Find work done in stretching rubber band
In summary: Also, it would be good to explain the limits of integration (something crashdirty86 may be able to do).If trying to convince a disbelieving student, I might try this approach:Suppose you nominate some realistic data values (for Fo, lo, and s) and plot the graph F vs. s. (Surely your prof would agree that the work done is represented by the area under the graph.)Then all that remains is to have his show whether his integral evaluates to the same answer as that graphical area, or yours. :cool:But, most likely he is just having a senior moment. After a restful night's sleep he'll probably smack his forehead and wonder what on
inter060708
24
Please see attachment.
Not really a homework problem. This is 1 of my exam question which I believe I had the right answer but my professor insists that he has the right one.
I started by equating work done, W = integral F ds, with limit of integration from 0 to Lo. My professor's integral has limits from Lo to 2Lo.
If I am correct, please tell me how I can explain it to my professor. If not, explain to me why.
Thank you very much.
It seems clear that s goes from 0 to lo. But are you sure your prof didn't simply substitute ❲s+lo❳with another variable, say, x, where x goes from lo to 2.lo?
No substitution were made. He did it everything the same way except for the limits of integration. How can I explain to him?
The problem text says that s is the length the band is stretched by beyond the unstretched length Lo.
ehild
If you get a rubber band, does it already sit at full length or is it laid in some weird oblong shape? In my mind, you would be doing some small amount of work to have the rubber-band laid out in a way to measure its full, unstretched, initial length. From this perspective, you then begin to stretch the rubber-band twice its length, so technically the force stretching the rubber band starts at the initial length and then commences at twice its length. This would be the distanced used to integrate the work done by the force on the rubber band.
I am sorry, but in this case, are you saying that my prof's limit of integration is correct?
I understand that you need reference length for the force to be acting, but putting the initial limit of integration as something other than 0 would mean that you have stretched it beyond its natural length.(since 's' in the 'ds' is the amount of stretch)
Not sure what crashdirty86 is saying, but everyone else so far, me included, agrees with you: s goes from 0 to L0.
Putting the shoe on the other foot?
But, most likely he is just having a senior moment. After a restful night's sleep he'll probably smack his forehead and wonder what on Earth he was dreaming about to say it so wrong.
F equals zero when s equals zero so don't both sets of limits give the same answer? If F is finite when s is zero then the professors answer would be correct. However, F is not finite for zero s so for this particular problem it doesn't matter which of the two sets of limits is used. I think I may be missing something here.
http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon3.gif Is your professor someone for whom English is not his native language?
" ... s is the distance the rubber band is stretched beyond its natural length." could be confusing, though comparison with any ordinary spring should clear it up in his mind.
1. What is work done in stretching a rubber band?
The work done in stretching a rubber band refers to the amount of energy required to stretch the rubber band from its initial length to its stretched length. This work is measured in joules (J).
2. How is work done calculated when stretching a rubber band?
The work done in stretching a rubber band can be calculated by multiplying the force applied to stretch the rubber band by the distance it is stretched. This can be represented by the equation W = F x d, where W is work, F is force, and d is distance.
3. Does stretching a rubber band require more work as it gets longer?
Yes, the work required to stretch a rubber band increases as it gets longer. This is because the force needed to stretch it also increases with the length, and work is directly proportional to both force and distance.
4. How does the thickness of a rubber band affect the amount of work done when stretching it?
The thickness of a rubber band does not directly affect the amount of work done when stretching it. However, a thicker rubber band may require more force to stretch, which would result in more work being done.
5. What happens to the work done on a rubber band when it is released?
When a rubber band is released, the work done on it is converted into elastic potential energy, which is stored in the stretched rubber band. This potential energy can then be released when the rubber band returns to its original length.
