What Causes the Shapiro Time Delay in Radar Signals?
In summary, Shapiro time delay experiments observe a delay in the round trip signal time of radar signals sent to distant planets on the opposite side of the sun due to gravitational effects. This delay is caused by the longer path the signal must take due to deflection by the sun's gravitational field, known as the geometric delay. The Shapiro time delay not only includes this geometric delay, but also the effects of gravitational time dilation. While the speed of light near the sun may vary according to the Schwarzschild coordinate system, it is a fundamental prediction of General Relativity that the local speed of light is constant. Measuring the speed of light using coordinates is not a reliable method, as the coordinates themselves are not true distances but simply a way to describe
yuiop
3,962
Can someone clear up what is observed in Shapiro time delay experiments.
As I understand it a delay is seen in the round trip signal time of a radar signal sent to a distant planet on the opposite side of the sun due to gravitational effects. The signal path would be longer than the straight line path to the calculated position of the planet in its orbit due to deflection by the gravitational field of the sun. This longer path would introduce a geometric delay. Would it be right to assume the Shapiro time delay is a measured delay over and above the the simple geometric delay?
As I understand it, the Shapiro time delay will include both the longer geometric path, and the effects of gravitational time dilation.
Yes, there is some additional delay due to the non-straight path of light. But it is much smaller than the main effect. In my opinion, the main origin of the Shapiro delay is the fact that light propagates slower in the vicinity of massive objects.
Eugene.
From the vantage point of the Earth observer, the speed of light passing near the sun's surface of radius r is c[(1-2GM/(c^2)r] but the local speed for an infinitely small physical distance and time is still c.
This might be true, however I don't think the speed of light in different gravitational potentials was ever measured with sufficient accuracy. We know for sure that the rate of all physical processes (e.g., the frequency of atomic clocks) slows down in the gravitational potential according to f' = f[1-GM/(c^2)r]. This fact can be reconciled with the variation of the speed of light c' = c[1-2GM/(c^2)r] if we assume that all distances decrease according to d' = d[1-GM/(c^2)r].
Eugene.
Eugene.
While direct tests of the speed of light may or may not have been done to any particular degree of accuracy, it is a fundamental theoretical prediction of General Relativity that the local speed of light is constant.
If the local speed of light were not constant, General Relativity would be falsified.
General Relativity to date has a fairly impressive amount of experimental support, certainly it does a good job of modeling transit times and light paths in the solar system, including the shapiro effect.
Note that "the speed of light" near the sun as seen from Earth is not even measurable unless one devises some synchronization scheme. What Yogi computes above is the "coordinate speed" of light in the Schwarzschild coordinate system, i.e. dr/dt, where r is the Schwarzschild r coordinate, and t is the Schwarzschild t coordinate. This can be and usually is interpreted as the coordinate speed of light viewed from an "observer at infinity", (so Yogi is talking about the Earth as if it were infnitley far away from the sun here), but there are conceptual ambiguities about talking about speeds at distant events.
Measuring dr/dt is not really a very fundamental way to measure speed, because (among other reasons) r is not really a distance measure, it is just a coordinate. The situation is rather similar to someone who claims that the speed of naval ships increases near the poles of the earth, because d(longigutude)/dt is greater, i.e. the ship can cover one degree of longitude in a shorter time near the poles than it can at the equator. If you look at the actual local speed of the naval ship relative to the ocean, it is constant - the apparent increase in d(longitude)/dt near the poles is an artifact of the curvature of the Earth.
Philosphically, lattitude (usually denoted by [itex]\phi[/itex]) and longitude (usually denoted by [itex]\lambda[/itex]) on the Earth are coordinates, not distances. The metric of the curved Earth's surface converts small changes in these coordinates into actuall distances. Because the Earth's surface is curved, the metric coefficients are not constant, assuming the Earth's surface is constant one can write this metric as
[tex]ds^2 = r^2 d\lambda^2 + r^2 \cos^2 \, \phi d \phi^2[/tex]
(I've taken the liberty of assuming one converts from degrees to radians rather than write out the conversion explicitly)
here ds is the distance on the Earth's surface, and [itex]\phi[/itex] and [itex]\lambda[/itex] are the lattitude and longitude as previously mentioned.
