Why connected correlation function depends on (x-y) only when <Phi(x)> equal constant
In summary, the connected correlation functions in vacuum quantum field theory are translation invariant, meaning they only depend on the difference of two space-time coordinates. This is due to the translation invariance of the vacuum state, which is preserved if the theory's Lagrangian does not depend on space-time coordinates explicitly. However, if there is spontaneous symmetry breaking, the vacuum state may not be translation invariant, leading to a breaking of space-time translation invariance and changing correlation functions under space-time translations. The scalar condensate, such as in the linear sigma model, is an example of this spontaneous symmetry breaking, resulting in massless particles known as Nambu-Goldstone bosons.
ndung200790
519
Please teach me this:
Why the connected correlation functions depend on the x-y(the difference of two space-time coordinates of two points) only in case the expectation of field(<phi(x)>) is constant(the translation invariance of vacuum state).
Thank you very much in advanced.
You've already answered the question yourself. The correlation or Green's function in vacuum quantum field theory are expectation values of field-operator product with respect to the vacuum state. If the theory is invariant with respect to space-time translations, i.e., if the Lagrangian doesn't depend on space-time coordinates explicitly, the correlation functions are translation invariant, i.e., if you add an arbitrary four-vector to each of its arguments it doesn't change its value, and thus in case of the two-point function (single-particle Green's function or self-energies) it must be a function of the only translation-invariant combination of its two space-time argument you can build, namely the difference of these space-time arguments.
If you have a scalar condensate (e.g., in the linear sigma model or in electroweak symmetry) due to spontaneous symmetry breaking, translation invariance is only preserved if it is space-time dependent. Otherwise the physics at one space-time point is different from that at another (e.g., the pion-decay constant is different at different space-time points if you have a space-time dependent vacuum expectation value of the sigma field), i.e., space-time translation invariance is broken, and your Green's functions are changing under space-time translations.
Thank you very much for your useful answer.By the way,please teach me what is the scalar condensation?
The most simple example is the linear sigma model. It consists of four real scalar fields,
[tex]\Phi=(\sigma,\vec{\phi}).[/tex]
It's Lagrangian reads
[tex]L=\frac{1}{2} (\partial_{\mu} \Phi) \cdot (\partial}_{\mu} \Phi) + \frac{\mu^2}{2} \Phi \cdot \Phi - \frac{\lambda}{4} (\Phi \cdot \Phi)^2.[/tex]
I'm using the west-coast metric (+---), and thus the plus sign in front of the quadratic term is just of the opposite sign to be a proper mass term. What's going on is most easily seen already in the classical limit: The potential has a maximum rather than a minimum at [tex]\Phi=0[/tex], and thus you can not have [tex]\Phi=0[/tex] as a stable equilibrium condition. Quantizing the model, you cannot do perturbation theory around [tex]\langle \Phi \rangle=0.[/tex]
You have to do perturbation theory around a minimum. This is continuous-fold degenerated since the model is symmetric under O(4) rotations in [tex]\Phi[/tex] space, but you can chose any of these minima and do perturbation theory around that one. The usual convention is to take [tex]\langle \sigma \rangle=\sigma_0[/tex] and [tex]\langle \vec{\phi} \rangle=0.[/tex]
The solution for the minimum for [tex]\sigma_0=\text{const}[/tex] is given by
[tex]\mu^2 \sigma_0-\lambda \sigma_0^3=0, \Rightarrow \sigma_0=\frac{\mu}{\lambda}.[/tex]
Now, you plug the ansatz
[tex]\Phi=(\sigma_0+\tilde{\sigma},\vec{\phi})[/tex]
into the Lagrangian. You'll find that you get a theory, which describes one particle with positive squared mass [tex]m^2=2 \mu^2[/tex] and three particles with 0 mass.
This is one of the most simple examples of the spontaneous breaking of a global gauge symmetry. The model described above is the most simple effective model to describe pions, which appear here as the massless states. The vacuum is not symmetric under the full group O(4) anymore, but only under the O(3) rotations of the three last components of [tex]\Phi[/tex]. The masslessness of the pions in this socalled chiral limit is exact to all orders in perturbation theory and is an example for the famous Nambu-Goldstone theorem: There are as many massless "Nambu-Goldstone bosons" in a theory with spontaneous symmetry breaking as the dimension of the symmetry group of the vacuum.
For more details on the linear sigma model, see my notes on QFT
http://theorie.physik.uni-giessen.de/~hees/publ/lect.pdf (p. 187ff)
Ok, but your order parameter is a vector, not a scalar, as asked for by ndung.
Here, "scalar" refers to the space-time properties. The four fields in the linear sigma model are scalar fields. Together they build a real vector in a (real) representation of the chiral group, [tex]\mathrm{SU}(x)_L \times \mathrm{SU}(2)_R,[/tex] in terms of the SO(4), which is locally isomorphic to the chiral group.
BTW: The symmetry breaking I described is in fact the breaking from the chiral group to the isovector symmetry [tex]\mathrm{SU}(2)_V,[/tex] here represented as SO(3), acting on the pion fields.
Very interesting, thank you Hendrik
1. Why is the connected correlation function dependent on (x-y) only when the average value of Phi(x) is equal to a constant?
The connected correlation function, also known as the two-point correlation function, is a measure of the statistical dependence between two points in a physical system. In order for this function to be valid, it is necessary for the average value of the field, Phi(x), to be constant. This is because any fluctuations in the average value would result in a non-uniform distribution of the field, making it difficult to accurately measure the correlation between two points.
2. What is the significance of having (x-y) as the only variable in the connected correlation function?
The fact that the connected correlation function is dependent on (x-y) only means that it is translationally invariant. In other words, the value of the function at a particular point is not affected by the position of that point within the system. This is an important property as it allows for easier analysis and interpretation of the function, and also makes it a useful tool for studying the symmetry and structure of physical systems.
3. Can the connected correlation function be used to determine the average value of a field in a system?
No, the connected correlation function cannot be used to directly calculate the average value of a field in a system. This is because the function is only dependent on the fluctuations of the field, not the average value itself. However, if the average value of the field is known, the connected correlation function can be used to study the fluctuations around this value.
4. How is the connected correlation function related to the concept of correlation length?
The connected correlation function is closely related to the correlation length, which is a measure of the distance over which two points in a system are correlated. In fact, the correlation length can be calculated from the connected correlation function by finding the point at which the function drops to zero. This length scale is important in understanding the behavior of physical systems, particularly in phase transitions.
5. Is the connected correlation function applicable to all physical systems?
The connected correlation function is a general concept that can be applied to a wide range of physical systems. It is particularly useful in the study of systems that exhibit spatial correlations, such as in condensed matter physics and statistical mechanics. However, it may not be as relevant in systems that do not exhibit such correlations, such as in certain types of gases.
  • Quantum Physics
  • Quantum Physics
  • Other Physics Topics
