null path - proper time is zero along a photon path. This much is valid. Where everything would break down is talking about the 'point of view' = frame of a photon; or distances as seen by a photon. Also, the normal meaning of proper time breaks down as gwellsjr points out - you cannot imagine a clock moving with the photon. However, as a geometric quantity, it is not only valid but required to speak of proper time=0 over a photon path.
  • #56
>Nugatory - Thank you... will chew on this for a while.
  • #57
I am a little bit reluctant to identify the spacetime interval along a null path with proper time.
If you have some path with a negative interval squared then that represents the proper time along the path. If you have some path with a positive interval squared then that represents the proper length of the path.
If you have a null interval then why would you identify that with proper time rather than proper length? No clock can follow that worldline, nor any ruler, so either way seems to be a stretch.
I think that I would probably just call it a null spacetime interval and not try to identify it with either proper time or proper length.
  • #58
I'll buy that. [In an inertial frame in SR:] Along a spacelike path, you can integrate √(1-c^2/v^2) dx to get proper length (v being strictly a coordinate derivative, not a physical quantity; treat as infinite when dt/dx=0). Along a timelike path you integrate √(1-v^/c^2)dt to get proper time. Along a null path, either one leads to zero interval.
  • #59
I believe you are referring to the spacetime interval which provides another equivalent definition for Proper Time.
If two events define a time-like spacetime interval, that means an inertial clock can be present at both events and will measure out the time-like spacetime interval, because it is a time interval and it is the Proper Time accumulated on the clock. We can think of the clock as being at a fixed location in a frame and the time is also the coordinate time delta between the two events.
If two events define a space-like spacetime interval, that means an inertial ruler can be present at both events in a frame in which both events occur at the same time and the ruler will measure out the space-like spacetime interval, because it is a distance and it is the Proper Distance measured by the ruler and it is also the coordinate location delta between the two events.
If two events define a light-like spacetime interval, that means that there is no frame in which an inertial clock can be present at both events nor is there a frame in which a ruler can be simultaneously present at both events. But a photon can be present at both events and it doesn't matter what frame is used.
When you consider the coordinates of two events where one of them is changing such that a space-like spacetime interval approaches zero and then hits zero and crosses over to a time-like spacetime interval, to attach the meaning of the zero-crossing to either a clock (time-like) or a ruler (space-like) misses the point. That is why it is also called a null interval--it is not merely a zero time interval any more than it is a zero distance interval or some hybrid of the two. It is neither. It is in a class all by itself, the class that only applies to light.
EDIT: I see DaleSpam got in essentially the same points while I was composing my post.
  • #60
PAllen said:
Where everything would break down is talking about the 'point of view' = frame of a photon; or distances as seen by a photon..
ghwellsjr in a different thread said:
Don't pay any attention to those people who want you to have a different reference frame for every observer. That just leads to unnecessary confusion. Any IRF can handle all the observers and all the objects
+1x2
If it were up to me, people would have to pass a test and be licensed to use the words "<something>'s reference frame"; until then they would be required to always say "a reference frame in which <something> is at rest".
Likewise, only license holders would be allowed to use the words "in a" in front of "reference frame" (not that they'd be likely to); the unlicensed would be required to say "working with coordinates calculated in" a reference frame instead.
Think of the possibilities...
WHOOP! WHOOP! WHOOP! <flashing blue lights>
"May I see your license, sir?"
"Officer, what's the problem? I just wanted to ask about the reference frame of a photon!"
"Sir, your license is restricted. You will have to restate your question, or I will forced to charge you with a license violation"
"What a stupid silly pedantic rule!"
"Sir, I am warning you that you are in violation of the law"
"OK, OK, I don't want to [STRIKE]go to jail[/STRIKE] be banned... I'll say it your way! I just want to ask about a reference frame in which a photon is at rest... Oh... wait... That does sound rather silly, doesn't it?"
"Yes, sir. That's why we do the license checks. I'll just give you a warning this time, but please [STRIKE]do drive more carefully[/STRIKE] post more precisely in the future."
  • #61
:rofl:
You could get points off your license for saying two things happens simultaneously without specifying the reference frame, and similarly for specifying a length or a time. So many points and your license is revoked.
  • #62
Nugatory said:
+1x2
Laughing out loud here!
Unfortunately, it seems that "reference frames" are the source of a lot of confusion. And the confusion is so basic that it seems hard to get people unconfused about it.