Compare this to the Schwarzschild metric: it's very similar as far as the angular terms go. (Note that equator of the Earth is [itex]\phi=0[/itex] while the equator in Schwarzschild coordinates is [itex]\theta=\pi/2[/itex].)
Similarly, the local speed of light is a constant everywhere - what could be called the "change" of dr/dt with r is an artifact of the curvature of space-time, not an physical change in speed, just as the change in [itex]d\lambda/dt[/itex] for our naval ship as it got closer to the poles (i.e. as [itex]\phi[/itex] increased) was.
The confusion comes about in large part by not distinguishing between coordinates: on the Earth, lattitude and longitude, in space: Schwarzschild r, theta, phi, and t coordinates, and distances.
Distances are computed from small changes in the coordinates via the metric. Note that in relativity, one actually computes the value of the space-time interval.
Hi pervect,
you are correct that my post about the varying speed of light is not consistent with the ideas of general relativity. I simply wanted to note that the Shapiro time delay can be explained without GR's assumption of the geometry change in gravitational fields. An alternative explanation - that the speed of light slows down according to
[tex] c' = c(1-\frac{2GM}{c^2 r}) [/tex]
also works.
Eugene.
http://xxx.lanl.gov/abs/astro-ph/0006423 takes a somewhat similar point of view, I think. We like to talk about peer-reviewed theories here. This is a peer reviewed theory that I think (hope) is similar to what you are talking about.
It's also an example of a non-geometrical interpretation of something that is locally the same as GR. Unfortunately, this is not quite the same as being equivalent to GR.
It is a different theory because it doesn't necessarily have the same global topology as GR does.
The above paper unfortunately doesn't go into or even mention the topology issues. There used to be some criticism of this theory, informally called "funky fields in a Minkowski space-time" that I would refer people to on the WWW, but it disappeared :-(. You can probably find some past PF discussions if you google. I think the idea has promise for getting rid of pesky time machines in GR, but that's a personal opinion, and there are still some unanswered questions as to how one deals with the topological issues, and it is also not quite clear how the theory deals with black holes. (Do said "funky fields" become infinite on the event horizon? Or what?).
Thanks for all the thoughtful replies and sorry for the delay replying (family issues).
We all seem to be agreed there would be a measurable time delay compared to a constant speed of light over the the coordinate distance. Yogi and Eugene interpret the cause as due to the speed of light slowing down in a gravitational field while Pervect has the more formal point of view that the speed of light is constant in a gravitational field when measured in 4 dimensional curved spacetime rather than the 3 dimensional space coordinates we are used to.
meopemuk said:
Hi pervect,
also works.
Eugene.
Shouldn't that be [tex] c = c'\sqrt(1-\frac{2GM}{c^2 r}) [/tex] ?
Eugene.
Did you intend f' = f[1-GM/(c^2)r] (the excellent approximation of f' = f sqrt[1-2GM/(c^2)r] in a week field that is the first term of a binomial expansion) or f' = f[1-GM/(c^2)r] ?
This aproximation has the interesting property that the solutions for r < GM/(c^2) do not involve imaginary numbers. It also implies negative gravity and negative time for r < GM/(c^2). I wonder if any real experiments have been carried out that can distinguish f' = f[1-GM/(c^2)r] from f' = f sqrt[1-2GM/(c^2)r] ?
Eugene.
Assuming we all agreed that the speed of light as measured by a local observer is always c then a slowing down of light as observed by a distant observer would be more likely to be reconciled with an increase of horizontal distances? For example, say we had a fibre optic that took one second for a photon to traverse in a very weak gravitational field. If we lowered that optical fibre ruler into a strong gravity well where the gravitational time dilation factor was 2 then a photon would take 0.5 seconds to traverse that ruler as measured by a local observer with slow clocks (assuming no length change). If the ruler had "length dilated" to twice its proper length, then the local observer would still measure the time taken to traverse the ruler as one second and the speed of light would still appear to be c to the local observer.
I would like to suggest a thought experiment with 2 scenarios to explore the possibilities and further clarify what is thought to be happening in a strong gravitational field.
