Noise measurement-decrease in sound intensity with distance
In summary, the conversation discusses the issue of a noise level meter being affected by the decrease in sound intensity with distance. The problem is that the meter may give the same reading for a low intensity sound near the meter and a high intensity sound far away. Suggestions for addressing this issue include placing the sensor closer to the source or installing multiple devices to cover a wider area.
Nau
I am making a noise level meter, that would trigger an alarm, if the noise level has reached hazardous levels. However, one problem with noise is that it'd intensity decreases with distance, so that the meter would percieve a low sound near the meter and a high sound far away as equal. So does anyone have any innovative idea about how I can handle this problem?
Why is this a problem?
You are presumably not trying to make a detector that can detect the level of noise far away from the sensor?
No my detector is sensitive enough to detect sounds at a distance. But ofcourse when the sound would have traveled a long distance, its intensity would have decreased, and the meter would also give a small reading. However, a low intensity sound near the meter might be giving the same reading. that is the problem.
I am still not followíng you...
Isn't the purpose of the meter to warn agains high noise levels at the location of the meter?
If so, why is it a problem that it is not triggered by low noise levels near the meter?
you need to either put the sensor closer to the source, or install multiple devices so that you can cover a wider area.
What is noise measurement?
Noise measurement is the process of quantifying the level of sound in a given environment. It involves using specialized equipment to measure the sound pressure levels in decibels (dB) and can be used to assess the potential impact of noise on human health and the environment.
How is sound intensity related to distance?
The sound intensity, or the amount of sound energy passing through a unit area, decreases with distance from the source. This is due to the spreading of sound waves, also known as the inverse square law. As sound waves travel further from the source, the same amount of energy is spread over a larger area, resulting in a decrease in intensity.
What is the unit of measurement for sound intensity?
The unit of measurement for sound intensity is the decibel (dB). This unit is a logarithmic scale that measures the ratio of a sound's intensity to a reference level. A decibel is one-tenth of a bel, which is named after Alexander Graham Bell, the inventor of the telephone.
How is noise measurement used in research and industry?
Noise measurement is an important tool in research and industry for assessing the potential impact of noise on human health and the environment. It is used to monitor noise levels in workplaces, construction sites, and other environments to ensure compliance with regulations and to identify potential health hazards. It is also used in research studies to investigate the effects of noise on human health and behavior.
What are some factors that can affect noise measurement?
Several factors can affect noise measurement, including the type of sound source, the distance from the source, the type of environment, and the sensitivity of the measuring equipment. Other factors such as weather conditions and background noise levels can also impact the accuracy of noise measurement. It is important to consider these factors when interpreting noise measurement data.
  • Mechanics
  • General Math
  • Mechanical Engineering
