Can I treat blocks as a single axis of rotation?
In summary, the wooden blocks A and B are pressed against two hardened steel plates through the tension of the bolt. The question is whether these blocks can be treated as a single point, ignoring the forces Fsa and Na. The solution manual appears to contradict this, as one of the Fsa forces will have a distance of zero while the other one does not. However, it is possible to isolate a part of a rigid body and only look at its left plate, as long as the body is connected by joints. In a later course, it will be learned that rigid bodies are not actually rigid and can bend, shear, and break, and must be treated as separate bodies if they can rotate or shift relative to each other.
Femme_physics
Can I treat "blocks" as a single axis of rotation?
http://img171.imageshack.us/img171/2245/blockthingy.jpg
Basically those A and B wooden blocks are pressed against two hardened steel plates through the tension of the bolt. My question, can I treat these blocks as a single point? For instance, If I do sum of all moment on A, can I ignore Fsa (on both sides) and Na (on both sides), saying their arm is zero because it's considered a single point?
Hi Fp! :smile:
What do you mean by treating these blocks as single points?You can ignore Fsa (on both sides) and Na (on both sides), because those forces cancel each other out.This means that on any sum of forces, Fsa would be added and Na would be subtracted, so the net result would be zero.
And it means that on any sum of moments, Fsa times distance would be added and Na times the same distance would be subtracted, so the net result would be zero.
I can see I was a bit hasty in saying those forces cancel out. :shy:
If you do a moment sum for the entire system, the Na forces cancel each other out.
If you do a moment sum on block A, the Na forces cancel each other out.
If you do a moment sum on the left plate, you have only one Na force, so indeed it is not canceled.Back to your question, that I understand a little better now. :smile:
The Na and Fsa forces act on a surface, but they can be treated as acting on a point in the middle of that surface.
(Actually that point should be in the middle of where the surfaces "touch", and not in the middle of the block.)
For your moment sum you can choose this same point, meaning the Na distances to this point are indeed zero. But one of the Fsa forces will have a distance of zero, while the other one does not.
It's kinda weird! I didn't know it was possible! You can just take a shape, and only look at one plate of it? I thought we always look at the entire shape! It's not a truss, it's not a frame, what gave us the right to isolate a part of this object and only look at its left plate?
You can always look at as little a part of a body that you want.
However, in practice it's not very useful to look at only a part of a specific rigid body, so that is why Statics was invented, to treat rigid bodies as complete entities.
Do note that in a later course, you'll probably be learning that what you thought was a "rigid" body, is not rigid after all, but it can bend, shear and break.
The body is then treated as a lot of very small bodies that are connected.
If different rigid bodies can rotate or shift relative to each other, that must be considered and they must be treated separately, so you should draw an FBD for it.
Looking only at the left plate is no different than looking at a single body in a system that is connected by joints.
Ah, gotcha, brilliant :smile:
It's hard to grasp that you need to isolate one part to get the answer in this exercise. But I'm glad this method has been approved by you :smile:
Also, I saw some of hibbeler mechanics of material, and we actually had some basic stuff in calculating shear/bend/break stuff, but only 1 or 2 exercises that were promised not to be on the final test. So, unsure whether how deep we'll delve into the calculations of it, though I hope we will!
Thanks :wink:
1. Can blocks be treated as a single axis of rotation?
Yes, in certain cases, blocks can be treated as a single axis of rotation. This is known as the principle of parallel axis theorem, which states that if an object is rotating around a fixed axis, it can be considered as rotating around a parallel axis that passes through the center of mass of the object.
2. What factors determine if blocks can be treated as a single axis of rotation?
The shape and distribution of mass of the block are the main factors that determine if it can be treated as a single axis of rotation. If the block has a symmetrical shape and its mass is evenly distributed, it is more likely to be treated as a single axis of rotation.
3. Are there any limitations to treating blocks as a single axis of rotation?
Yes, there are limitations to this treatment. If the block is irregularly shaped or its mass is not evenly distributed, it may not be possible to treat it as a single axis of rotation. Additionally, external forces and torques acting on the block can also affect its rotation and may not be accurately represented by treating it as a single axis of rotation.
4. How does treating blocks as a single axis of rotation simplify calculations?
Treating blocks as a single axis of rotation simplifies calculations by reducing the problem to a one-dimensional rotational motion. This eliminates the need to consider the complex dynamics of the block and allows for the use of simpler equations and formulas.
5. Can treating blocks as a single axis of rotation be applied to real-world scenarios?
Yes, the treatment of blocks as a single axis of rotation is commonly used in various real-world scenarios, such as in engineering and physics applications. It is a useful simplification that allows for easier analysis and prediction of rotational motion in systems involving blocks.
  • Mechanics
  • Mechanics
  • Mechanics