  • #63
OK from what I understand, the question here is why light from the sun doesn't just magically appear on Earth after it is emmited, since it's moving at the speed of light, yes? The thing is, time dilation occurs for only the photon, and not for the observers on Earth looking at the photon. If a classic relativity example is used, this is akin to an observer experiencing normal time, while a person in a fast-moving vehicle (say a spaceship) experiences time dilation. E.g. 1 second will stilll be 1 second to the observer, whereas to the guy in the ship, 1 second would be maybe 1.5 seconds, depending on how fast he is moving. The point I'm trying to state here is that time does not change or dilate for the stationary observer
For photons, this effect is merely magnified enormously, whereby the photon would experience an infinite time dilation, and essentially time would stop for the photon. Nothing changes, however for the observer and hence everything continues as per normal. If you still don't understand, try to imagine if photons from the sun didn't move at c, maybe at 1m/s lower than the speed of light (this is absurd but bear with me). Without hitting that limit, we treat the photon as a classical object, and the problem resolves itself, yes? It would take a certain amount of time for the photon to reach Earth. Then, we add the extra second, and we (or maybe just me) realize that it would be absurd to think that with that extra m/s, the photon magically would be able to bypass this time duration and instead instantaneously appear on Earth.
As an extra, I'd just like to say that Einstein himself said that instantaneous time travel is impossible, since that would mean the thing traveling instantaneously would be bypassing the speed of light.
  • #64
But light from the sun does appear magically on Earth. It's not like a spaceship coming from the sun at slightly less than the speed of light where we can actually watch it being launched at the sun and we can watch it traverse the space between the sun and the Earth and then watch its arrival on the Earth. If the spaceship had a clock that was visible to us on the Earth, we could see the same time on the clock that the riders see at launch and we could see the hands on the clock progress through the same time that the riders would see it progress during the trip and we would see the same time on arrival that they would see. However, we would see all this happening at a much greater rate than the riders would see it happening.
But not so with a photon. We cannot observe its emission from the sun as a separate event from its arrival. We cannot observe its progress as it travels the space between the sun and the Earth. All we can observe is the instant it actually arrives on Earth.
Time dilation does not occur for the photon and, as I just said, we cannot watch the photon's progress on its trip from the sun to the Earth. To us, it all appears instantly.
When you talk about Time Dilation, you must state what Inertial Reference Frame (IRF) you are referring to. (Didn't you read the previous posts on this subject?) Time Dilation is not something that can be observed because it is always in reference to a particular IRF and different IRF's assign different Time Dilations to each observer/clock/object. If you are assuming an IRF in which the sun and the Earth are at rest, then there is no Time Dilation for people on Earth that are also at rest in the IRF. People on the spaceship and their clocks will both be Time Dilated by the same amount so they will not be able to tell that you are using an Earth-sun based IRF. If you are using the IRF in which the spaceship is at rest, then the riders on the spaceship and their clocks will not be Time Dilated but those of us on the Earth and our clocks will be.
No, Time Dilation does not apply for photons because time does not apply for a photon. There is nothing different for a photon when you use different IRF's. The one thing that applies to a photon in an IRF is its speed which is always c. All material objects traveling at less than c travel at different speeds in different IRF's and experience different Time Dilations. This effect is meaningless for a photon. Please read the rest of this thread.
What problem?
If something travels at less than c on its trip from the sun to the Earth, then it will take a certain amount of time for us to observe its progress. But since photons travel at c, we cannot observe their progress and their trip appears to take zero time. But this has nothing to do with Time Dilation. There is no Time Dilation that needs to be bypassed.
Don't you mean it would be traveling at the speed of light and not bypassing it?
  • #65
h1010134 said:
... this is akin to an observer experiencing normal time, while a person in a fast-moving vehicle (say a spaceship) experiences time dilation. E.g. 1 second will stilll be 1 second to the observer, whereas to the guy in the ship, 1 second would be maybe 1.5 seconds, depending on how fast he is moving. The point I'm trying to state here is that time does not change or dilate for the stationary observer
Just in case ghwellsjr didn't make it completely clear to you, this is incorrect. The traveler on the spaceship does not experience any time dilation. For him, his clock ticks away at one second per second, but he sees Earth as time dilated. This is becase ALL obervers are stationary in their own frame of reference. There are no stationary observers in any absolute sense.
  • #66
Just seeking clarity on one point.
Case: Ship leaves non-gravitational location at relativistic speed. Both the observer at the origin and ship passenger see a clock in the other IRF as running slower, correct?
