Speed of light becomes Infinity and Zero
In summary, the conversation discusses the idea of time dilation and Lorentz contraction in relation to the speed of light. It is noted that photons, which travel at the speed of light, do not experience time and have no valid reference frame. The equation t = t0/√(1-v2/c2) is mentioned but questioned for its accuracy and explanation of variables. The concept of the speed of light being considered as an infinitely great velocity is also discussed.
  • #36
elfmotat said:
This equation says that the clock in S' should age more than the clock in S. Based on what we just established this is clearly wrong. The correct equation would be [itex]\Delta t' = \Delta t \sqrt{1-v^2/c^2}[/itex].
ok let's restrict ourselves to frame S and don't jump to S' when we discuss.Let S(stationary) and S' (say velocity=0.8c) have identical light clocks and time between consecutive ticks is 1 second(meaning in any inertial frame, the frame ages by 1 second for each tick in a clock placed in that frame).Going by your equation Δt'=0.6 s meaning S' registers 1 second for every 0.6 s in S. Do you think that's correct?
  • #37
That's what we've been doing the whole time.
If Δt'=0.6 s then the clock in S' registers 0.6 seconds for every one second in S. That's what Δt'=0.6 s means; 0.6 seconds has passed in S' as viewed from S!
  • #38
Δt' is NOT the time measured in S'. It is measured in S as the time taken between consecutive ticks for a clock placed in S'.
  • #39
Exactly.
  • #40
Combining and rearranging several posts:
RiddlerA said:
Wow that gives me an idea.. photon can be converted to particle/anti-particle pair and vice versa right?.. So if we find a way to photonize(matter annihilation) ourselves then we can travel at light speed.. In the destination we again do the reverse process(pair production) to bring our former self :smile:
And hence the mystery of Nightcrawler's teleportation is solved. Case Closed...:cool:
I don't know the details of particle/anti-particle creation and certainly not about teleportation; but if a Start Trek kind of teleportation would be technologically feasible then according to current theory, then yes it should be possible to travel like that to another part of the universe. :-p
RiddlerA said:
What i meant was that einstein eliminated the thought of ether by introducing relativity...
He thought so, but later he thought differently. The essential point which he showed is that if we accept certain premises based on observation (the postulates), then the Lorentz transformations follow of necessity, without explicitly introducing a physical model of what happens "in reality".
And btw thanks for the link.. that cleared lots of doubt... thank you very much..
You're welcome . :smile:
RiddlerA said:
Is this the twin paradox is all about? It is a hole in the special theory of relativity right?
I mean in reality Only one of them is going to age slower than the other, but if we interchange FoR then it shows that either of them have to age slower relative to each other, which doesn't make any sense...
Mutual time dilation is not really what the twin paradox is about as it goes one step further (and it is also not a hole in special relativity). However, it does rise a philosophical discussion point which also often comes up in discussions about the twin paradox - see below.
DaveC426913 said:
There is no "in reality"; that would imply a privileged point from which it can be viewed. There are only frames of reference.
The key is that, to decide which one is younger, one of them must turn around and go back to meet the other. And in doing so, this causes an asymmetry in the passage of their timelines. By the time they meet up again, they will both agree on who is younger.
That remark about asymmetry is perfectly correct; however the opinion that "reality" should correspond to "a privileged point" of observation is (positivistic?) philosophy; philosophy about reality is definitely not part of relativity. Relativity theory describes observations of physical phenomena.
  • #41
harrylin said:
...the opinion that "reality" should correspond to "a privileged point" of observation is (positivistic?) philosophy;
No, what's philosophy is RiddlerA's assertion that there is any kind of "in reality" in the first place - there is no way to experience it except through a frame of reference chosen arbitrarily.
How does he propose to go about demonstrating or measuring a "reality" that is not subject to a frame of reference?
  • #42
That is exactly what I meant with "positivistic" philosophy, as opposed to Riddler's "realistic" philosophy. :wink: Indeed, special relativity does not relate to "in reality", it only relates to measurable phenomena.
Coincidentally (and as discussed in other threads), Langevin* provided the space traveler example (later "twin paradox") as a demonstration of the existence of such a reality; but it depends on the way one's brain is wired if one agrees or not. :-p
But let's not deviate too much from the topic; the issue is merely if mutual time dilation (etc.) is clear for the OP.
*Langevin was one of the early teachers of special relativity and was also involved in its early conception
  • #43
Sorry I mentioned the equations by accident so don't keep bothering about the equations.. My question arised from the concept, not the equation...
DaveC gave a lot of points that i didnt know before such as that photon don't experience time and they see all the events of universe simultaneously etc etc...
Actually that makes sense as well as makes me think that relativity fails to explain the proper working of the universe..
Please DOnt ask why I am saying like this, its just a feeling that i have...