Thought experiment:
Suppose we had optical fibre ring that had a radius of [tex] \frac{1}{2\pi} [/tex] light seconds when the ring is far from any gravitational fields. A device is spliced into the ring that can inject a photon into the optical fibre ring and times the interval for the photon to complete one loop and this should presumably be one second. R is calculated by a distant observer from the angle subtended by the ring when viewed through a telescope and the distance of the observer from the ring. At this point both local and distant observers agree on the radius of the ring, the apparent speed of light and that the circumference is given by [tex] {2\pi r} [/tex] .
Now suppose we had a convenient (non rotating) gravitational body which just happens to be a snug fit for our optical ring around the equator of the body. Assume the mass of the body is such that the gravitational time dilation factor is 1.25. Also assume there is atmosphere that would give rise to optical effects. Please ignore practical considerations such as this body is probably a neutron star and all local instruments and observers would be crushed ;) What would the local and distant observers measure?
Scenario A: (Assuming horizontal gravitational length dilation).
Here we assume the circumference of the ring has expanded by a factor of 1.25
The local observer measures the time for a photon to travel within the optical fibre ring as one second due to his slow clocks relative to the distant observer.
The distant observer measures the photon as taking 1.25 seconds to travel a distance of 1.25 light seconds. Both agree on the same number for the speed of light in metres per second so neither sees an apparent slowing down of the speed of light in a gravitational field.
Scenario B: (No length dilation)
The distant observer measures the circumnavigation time of the photon within the optical fibre ring on the equator of the gravitational body as 1.25 seconds. From the distant observers point of view the circumference is 1 light second so the speed of light seems to have slowed down to 0.8c
If the distant observer defines distance by light travel times then he could say that that the circumeferance of the body is not given by [tex] {2\pi r} [/tex]
The local observers on the surface of the body (with the slower clock) measures the photon travel time as 1 second and so the local speed of light appears to be c to them.
Note: Self gravitational lensing
I have not taken self gravitational lensing into account in either scenario. It should be apparent that the strong gravitational field of the body will magnify the apparent size of the body to a distant observer. The body and ring will appear to subtend a larger angle in the telescope the distant observer. I can find formulas for the amount light is bent by a gravitational field as it passes a massive body. However I can not find a formula for how much a body would be appear to be magnified by its own gravity. It may be possible that when the distance of the observer from the body, the mass of the body and the gravitational dilation factor on the surface of the body and at the location of the distant observer (assuming he is not at infinity) are all taken into account then the optical magnification would make the speed of light be c to both local and distant observers. For example, in scenario B the distant observer would see the radius and circumference of the body optically magnified by a factor of 1.25 so that the circumnavigation time of 1.25 seconds would be consistent with an unchanged speed of light even to the distant observer.
So, is scenario A or B (or neither) more consistent with the accepted wisdom?
Does anyone have a formula for self gravitational lensing of a body?
(My interpretation is that it would be something like [tex] s = s'\frac{\sqrt(1-\frac{2GM}{c^2 d}}{ \sqrt(1-\frac{2GM}{c^2 r}} [/tex] where s is the self gravitational optical magnification of the body and d is the distance of the observer from the body)
In measuring r and d I have assumed there is no dilation or contraction of length in the vertical direction in a gravitational field. Is that a reasonable assumption?
Thanks :smile:
Hi kev,
I used f' = f[1-GM/(c^2)r] instead of f' = f sqrt[1-2GM/(c^2)r] simply because (as far as I know) all existing experimental tests have precision of not better than [itex]c^{-2}[/itex]. So, keeping only the first order in [itex]c^{-2}[/itex] seems to be a prudent approach.
Your ideas about experimental tests for gravity effects on length and speed of light look interesting, however (you would probably agree) completely unrealistic. Is it possible to modify these tests, so that they become realizable with modern technology?
Eugene.
meopemuk said:
Hi kev,
I used f' = f[1-GM/(c^2)r] instead of f' = f sqrt[1-2GM/(c^2)r] simply because (as far as I know) all existing experimental tests have precision of not better than [itex]c^{-2}[/itex]. So, keeping only the first order in [itex]c^{-2}[/itex] seems to be a prudent approach. Eugene.
