- 19,443
- 10,021
We've been experiencing some instability so until I figure out the exact cause some features will be disabled off and on throughout the next few days. Sorry for the inconvenience.
Warning: file_put_contents(/home/physicsf/cache/rss.sciam.com-sciam-physics.cache) [function.file-put-contents]: failed to open stream: Read-only file system in [path]/includes/init.php(294) : eval()'d code on line 260
Warning: file_put_contents(/home/physicsf/cache/www.physicsforums.com-external.phptype-rss2-forumids-186.cache) [function.file-put-contents]: failed to open stream: Read-only file system in [path]/includes/init.php(294) : eval()'d code on line 260
Warning: file_put_contents(/home/physicsf/cache/www.physicsforums.com-mgc_gloss-mgc_gloss_rss.xml.cache) [function.file-put-contents]: failed to open stream: Read-only file system in [path]/includes/init.php(294) : eval()'d code on line 260
Warning: file_put_contents(/home/physicsf/cache/www.physicspost.com-rss.php.cache) [function.file-put-contents]: failed to open stream: Read-only file system in [path]/includes/init.php(294) : eval()'d code on line 260
Warning: file_put_contents(/home/physicsf/cache/www.physicsforums.com-blog_external.php.cache) [function.file-put-contents]: failed to open stream: Read-only file system in [path]/includes/init.php(294) : eval()'d code on line 260
Greg Bernhardt said:Our IPMI card appears to be a culprit in the server's instability.
Moonbear said:Is that related to the long list of errors I'm currently seeing on the main index page?
This is what they all are:
Count Iblis said:Is PF about to collapse under the weight of the 2,000,000 postings?
Vanadium 50 said:Wow...that was some "worst"!
Greg Bernhardt said:tell me about it! i have no slept yet and it's noon here :(
"Features Temporarily Disabled Due To Instability" refers to a situation where certain features or functions of a system, software, or application are temporarily unavailable due to technical issues or problems that may affect its stability or performance.
Features may be temporarily disabled due to a variety of reasons, such as software bugs, server issues, or unexpected errors. This is done to prevent further problems and maintain the stability of the system.
The duration of the disabled features depends on the severity of the issue and the time it takes for the developers to fix it. It can range from a few hours to a few days, depending on the complexity of the problem.
Yes, you can still use the other available features while some are temporarily disabled. However, there may be some limitations or disruptions in the overall functionality of the system.
The developers or technical support team will typically provide updates on when the features will be back. You can also check the system's status page or social media accounts for any announcements or estimated time of resolution.
