Cylindrical continuity eq using cartesian substitution.
In summary, the two questions asked are not valid and cannot be used to create a substitution for the normal velocity in the continuity equation.
psyclone
I've have two questions, but if my assumption is incorrect for the first, it will also be incorrect for the second. (in-terms of physics.)
For a two dimensional cylinder, using cylindrical co-ordinates (as follows), taking v(subscript-r) => velocity normal to cylinder surface & v(subscript-phi) => velocity parallel to surface (please refer to diagram for more detail).
[tex]\frac{1}{r}\frac{\partial v_{\phi}}{\partial \phi}+\frac{1}{r} \frac{\partial (r v_{r})}{\partial r}=0[/tex]
Using the the product rule, can we separate out the second term into two terms, creating a continuity equation consisting of three terms?
[tex] \frac{\partial v_{\phi}}{\partial \phi}+ v_{r}\frac{\partial r}{\partial r} + r \frac{\partial v_{r}}{\partial r}=0[/tex]
If that's valid. Can we make a substitution by using the cartesian form of the continuity equation, to change the normal velocity (v(subscript-r)) to the parallel velocity (v(subscript-phi))?
[tex]\frac{\partial u }{\partial x}+\frac{\partial v }{\partial y}=0 ==> \int d v =-\int_{0}^{\delta}\frac{\partial u } {\partial x}dy[/tex]
To yield,
[tex]\frac{\partial v_{\phi}}{\partial \phi}-\frac{\partial u}{\partial y}\frac{\partial y}{\partial x}\delta + r \frac{\partial v_{r}}{\partial r} =0[/tex]
Your help will be much appreciated. Ref: diagram Int. Comm. Heat Mass Transfer, Vol. 28, No. 8, pp 1127, 2001.
Your assumption is incorrect. The equation you have written is not a continuity equation and cannot be used to substitute for the normal velocity. The equation you have written is a conservation of momentum equation, which is used to describe the motion of a two-dimensional cylinder in cylindrical coordinates. The continuity equation describes the flow of mass or energy in a given area, while the conservation of momentum equation describes the motion of a particle in that same area. Therefore, they are two different equations and cannot be used interchangeably.
1. What is cylindrical continuity equation using cartesian substitution?
The cylindrical continuity equation using cartesian substitution is a mathematical representation of the conservation of mass in a system with cylindrical coordinates. It is used to describe the flow of fluid or other substances in cylindrical systems.
2. How is cylindrical continuity equation derived?
The cylindrical continuity equation is derived from the conservation of mass principle, which states that the mass of a closed system remains constant over time. Using the divergence theorem and applying it to a cylindrical volume, the equation can be derived.
3. What are the variables in the cylindrical continuity equation?
The variables in the cylindrical continuity equation are the velocity components in the radial, azimuthal, and axial directions (ur, uθ, uz), the density (ρ), and the cylindrical coordinates (r, θ, z).
4. What is the significance of using cartesian substitution in the cylindrical continuity equation?
Cartesian substitution is used in the cylindrical continuity equation to simplify the equation and make it easier to solve. It allows the equation to be written in terms of familiar cartesian coordinates, rather than the more complex cylindrical coordinates.
5. How is the cylindrical continuity equation used in real-world applications?
The cylindrical continuity equation is used in a variety of real-world applications, such as fluid dynamics, aerodynamics, and heat transfer. It helps engineers and scientists understand and model the behavior of fluids in cylindrical systems, such as pipes, turbines, and engines.
  • Classical Physics
  • Math POTW for Graduate Students
