Coefficient of x^r in Expansion of (1+x)(1-x)^n
In summary, the book should have defined the notation used in the last expression as 0 for cases where the index is out of range.
Appleton
91
I am puzzled by the following example of the application of binomial expansion from Bostock and Chandler's book Pure Mathematics:
If n is a positive integer find the coefficient of xr in the expansion of (1+x)(1-x)n as a series of ascending powers of x.
[itex](1+x)(1-x)^{n} \equiv (1-x)^{n} + x(1-x)^{n} [/itex]
[itex]\equiv\sum^{n}_{r=0} { }^{n}C_{r}(-x)^{r} + x\sum^{n}_{r=0} { }^{n}C_{r}(-x)^{r}[/itex]
[itex]\equiv\sum^{n}_{r=0} { }^{n}C_{r}(-1)^{r} x^{r}+ \sum^{n}_{r=0} { }^{n}C_{r}(-1)^{r}x^{r+1}[/itex]
[itex]\equiv [1-{ }^{n}C_{1}x+{ }^{n}C_{2}x^{2}...+{ }^{n}C_{r-1}(-1)^{r-1} x^{r-1}+{ }^{n}C_{r}(-1)^{r} x^{r}+...+(-1)^{n}x^{n}][/itex]
[itex]+[x-{ }^{n}C_{1}x^{2}+...+{ }^{n}C_{r-1}(-1)^{r-1} x^{r}+{ }^{n}C_{r}(-1)^{r} x^{r+1}+...+(-1)^{n}x^{n+1}][/itex]
[itex]\equiv\sum^{n}_{r=0} [{ }^{n}C_{r}(-1)^{r} + { }^{n}C_{r-1}(-1)^{r-1}]x^{r}[/itex]
The 4th and 5th line seemed a peculiar way of writing it. Were they just trying to demonstrate how the second series is always one power of x ahead?
The last expression seems to require a definition of [itex]{ }^{n}C_{-1}[/itex] which hasn't been defined in the book so I'm guessing I have misunderstood something. Could someone please explain this for me?
Apologies for any typos, I'm using a mobile. Very fiddley.
Mathematics news on Phys.org
That's what it looks like to me - the author is making a step in the calculation explicit.
Do you see how the last line is derived from the one before it?
Notes:
...everything from the third "equivalence" sign to (but not including) the fourth one is all one line of calculation.
Do Bostock and Chandler number their working, their equations?
You likely didn't misunderstand anything, the book just has been incomplete. The book should have mentioned that we define ##{}^nC_m = 0## for ##m< 0## and ##m>n##.
Likes 1 person
Yes.
The last expression seems to require a definition of [itex]{}^{n}C_{-1}[/itex] which hasn't been defined in the book so I'm guessing I have misunderstood something. Could someone please explain this for me?
I think the book is a bit careless there. ##{}^{n}C_{k}## is normally only defined for ##0 <= k <= n##. But the only "sensible" defintiion when ##k < 0## or ##k > n## is zero. If you define ##{}^{n}C_{k}## as the number of ways to choose objects from a set, there are no ways to choose more than n different objects from a set of n, and you can't choose a negative number of objects. If you define it using Pascal's triangle, any numbers "outside" the triangle need to be 0 to make the formulas work properly.
Likes 1 person
The definition being used should be evident by following the derivation though... looking at the coefficient of x^0, probably why the authors felt they could be a bit sloppy there?
Likes 1 person
Thank you so much for clarifying that for me.
The last articulation appears to oblige a meaning of nc−1 which hasn't been characterized in the book so I'm speculating I have misconstrued something. Would someone be able to please clarify this for me?
Expressions of remorse for any typos, I'm utilizing a versatile. Exceptionally fiddle...
This question has already been asked and answered - see post #3.
FAQ: Coefficient of x^r in Expansion of (1+x)(1-x)^n
1. What is the formula for finding the coefficient of x^r in the expansion of (1+x)(1-x)^n?
The formula for finding the coefficient of x^r is nCr * (-1)^r, where n is the power of (1-x), r is the power of x, and nCr is the combination formula (nCr = n! / (r! * (n-r)!)).
2. How do you determine the value of n in the formula?
The value of n is determined by the power of (1-x) in the expansion. For example, if the expansion is (1+x)(1-x)^5, then n = 5.
3. What does the exponent r represent in the formula?
The exponent r represents the power of x that you are trying to find the coefficient for in the expansion.
4. Can the value of r be greater than n in the formula?
Yes, the value of r can be greater than n in the formula. However, the coefficient will be 0 because there will be no term with that power of x in the expansion.
5. How can the coefficient of x^r be useful in solving problems?
The coefficient of x^r can be useful in solving problems involving binomial expansions, such as finding the probability of a certain outcome in a series of events or finding the number of ways to arrange a set of objects. It can also be used in simplifying algebraic expressions and solving equations.
