Experimenting with Geiger-Müller Tube: Half-Life of Protactinium (Pa)
  • Thread starter _Mayday_
  • Tags
    Tube
In summary: OKEN LINK In summary, Astronuc is asking about a situation where a Geiger Muller tube is used but it is not connected to the high voltage that activates it. If the GM is exposed to a high dose, would that dose be accumulated in the GM and would it give an indication when it is turned on?
_Mayday_
808
Hey,
On Monday I am doing an experiment to determine the half-life of protactinium (Pa), using a Geiger-Müller tube. The experiment itself is very straight forward and simple, but I have 70 minutes to do it in, which is a lot of time. I was wondering if there was anything else I could do with this apparatus to make the time left over constructive? I have already used to to measure how penetrating certain particles are through different materials.
The 70 minutes does not include time for writing up, so it is a long time, any ideas would be great.
Thanks.
Well, if it rains around then (don't know what part of the world you're in) you could collect some rain and measure the events per second from the fresh rain water (it was just a good ways up in the sky and exposed to cosmic rays, should have some radioactivity to it). Not difficult or anything, but mildly interesting just to see how radiactive rain water is. Of course I don't know how your teacher/TA/whatever would feel about you bringing water near the Geiger-Muller tube (probably not that expensive but it sucks to have to replace lab equipment).
Explore what might create a false positive with your counter.
How about variations in radiation intensity with direction?
Is there any significant (Radon) radiation from concrete vs. other building materials/soil?
Could you please expand a bit on that. What do you mean by a false positive? Thanks :smile:
I might try that if it's rainy tomorrow thank you.
I think what Loren Booda is suggesting is to do a background count, i.e. with the Pa source away from the detector. Due to low counting rates, a background count would take longer to achieve good statistics.
To measure the half-life (or decay constant) one usually has to do two measurement over some period of time. Then there are the two counting periods and the waiting period in between. Otherwise, one counts for one period, but one must know the mass of isotope present in order to determine the decay constant from the activity.
What is the pedigree of the Pa sample? Does one know the isotopic vector?
See this taken from ( www.nndc.bnl.gov/chart ). Use cursor to find Pa click on chart, then click on 1 under Zoom to see the details.
http://img213.imageshack.us/img213/8680/z91n139zl1ct12r4057sl3.png
Thanks, Astronuc, background count.
Dear Sir,
I need to ask about the Geiger Muller tube that is used for radiation detection in Japan by public. What if the GM exposed to radiation dose (gamma or beta) more than its limit but it wasn't connected to the high voltage which activate it, (Current+ cathode+ anode>> ionization+ cpm). Was this dose accumulated in the GM and as turn it on it will give indication for the high dose or not?
Thank you
BR
1. What is the purpose of using a Geiger-Müller tube in this experiment?
The Geiger-Müller tube is used to detect and measure the amount of radioactive particles emitted by the protactinium sample. This allows us to determine the half-life of protactinium.
2. How does the Geiger-Müller tube work?
The tube contains a gas that is ionized when radioactive particles pass through it. This ionization creates a current which is then amplified and measured by the detector, providing a count of the radioactive particles.
3. Why is protactinium used for this experiment?
Protactinium is a radioactive element with a relatively long half-life of 32,760 years. This makes it a suitable candidate for studying radioactive decay and determining the accuracy of the Geiger-Müller tube.
4. What safety precautions should be taken when working with radioactive materials?
It is important to wear protective gear such as gloves, lab coat, and safety glasses when handling radioactive materials. The experiment should also be conducted in a well-ventilated area and any spills should be immediately cleaned up and reported to the proper authorities.
5. How does the half-life of protactinium impact the results of the experiment?
The longer the half-life of a radioactive element, the slower the rate of decay. This means that it may take longer to obtain accurate readings and multiple measurements may need to be taken in order to calculate the half-life more precisely.
  • Other Physics Topics
10K
  • Quantum Physics