Hi Eugene,
In 2005 I posted a document on the web that conjectured "What if f' = f[1-GM/(c^2)r] if the true relationship rather than the conventional f' = f sqrt[1-2GM/(c^2)r] ?" As you point out the accuracy of existing tests can not rule out f' = f[1-GM/(c^2)r] (as far as I know). In strong gravity fields such as near a black hole the differences become significant and give rise to a different type of black hole. Using f' = f[1-GM/(c^2)r] the event horizon is half the conventional Schwarzschild radius. Below the event horizon gravity is negative giving rise to a solid shell with radius GM/(c^2) rather than the singularity of the conventional interpretation. Quantum fluctuations at the surface of the shell would allow radiation from the surface of black hole but that radiation would be at very long wavelengths and very faint due to extreme time dilation at the surface. (The alternative black hole would still be a very dark object) Gravitational lensing due to a black hole would probably be less than the conventional interpretation. One interesting thought is that if all the mass of the known universe was contained within a Planck radius there would extreme negative repulsive gravity giving rise to a simple model of the inflation/expansion of the big bang. The negative time dilation at such extremes in this model is not a problem as it is the cause of negative gravity. Objects fall away from each other instead of towards each other in negative time. Anyway, I have not posted a link to my document as I admit it is all idle speculation and conjecture. (Just an interesting thought)
Eugene.
I agree the thought experiments are unrealistic (as are most thought experiments) and being non local there is no possibility of testing them in a lab. However observations of X ray emissions from a black hole accretion disc and possibly measurements of red shifted emissions in the radio spectrum from nearer the event horizon of the black hole may give an indication of the actual "radius" of the black hole. Comparing these measurements to the black hole mass calculated from the orbit of a companion binary star may give some indications of physics at work in these extreme gravitational fields. Quite possibly, this has already been done.
In my last post I asked a lot of questions (perhaps too many).
To keep things simple the main question I am asking at his point is:
Do objects length contract or expand in a strong gravitational field as measured by a distant observer ...or not?
Any expert in GR should be able to answer that simple question :P
A Few Pointers
What textbooks have you studied so far? I'll hopefully assume that you are familiar with the contents of a standard textbook such as O'Hanian and Ruffini, Gravitation and Spacetime, which has a nice exposition of the Shapiro time delay effect. For the reader's convenience I'll review the essential ideas here.
Correct. Consider the Earth, Venus, and the Sun. The experiment is best performed when all three are almost aligned, but Venus is on the other side of the Sun relative to the Earth. Then a radar pip is sent from Earth toward Venus, passing very near the Sun; it is reflected from Venus and returns to Earth, again passing very near the Sun.
Idealize Earth and Venus to have neglible mass, i.e. imagine that the ambient gravitational field is due to the Sun. This suggests treating the problem in the (exterior of the) Schwarzschild vacuum solution by considering two world lines representing the motion of the Earth and Venus as test particles. Since the round trip takes on the order of ten minutes we can even idealize them as static test particles. The problem is now reduces to studying null geodesics connecting the two world lines. By symmetry, we can consider the two legs of the journey to be almost identical.
The line element written in the standard Schwarzschild chart is
[tex]
ds^2 = -(1-2m/r) \, dt^2 \, + \, \frac{dr^2}{1-2m/r} \, + \, r^2 \, \left( d\theta^2 + \sin(\theta)^2 \, d\phi^2 \right),
[/tex]
[tex]
-\infty < t < \infty, \; 2 \, m < r < \infty, \; 0 < \theta < \pi, \; -\pi < \phi < \pi
[/tex]
The world lines of static observers in this chart have the form [itex]r=r_0, \, \theta=\theta_0, \, \phi=\phi_0[/itex]. The spatial hyperslices orthogonal to such observers have the form [itex]t=t_0[/itex] and they are all identical (by the time translation symmetry of the Schwarzshild vacuum). The null geodesics are planar, so without loss of generality we can suppress the coordinate [itex]\theta[/itex] by setting [itex]\theta=\pi/2[/itex] (the locus of the equatorial plane).
If we project the null geodesic arc representing outward leg of the journey of the radar pip into [itex]t=0[/itex], we obtain a curve which I'll call "the path". It is the projection of a null geodesic in spacetime, but it is not a geodesic in the metric on t=0 which is induced by restricting the Schwarzschild metric tensor to this hyperslice (with [itex]\theta[/itex] suppressed):
[tex]
d\sigma^2 = \frac{dr^2}{1-2m/r} \, + \, r^2 \, d\phi^2, \; 2 \, m < r < \infty, \; -\pi < \phi < \pi
[/tex]
This induced metric can be considered a perturbation of the usual polar coordinate chart for the euclidean plane, and also a good approximation to it, in the region we are considering (outside the surface of the Sun).
