Net movement of plasma in tokamak
In summary, there are conflicting explanations for the motion of particles in tokamak reactors. According to Wikipedia, particles generally follow the poloidal field lines due to the Lorentz force. However, another source suggests that the results are due to random motion within the plasma, with overall zero net momentum. The reality is that particles are traveling in the same general direction as the field lines, but appear to have random motion due to relativistic effects. Both ions and electrons are confined in the plasma, with the poloidal magnetic field being responsible for confinement. In a TOKAMAK, induced toroidal and poloidal electric fields create a high current, resulting in heating of the plasma through collisions. However, Ohmic heating is not enough to reach the
nuiluidwde
Hi, I've got conflicting impressions on the motion of particles in tokamak reactors. Wikipedia says that they generally follow the poloidal field lines due to the Lorentz force, whilst another site claimed that the promising results were due to the random motion of the particles within the plasma, traveling in many different directions, suggesting that overall the plasma is almost static with zero net momentum.
Is the reality that they are all generally traveling fast in the same general direction of the field lines, either clockwise or counterclockwise, but that relativistically they appear to have random motion, just as on Earth we are all traveling east at hundreds of miles an hour due to the rotation of the earth, but relativistically we appear to all be moving in different directions?
Thanks, I hope my question makes sense :smile:
There is random motion and net currents in a magnetically confined plasma.
Neutrals (neutral atoms) simply leave the plasma.
Electrons and nuclei/ions move randomly, as well as drift in a toroidal direction, and those near the periphery follow the magnetic field lines, which are a vector sum of the various fields. Electrons (-) and nuclei/ions (+) travel/drift in opposite directions, e.g., in the toroidal current.
Plasma exclude (acutally attenuate) externally apply magnetic fields, so the magentic field strength falls off from the surface inward to the plasma.
Astronuc, since the plasma is composed of both + and - ions, how are both confined at the same time? Something to do with the applied current in the plasma? My knowledge of magnetic fields and the structure of the reactor is limited, so I apologize if it is because of something obvious.
Thanks Astronuc! I'll look into those links.
If we talk about TOKAMAKs there are three types of magnetic fields:
-poloidal created by induced toroidal current
-toroidal created by winding around vacuum chamber
-vertical mag field excluding "baloon effect"
Namely poloidal mag field is responsible on confinement.
Superposition of poloidal and toroidal creates so called "rotary transformation" by which power lines rotate around torus with some step. That step is different at different distance from torus axis and this configuration called "shir".
Such a configuration interferes with development the most types of instabilities.
The balloon effect caused by that the external torus area тора exceeds internal and as plasma kinetic pressure is the same, torus tries to increase its diameter.
Also the vertical magnetic field is created aspiring to reduce diameter. By this way the equilibrium can be achieved.
Thanks Joseph. I understand how something like a Fusor or Polywell works, but when it comes to multiple types of magnetic fields my understanding is sorely lacking. I know that the 2 charges experience opposite directions in force, so are the magnetic fields set up so that one confines one type and the other confines the other?
Wow :D Thanks for everyone's contributions, I understand a lot more now and those links were great.
I've got another question now, in a cyclotron, is the majority of the particle energy supplied by the surrounding magnetic field or the wave function between the Dees? Are there any equations linking the accelerated particle energies and the input power, or is it as simple as say a 15kV results in a 15 keV energy per elementary charge?
Interesting, I just read about the magnetic mirror effect. I did not realize that both + and - charges both tend to bounce away from a higher strength magnetic field.
I think the acceleration is solely due to the electric field.
If we talk about TOKAMAK, first of all there is induced toroidal (cyclic) electric field with intensity sufficient for discharge in gas. Discharge and ionization.
When ionized electrons in that electric field move at one direction and ions to the opposite. So, very high current is created - about 10-20 millions amperes in latest TOKAMAKs. But due to much lower mass firstly the main carrier of that current are electrons.
That current creates poloidal mag field in which plasma compressed in radial direction (pinch) increasing number density of particles and so collisions intensity.
Then due to multiple collisions kinetic energy of arranged motion of particles transferred to random (chaotic) motion - in the other words growth of temperature. This is so called "Ohmic heating". From the beginning the temperature of electron gas is much higher than ion's. But then those temperatures go to alignment.
But only Ohmic heating can not increase plasma temperature till 10-15keV required for ignition of self-sustained process.
Because by increasing of temperature also increases the conductivity of plasma. The second factor is growing braking radiation (Bremstahlung). And at certain temperature energy input into plasma through induced electric field will become equal to energy losses mainly via Bremstahlung. And so, Ohmic heating allows to reach only about 1 or few keVs.
For reaching higher temperature two other ways of heating are used: RF heating utilizing cyclotron resonance and injection into plasma of beam of neutrals (mostly deuterium). Neutrals because it is difficult to inject charged particles through mag field’s lines from externally.
What is the net movement of plasma in a tokamak?
The net movement of plasma in a tokamak refers to the overall direction and speed of the plasma particles within the tokamak chamber. This movement is influenced by various factors such as the magnetic field, heating mechanisms, and particle collisions.
How is the net movement of plasma controlled in a tokamak?
The net movement of plasma in a tokamak is controlled by adjusting the strength and direction of the magnetic field, as well as by introducing heating mechanisms to increase the temperature and velocity of the plasma particles. These controls help to maintain stability and prevent the plasma from escaping the tokamak chamber.
What impact does the net movement of plasma have on tokamak performance?
The net movement of plasma plays a crucial role in determining the efficiency and stability of a tokamak. If the plasma particles are moving too fast or in an uncontrolled manner, it can lead to instabilities and disruptions in the plasma, affecting the performance and potentially damaging the tokamak.
How is the net movement of plasma measured in a tokamak?
The net movement of plasma in a tokamak can be measured using various diagnostic tools such as magnetic sensors, interferometers, and spectroscopes. These tools provide data on the plasma density, temperature, and velocity, which can be used to analyze the net movement of plasma within the tokamak.
What are some challenges in controlling the net movement of plasma in a tokamak?
One of the main challenges in controlling the net movement of plasma in a tokamak is maintaining stability and preventing disruptions. This requires precise control of the magnetic field and heating mechanisms, as well as a thorough understanding of the complex interactions between the plasma particles and the tokamak chamber. Additionally, the high temperatures and intense radiation within the tokamak pose safety and maintenance challenges.
  • Nuclear Engineering
  • STEM Academic Advising
  • High Energy, Nuclear, Particle Physics
