When can you assume that gravity is the only applied force opposing friction?
In summary: Fnet(x) = n - W(x) = ma --> n - Wcos(theta) = maFnet(y) = f(k) - W(y) = 0 --> f(k) - Wsin(theta) = 0The normal force in that direction is equal to the weight of the skier.
kathyt.25
49
When can you assume that gravity is the only "applied force" opposing friction?
"Determine the stopping distance for a skier moving down a slope with friction with an initial speed of 24.7 m/s. The slope makes an angle of 5.02deg above the horizontal, and assume that μk=0.172."
For this question, I have three variables that I don't have values for -- normal, mass, and acceleration. Since I only have two equations (sum of the forces for F(x) and F(y) directions), I can only have two unknowns for me to solve the problem. Am I supposed to assume that the acceleration is 9.8m/s/s (acceleration due to gravity) in this case?
Fnet = ma
With my method of assuming that a=9.8m/s/s, I then isolated for "m" in each equation.
(1) m = n / [a +gcos(theta)]
(2) m = μ*n / [gsin(theta)]
I then equated both formulas to each other, to solve for the normal, "n".
You might not need the mass--just call it "m" and continue. The normal force can be expressed in terms of the mass.
Definitely not! The acceleration is what you need to find in order to solve for the stopping distance.
Looks like you chose the x-coordinate to be perpendicular to the surface. What's the acceleration in that direction?
Parallel to the surface the acceleration is not zero. That's what you're trying to find.
Usually folks take the x-axis as parallel to the surface, but it doesn't matter. The resulting equations are what matters.
Express the weight, normal force, and friction force in terms of the mass. (And other needed values, of course.)
From the previous post, I just need some clarification on what it means to express the normal force in terms of the mass.
I know that on a non-inclined surface, normal = weight = mass * gravity... but this is an inclined plane. I thought we couldn't assume that normal = m*g?
Right, you can't assume that. Use your equation for Fnet for forces perpendicular to the surface. You'll have to correct it. What must Fnet equal in that direction?
1. When does gravity become the only force opposing friction?
Gravity becomes the only force opposing friction when there are no other external forces acting on an object. This typically occurs in a vacuum or at the surface of a planet where air resistance can be neglected.
2. How does the presence of other forces affect the assumption that gravity is the only force opposing friction?
The presence of other forces, such as air resistance or applied forces, can complicate the assumption that gravity is the only force opposing friction. In these cases, the net force acting on the object must be calculated in order to accurately determine the opposing forces.
3. Can friction ever be the only opposing force?
No, friction can never be the only opposing force. In order for friction to occur, there must be at least two surfaces in contact with each other and an applied force acting on the object.
4. How does the mass of an object affect the assumption that gravity is the only force opposing friction?
The mass of an object does not directly affect the assumption that gravity is the only force opposing friction. However, a larger mass may require a greater applied force to overcome the force of friction.
5. Is the assumption that gravity is the only force opposing friction always accurate?
No, the assumption that gravity is the only force opposing friction is not always accurate. In situations where other forces are present, such as air resistance or applied forces, the assumption may not hold true and the net force must be calculated to accurately determine the opposing forces.