The path appears to be "bent" slightly as it passes near the origin (the location of the Sun). As everyone knows, extending the path to infinity in both directions we get a angle between two asymptotes, which Einstein computed ("light bending"). The two asymptotes in fact are rather close to the path itself, so to simplify the computation we can (subject to justification upon demand!) treat the path as two line segments.
We can write any straight line segment in a polar chart in the form [itex]R = r\, \cos(\phi)[/itex], where R is the distance of closest approach to the origin. Differentiating gives [itex]r \, d\phi = \cot(\phi) \, dr[/itex] and plugging this relation into the line element of the Schwarzschild vacuum (still working in the equatorial plane) and setting [itex]ds^2 = 0[/itex] (since we are working with a null geodesic arc) gives
[tex]
dt = \frac{r}{r^2-R^2} \left( 1 + 2m/r - 2mR/r^3 \right) \, dr \; + \; O(m^2)
[/tex]
Now suppose that the Earth is at [itex]r=R_1[/itex] (angle irrelevant) and integrate from [itex]R_1[/itex] to [itex]R[/itex]. Proceding similarly for [itex]R[/itex] to [itex]R_2[/itex], where Venus is at [itex]r=R_2[/itex] (angle irrelevant), and adding, we obtain an expression consisting of the flat spacetime "height" (travel time) of our broken null geodesic path, namely [itex]\sqrt{R_1^2-R^2}+\sqrt{R_2^2-R^2}[/itex], where of course [itex]2 \, m \ll R \ll R_1, \, R_2[/itex], plus some correction terms, of which the largest is a logarithmic term. (Closer examination would show that it overwhelms the small errors introduced by the broken line approximation.)
By symmetry, the return leg should give the same result, so twice the logarithmic correction term gives the desired time delay. This is the increased time it takes for the round trip journey, as measured by an ideal clock on Earth, in case the radar pip travels near the limb of the Sun, as compared to when it does not. It's a very concrete effect!
Here's a pointer for your original question: suppose we model bending a paper clip using some one parameter family of curves. The tip moves quite a bit as we vary the parameter, but the change of length due to the bending is comparatively modest.
To find out, and also to justify the broken line approximation, compute the length of
  • a straight line path "from Earth to Venus" in [itex]t=0[/itex], using the euclidean metric or the induced metric,
  • the broken line path, likewise,
  • the actual path, likewise
(I'll let you attempt this before I say more.)
This is the same misconception which I just characterized as a FAQ in another thread! Time does not slow down and distances do not shorten! (Neither of these claims even makes sense.) Rather--- well, see [post=1181763]this post[/post]. Well, ditto Pervect generally :wink:
kev, I urge you to simply ignore what meopemuk said; IMO he's adding confusion, not clearing it up.
kev said:
For example, say we had a fibre optic that took one second for a photon to traverse in a very weak gravitational field. If we lowered that optical fibre ruler into a strong gravity well where the gravitational time dilation factor ... Now suppose we had a convenient (non rotating) gravitational body which just happens to be a snug fit for our optical ring around the equator of the body. Assume the mass of the body is such that the gravitational time dilation factor is 1.25...Here we assume the circumference of the ring has expanded by a factor of 1.25
Careful now! I've seen even professional physicists fall into fallacy with this kind of thinking :frown: The basic problem is that it is rarely straightforward to compare two objects in two different spacetime manifolds and to declare these objects to be "equivalent". IMO you need to think much harder about your thought experiments. For example, your ring cannot remain rigid when you "lower" it, so you need to think about how it responds to the changing stresses.
Due to the difficulty of nonlinear mathematics, approximations are often necessary to make even limited progress. Unfortunately, approximation is a tricky art form and this is where fallacies most often seem to creep into "mathematical physics discourse". Unfortunately for the present context, approximations which are somewhat tricky even in flat spacetime often become much trickier in curved spacetimes.
There are in fact a number of "fiber optic" thought experiments offered in arXiv eprints, some of which IMO are misleading and have led to incorrect conclusions. Some authors are much more careful than others; preprints posted to the gr-qc section seem to exhibit a particularly large range of quality :rolleyes:
Yes, IMO meopemuk is confusing you and leading you away from your original question, which at least makes sense to me.