  • #44
None of the equations you quoted or supplied the links for nor any of the others that have been discussed in this thread were like Einstein's and his simple explanation:
ghwellsjr said:
τ = t√(1-v2/c2)
He explains this as t being the time on a clock at rest in a frame and τ (tau) being the time on a clock moving in that frame. It's so simple, but don't overlook the fact that the square root factor is multiplied, not divided, meaning the time dilation results in the moving clock running slower than the stationary clock. That's all there is to it. What ever speed any clock is moving at in a frame determines how much time dilation there is for that clock. If you switch to a frame where the moving clock is now at rest, the time dilation switches to the other clock.
Do you understand this? Doesn't it seem simple to you?
Dave did say that photons don't experience time but he didn't say they see all events simultaneously:
DaveC426913 said:
...photons do not experience time. Photons do not experience anything at all (since experience requires the passage of time)...
I sure hope you aren't giving up on understanding Special Relativity. (And it doesn't explain everything in the universe because it ignores the effects of gravity which is not simple.) Can you please just respond to my question about Einstein's equation and his explanation? Do you understand it? Don't you think it is simple? If you don't think so, please tell me why because I like to explain the simple concepts of Special Relativity to people and if what I think is simple does not seem simple to others, then I need to know why. Thanks for responding.
  • #45
τ = t√(1-v2/c2)
Let me tell u what i understand from this equation..
τ = denotes the time as read in a clock which is moving in a frame(say A)..
t = denotes the time as read in a clock which is at REST in the same frame A..
v = velocity of the clock which is in motion relative to the other which is at rest
c = speed of light in vacuum
Time Dilation:
Now let's consider you and me, where I am moving at speed v and you are at rest.. we both are in the same frame(say on a staircase to heaven ) I am rushing to enter the heaven at speed v while you wait patiently on the staircase... Let's take our heartbeats to be the clocks from which we measure our time... so my heartbeat is read as 'τ' and yours as 't'...
From the equation above, we can come to the conclusion that my heart beats slower than yours(Biologically: Assume everyone's heart beats at the same rate for all physical conditions (meaning fear don't increase heartbeat rate and so on))
For convenience, I am assuming my speed v = √(3/4)th of c
So the eqn becomes τ = t(1/2)
SO the above eqn implies that For every one of my heartbeats, your heart beats twice..
Mass Variation:
And also My mass would increase by the factor 1/√(1-v2/c2)
Length Contraction:
Now consider the same story as mentioned above..
A small change in the story for this concept
τ = time INTERVAL of my clock, t = time INTERVAL of your clock
and ofc τ= half of t
For you, my speed is √(3/4)th of c ...
so from your point of view, i would seem like traveling (√(3/4)th of c)*t metres in 1 second
If space remains absolute regardless of speed
Then from my own point of view, i would travel (√(3/4)th of c)*t metres in half a second(remember 1 second in my frame equals 2 seconds in your frame)
But the above condition cannot occur, it doesn't make sense because my speed is not the same in both our frames...
So we are introducing Length Conraction..
Now since I am moving, the staircase will be contracted by a factor of √(1-v2/c2) in my own point of view...
So as a result i would travel a contracted distance in 1 second in my own frame which would appear as me moving (√(3/4)th of c)*t metres in 1 second in your frame...
And so my speed remains constant in both the frames...
Problem solved...:smile:
Phew... Are the above stories correct?
Curiosity is one of the most dangerous incurable disease that happens to humans...
So my friend, i will never stop wondering why the universe works the way it works...
-RiddlerA
  • #46
RiddlerA said:
τ = t√(1-v2/c2)
Time Dilation:
Excellent. In fact, perfect. I especially like your comment that both of us are in the same frame and you consistently point out that only you are moving and only I am at rest. A lot of people never seem to learn this concept that everyone and everything is in any frame you choose.
RiddlerA said:
Mass Variation:
This is what I was taught in school many decades ago but I'm told that this idea is no longer in vogue. If you want to know more, do a search in this forum for "mass" and specify "Search Titles Only".
RiddlerA said:
Length Contraction:
This last part is correct as far as your calculations go but your explanations are not quite right because you are mixing two frames together. That will always introduce confusion. Always make it clear which frame you are discussing.
And you started using terms like "point of view" and "seem like" and "appear". When we are using Einstein's method, we need to emphasize that the times on clocks are what the equations say they are, it's not a mere optical effect or opinion or illusion. In fact, you and I may not even be able to observe the other ones clock as being time dilated like the equation says or we may not be able to detect length contraction but that is what is really happening according to the definition of the chosen frame of reference.
Another point: when you talk about your point of view, and by that, I understand you to mean you are now switching to your frame of reference in which you are at rest, you can't then say that you are moving. Rather you should say that the staircase is moving a contracted distance and you would say that you are moving a certain speed in my rest frame and I am moving the same speed in your rest frame. I think you really mean this and understand this, but I just wanted to clarify the terminology.
Anyway, you've done a really great job and I'm proud of you for seeing this through.
