Higgs boson's mechanism for giving mass?
In summary, the Higgs boson is a fundamental particle that plays a crucial role in the Standard Model of particle physics by giving mass to other particles through its interaction with the Higgs field. This mechanism, known as the Higgs mechanism, is responsible for the existence of mass and is a key component in understanding the fundamental forces and particles of the universe. The discovery of the Higgs boson in 2012 confirmed the existence of this mechanism and provided further insight into the nature of mass and the fundamental workings of the universe.
keepit
94
What is the Higgs boson's mechanism for giving mass?
OK, so the Higgs boson interacts with particles to give them mass (as per the previous movie) but still, does anyone know the mechanism of interaction?
does anyone here know what the Higgs mechanism is?
Did you read the wikipedia page? Since you replied a minute after it was posted, I gather that you did not. If you did, what is there on that page that you do not understand?
To clarify: it's the interaction with the Higgs field that gives gauge particles mass. The Higgs boson is the excitation of this field.
Likes 1 person
quite a bit actually. The wiki post and my post were only a coincidence. The math of the wiki post notwithstanding, it is really that simple?
"Don't shoot, it's only me," Bob hope 1990.
"Simple"? It is simple if you make the model so simple that it is a very rough, and often misleading description of the actual physics.
is the Higgs field equivalent to space itself?
No. It's just like any other quantum field, except that there is a property of the Higgs field that is nonzero in space.
do the particles that are given mass by the Higgs field affect the Higgs field?
Yes. For example, the mass of the Higgs particle depends on all the particles to which the Higgs couples. More generally, any property of the Higgs that gets renormalized depends on all such particles.
Likes 1 person
In general is the technique of renormalization required because of interactions?
I know the question is vague. That's because there's a lot i don't know.
my2cts said:
Actually the Higgs field in the vacuum should be so strong that according to Nobel laureate Veltman the universe would collapse to the size of a football.
http://lepfest.web.cern.ch/LEPFest/OfficialCeremony/Speeches/MartinusVeltman.html
That's the energy of the Higgs vacuum; I'm referring to the vacuum expectation value of the field. The latter is definitively nonzero, the former is unknown. I have no idea Veltman thinks there needs to be an energy associated with the Higgs field that would cause the universe to collapse.
Can you explain the difference?
On slide 17 of http://www.nikhef.nl/pub/theory/academiclectures/Higgs.pdf Veltman explains how he reaches this conclusion.
That is correct.
See the figure in this post: http://dorigo.wordpress.com/2007/11/10/the-goldstone-theorem-for-real-dummies/. The values +/- [itex]\nu[/itex] are the vacuum expectation values of the field for the corresponding vacuum. The Higgs starts in the middle, at the local maximum (the false vacuum), and rolls down to one of the minima (true vacua). The energy of the true vacua, [itex]V(\pm \nu)[/itex], is the vacuum energy of the Higgs. So the vacuum expectation value of the field and the vacuum energy are different things. It is generally assumed that [itex]V(\nu)=0[/itex], but this is really just put in by hand. If [itex]V(\nu)<0[/itex], then the universe should collapse if the Higgs field is dominating the energy density of the universe (this might be what Veltmann is talking about). Otherwise, if [itex]V(\nu)>0[/itex], the universe should inflate once the Higgs field dominates.
Here's how I like to explain it. The Higgs particle gets a nonzero field value from interacting with itself. That nonzero field value then makes it always there for particles that interact with it, and that's what gives those particles their masses.
But you should distinguish between the Higgs field and the Higgs particle, which is the excitation of the field. Gauge bosons acquire mass through their coupling to the VEV, not through Yukawa-type couplings to the field directly.
Gauge particles don't just couple to the Higgs VEV, but to the entire Higgs field, as elementary fermions do.
Of course, but the gauge boson mass terms arise specifically from the coupling with the VEV: [itex]M \sim gv[/itex], where [itex]v[/itex] is the VEV and [itex]g[/itex] the coupling.
The elementary-fermion mass terms also arise in that fashion.
Rather schematically,
[tex]L = |(g\cdot W)\cdot H|^2 + (y \cdot \psi_R \cdot H \cdot \psi_L) + \text{H.C.}[/tex]
for the gauge particles and the elementary fermions.
[tex]H = v + \phi[/tex]
Higgs particle -> VEV + excitations
So it works the same for both:
[tex]L = (m_W)^2 |W|^2 (1 + \phi/v)^2 + (m_f \cdot \psi_R \cdot \psi_L) (1 + \phi/v) + \text{H.C.}[/tex]
where mW = g*v and mf = y*v.
Ok guys, thanks for the explanations. I wonder what Veltman's pov is on this. How does the cosmological constant fit in?
In this link there is more detail:
http://igitur-archive.library.uu.nl/phys/2005-0622-155143/ReflectionsoftheHiggssystemVeltman.pdf
The cosmological constant is a sort of vacuum energy density, with pressure = - that density. Notice the minus sign.
The big problem with it is that its value is much lower than what one might expect from quantum gravity. One naively expects the Planck density, but its observed value is about 10^(-120) that. Relative to electroweak symmetry breaking, that discrepancy is about 10^(-52) - 10^(-50).
I think that it's a problem for quantum gravity, and that is still an unsolved problem.
Veltman states that the cosmological constant in the Higgs model takes the form C= m2M2 / 8g2 ,
which is way too large.
http://igitur-archive.library.uu.nl/...temVeltman.pdf
This must be one of the most common questions I have seen on this forum
Related to Higgs boson's mechanism for giving mass?
1. What is the Higgs boson's mechanism for giving mass?
The Higgs boson's mechanism for giving mass is a theoretical concept in particle physics that explains how particles acquire mass. It proposes that the Higgs field permeates the universe and interacts with particles, giving them mass.
2. How does the Higgs boson give mass to particles?
The Higgs boson is a particle that is associated with the Higgs field. When particles interact with this field, they gain mass through a process called the Higgs mechanism. This interaction slows down particles and gives them a resistance to acceleration, which we perceive as mass.
3. Why is the Higgs boson's mechanism important?
The Higgs boson's mechanism is important because it helps explain one of the fundamental questions in physics - why particles have mass. It also provides a way to unify the electromagnetic and weak forces, which are two of the four fundamental forces in nature.
4. How was the Higgs boson's mechanism discovered?
The Higgs boson's mechanism was discovered in 2012 by the Large Hadron Collider (LHC) at CERN. Scientists detected a particle that behaved similarly to what was predicted by the Higgs mechanism, confirming its existence.
5. What are the implications of the Higgs boson's mechanism for future research?
The discovery of the Higgs boson's mechanism has opened up new avenues for research in particle physics. It has also provided evidence for the existence of the Higgs field, which could potentially lead to the discovery of new particles and a deeper understanding of the fundamental forces in the universe.