All that stuff meomepuk told you about length shortening and time slowing is just wrong. Gtr says no such thing. (See any good textbook.) The best answer to this question is that it doesn't make sense. It's like asking: "In the game of baseball, when the batter turns up an ace of spades, does that result in an automatic advancement of the player holding the office of second base to the office of first base?" It sounds like a reasonable question, but only if you know nothing about baseball!
Let me see if you would agree with the following logic:
The claim is that from the point of view of distant observer D objects in the gravity field (F) have the following properties:
1. All clocks go [1+GM/(c^2)r] slower, i.e., the duration of one F second is equal to [1+GM/(c^2)r] D seconds
2. All objects become shorted, i.e., what F observer perceives as 1-meter rod, the D observer sees as a [1-GM/(c^2)r] meter rod
3. Light is slower in the gravitational field, i.e., observer D measures the speed of light near observer F as c[1-2GM/(c^2)r], where c is the speed of light in the vicinity of D.
If these conditions are satisfied, then measurements of observer F would also yield the speed of light as c. If F takes a rod of 300.000.000m long (which, according to D is shorter than necessary) and sends a light pulse (which, according to D is slower than usual) along it, then signal would arrive to the other end exactly in one F-second (which, according to D is longer than normal). So, both D and F would measure the speed of light as 300.000.000 m/s in their local frames.
Eugene.
Please avoid needless muddling this thread
... All clocks go [1+GM/(c^2)r] slower
... All objects become shorted... Light is slower in the gravitational field
Wrong, wrong (even by your own view since you forgot about radial versus nonradial orientations), wrong. GTR says nothing like this. Meopemuk, IMO you are not helping here.
kev, to state the obvious, it makes good sense to master the mainstream view before exploring/debunking fringe viewpoints (should you desire to do that).
Chris Hillman said:
Time does not slow down and distances do not shorten! ...GTR says nothing like this.
I never claimed that what I said is a part of GTR. I simply looked at experimental observations and tried to understand them without prejudice in a simplest possible model.
I wouldn't say that "time slows down" in the gravitational potential (because I don't know what's the meaning of the expression "speed of time"). However, it is well established that identical clocks run slower in the gravitational potential than far away from it (e.g., the Pound-Rebka experiment, GPS,...). This difference in the clock rates is described well by formula
[tex] T' = T(1+\frac{GM}{c^2r}) [/tex]
where T' is the period of one clock tick in the potential.
It is also known that light takes longer time to propagate between two points (e.g., Earth and Venus) if there is a massive body (Sun) on its way. This Shapiro time delay can be explained within GTR, as you demonstrated. But one can offer a simpler explanation as well. One can simply assume that the speed of light depends on the gravitational potential as
[tex] c' = c(1-\frac{2GM}{c^2r}) [/tex]
(independent on the light direction) It can be shown that the numerical value of the Earth-Venus-Earth time delay comes out exactly as in GTR.
Another fact is that the speed of light appears the same to observers in different gravitational potentials. All these facts can be reconciled by the assumption that the length of any rod decreases in the potential as
[tex] d' = d(1-\frac{GM}{c^2r}) [/tex]
The slowing-down of clocks and the reduction of the speed of light can be explained within a simple Newton-like theory of gravity, where gravitational interactions are distance- and velocity-dependent. Of course, this theory has nothing to do with GTR, and doesn't belong to the mainstream. However, in contrast to GTR, it is perfectly compatible with quantum mechanics, so, in my opinion, it can't be dismissed lightly.
I have no idea how to explain the shortening of lengths in the field. I think it would be great to design an experiment to show whether this length shortening exists or not. This question makes sense no matter which theory of gravity is correct. And it would be a great independent check on the general theory of relativity. Here I agree with kev.
Eugene.
It would be very helpful if you found peer-reviewed papers and/or respectable popularizations with a viewpoint similar to your own, and pointed them out.
http://xxx.lanl.gov/abs/astro-ph/0006423 might be a place to start. However, it's at a level that I wouldn't want to throw it at the average lay person. It also is arguably flawed, to boot, though I think it's interesting nonetheless for the advanced reader. It would unfortunately probably only confuse someone who didn't already know quite a bit about GR :-(.
