Transition amplitudes and relation between wavefunctions
In summary, the dipole transition amplitude is a probability amplitude that gives the transition probability. The calculation of the Clebsch-Gordan coefficients needed to find Cn in the conversion of \psi_{nlm_{l}m_{s}} to C_{n}\psi_{nljm_{j}} is a result of group theory, as angular momentum theory (including the addition of angular momenta) is also a result of group theory.
stunner5000pt
1,461
bb] The dipole transition amplitude for the transition (nlm) -> (n'l'm') is given by [/b]
[tex]\int \psi_{n'l'm'}^* \vec{r} \psi_{nlm} d\tau [/tex]
Is the dipole transition amplitude simply a measure of how likely a certain transiton is??
Heres another question
In converting [tex] \psi_{nlm_{l}m_{s}} = C_{n}\psi_{nljm_{j}} [/tex]
my prof said that finding the Cn would involve a rather messy calculation involving group theory... how does that come about?? How does a simple relation like j = l + s bring about something like that??
thanks for your input!
It's a probability amplitude. Its square modulus gives the transition probability.
The Clebsch-Gordan coefficients that you need are a result of group theory. Angular momentum theory (including the addition of angular momenta) is a result of group theory.
Related to Transition amplitudes and relation between wavefunctions
What are transition amplitudes?
Transition amplitudes, also known as matrix elements, are a measure of the probability of a quantum system transitioning from one state to another. They are calculated using the wavefunctions of the initial and final states.
How are transition amplitudes related to wavefunctions?
Transition amplitudes are directly related to wavefunctions through the quantum mechanical principle of superposition. The amplitude for a transition between two states is the product of the wavefunctions for those states.
What is the significance of transition amplitudes in quantum mechanics?
Transition amplitudes play a crucial role in quantum mechanics as they allow us to calculate the probability of a system transitioning between different energy levels or states. They also help us understand the behavior of particles at the quantum level.
How are transition amplitudes calculated?
Transition amplitudes can be calculated using the mathematical formulation of quantum mechanics, specifically through the use of operators and the Schrödinger equation. These calculations involve finding the overlap between the initial and final wavefunctions.
What factors can affect the values of transition amplitudes?
The values of transition amplitudes can be affected by a variety of factors, including the energy difference between the initial and final states, the shape of the wavefunctions, and the strength of the interaction between the system and its environment.
  • Quantum Physics