In SR is this solely a Doppler shift effect?
If the reverse is happening where a ship is approaching a non-massive location then do the clocks appear to be running faster?
BTW thank you gentlemen(women?) for clarifying why light cannot have an IRF... I am trying not to misuse terminology. :-)
  • #67
yep, you got it.
  • #68
correct
No, even if you correct for Doppler based on known speed of relative motion and speed of light (but not using relativistic Doppler formula), you find an additional slowdown by a factor of 1/√(1-v^2/c^2)
Yes, they visually appear faster. However, just as with separation, if you correct for Doppler in the obvious way, each computes a slowdown of the other by the same factor as above.
  • #69
We can do "leaving" and "approaching" all in one thought experiment by doing the approaching first: Approach, pass, and keep on going, and now we're moving away.
Let's agree to use a strobe light that flashes periodically (and at a rate of once per second according to an observer at rest relative to it) as a standard clock, and equip all observers with these clocks.
If you mean "see" and "appear" literally - you have a telescope focused on the clock and you are counting the pulses and comparing their rate with your local clock - then yes, you will see the [STRIKE]moving clock ticking fast[/STRIKE] pulses arriving at a rate greater than once per second as you approach the other ship and then slow as you pass it and are moving away from it. This is Doppler at work. (Because the same description works if we say that we're at rest and the other ship is racing towards and past us in the other direction, for the rest of this post I'll try very hard not to refer to one of the ships as moving and the other at rest; there are just two ships moving relative to one another).
But note that you are not making a direct observation of the moving clock (and therefore the struck-out text in the previous paragraph is a subtle but dangerous misstatement). You are making direct observations of light pulses arriving at your telescope, right under your nose.
It's not possible for me to directly observe the time dilation of the other clock but there is a procedure that I can use to indirectly observe it (this procedure is how the cosmic ray muon decay observations are justified, for example). Ahead of time, long before the two ships are starting their approach, I station a very large number of observers all along the line of travel between me and the other ship. Each of these observers is at rest relative to me, and each one is carrying their own synchronized clock. Note that the clock synchronization is only possible because they're all at rest relative to me and each other; we could say that they're all part of the same inertial reference frame, although I'd rather say that they collectively define an irf. Eventually the other ship will pass by each of these observers, and as it does, that observer writes down on a slip of paper the time on his clock, his (fixed) position, and whether the light on the passing ship is on or off.
Then, much later and long after the thought experiment is done, we gather all of these slips of paper and correlate them to see exactly when and where the flashes happened; these are the positions and locations, aka coordinates, of the flash events as described in our inertial reference frame. When we do this, we will conclude that the clock on the other ship passing us was running consistently slow, both as we draw nearer and then as the two ships pass and start to move apart. That's the SR time dilation effect, and whatever is recorded on the slips of paper will be consistent with the observed arrival times of the pulses of light at our telescope.
It's worth noting that the other spaceship can set up their own chain of observers along the flight path as well. Because the other spaceship's observers will all be at rest relative to the other spaceship, they'll all be moving relative to our observers. The situation is completely symmetrical, and both sets of observers will find that the moving clock is running slow.
And finally, I can gather up all the slips of paper from one group of observers, and then use the Lorentz transformations to calculate what the other group of observers wrote down. That relationship is also symmetrical.
  • #70
Sorry, DaleSpam, but your mere derivation of the proper time formula from Lorentz transformation does not inhibit the possibility that the constraints the original formula is underlying do not rule the resulting formula (e.g. from the formula x = y*z/z derives x = y; both are not defined for z=0, but may be the second works also for z=0).
What I mentioned in the last posts I learned at school and read in books. In order to be precise, before posting I adopted the information
“For photons, their life time is an instant of 0 seconds, and in their frame space is contracted to zero.”
in its sens from a physics book. - Except the notion “frame” which I can take back. I used it because for me a “frame” was not an “inertial frame”. The last posts of forum users showed me that the word “frame” is not admitted in this forum. I hope you accept my following correction:
“The photon life time (in vacuo) is an instant of 0 seconds, the photon path is contracted to zero”.
However, I do not understand the following (please correct me if I’m wrong with these conclusions):
Photons are composing light, so light is submitted to a null space-time interval, life time of light is 0 seconds and the light path is zero.
But science found out that light takes 8 minutes from Sun to Earth, over a distance of 8 light minutes.
If time dilation is not applying to light, is there a “similar effect”, similar to the time dilation of special relativity (as we know it from the twin paradox)?