It's problematic with respect to PF guidelines to promote ideas unless they've been published in a peer-reviewed journal. Because GR is very technical, I think that respectable popularizations are also acceptable.
It's also very handy to be able to point interested readers at respectable published sources. They can usually explain things in a lot more depth than a post can, and they are also something that interested readers can point to when *they* want to talk about the topic with someone else.
Eugene.
I agree that the non-straight path of light is much smaller than the main effect.
But the space can be curved (stretched or compressed) even if it is straight
for example, rubber band can be stretched without bending
You can say that space is flat but ruler shrinks in gravitational field
Anyway, if you measure the length of the path with rulers, you definitely need more rulers
In my opinion, if you ignore the curvature of space, you will get only half of the Shapiro delay
meopemuk said:
Hi pervect,
also works.
Eugene.
It's perfectly OK to say the speed of light slows down and ruler shrinks in gravitational field. But the prediction must agree with measurement
In the book, Black Holes & Time Warps (page 400), Kip Thorne says:
"What is the real , genuine truth? Is spacetime really flat, or is it really curved?
To a physicist like me this is an uninteresting question because it has no physical consequences. Both viewpoints, curved spacetime and flat, give precisely the same predictions for any measurements"
Thought Experiment 2
As a layperson this is the sort of answer I am looking for. We can argue forever about the philosophy behind the physics, but supporters of a given theory should be able to agree on what would be measured in a given experiment. Some people (like me) might refer to "if you measure the length of the path with rulers, you definitely need more rulers" as length contraction (informally) while others like Chris Hillman would say "All that stuff meomepuk told you about length shortening and time slowing is just wrong. Gtr says no such thing. (See any good textbook.) "
(I do not know if Meomepuk is right or wrong but he is at least trying to discuss what would be measured which is what I am trying to find out in this post)
------snip---- "
I am a little confused here. Are you now saying rulers do not shrink in a gravitational field? This seems to contradict your previous post. If you need more rulers to measure a given path in a gravitational field than you would require to measure the same path in a non gravitational context then surely one interpretation is that rulers have shrunk?
Anyway, in an early post I posed a though experiment that involved a fibre optic ring. Chris Hillman raised many objections to this thought experiment mainly due to the physical properties of a fibre optic in "different spacetime manifolds". I have now thought of a similar experiment that eliminates the requirement to use a fibre optic. It works like this:
Thought experiment 2:
Place a tape measure in space, far from any significant gravitational field. A clock is placed at one end and a mirror at the other end. The time for the two way trip of a light pulse from the clock to mirror and back to the clock is measured as 200 seconds. We can assume the tape measure is 100 light seconds long. We now wrap the tape measure around the equator of a convenient gravitational body and the two ends meet exactly in the same place. Conveniently we discover that the body has a mass exactly equal to R*(c^2)/3/G. In other words the radius of the body is the same as the photon sphere radius for that mass and density. A photon sent from the clock at the start of the tape measure will orbit the body without any need for a fibre optic to guide it and return to the clock.
a) What period will be measured by the clock on the surface of the body for one orbit of the light pulse around the body?
b) What period would be measured by the clock of a distant observer.
For the pedantic:
The gravitational body is non rotating and perfectly spherical. There is no atmosphere around the gravitational body. The original measurement of the tape measure was made in a inertial frame i.e. non-accelerating. The clocks are as near ideal as can be made. The "distant observer" is sufficiently far from the surface of the body that the gravitational field is assumed to be negligible.
Also, would the surface observer and distant observer agree on the measured geometrical and gravitational radius of the body, if we ignore strictly optical effects?
(In an early post I discussed how a distant observer would see a greater optical radius for the body due to self gravitational lensing)
Any decent theory should have testable predictions and therefore be able to predict what would be measured. Anyone claiming to understand GR should be able to give a precise answer in seconds to questions 2a and 2b.
Place a tape measure in space, far from any significant gravitational field. A clock is placed at one end and a mirror at the other end. The time for the two way trip of a light pulse from the clock to mirror and back to the clock is measured as 200 seconds. We can assume the tape measure is 100 light seconds long. We now wrap the tape measure around the equator of a convenient gravitational body and the two ends meet exactly in the same place. Conveniently we discover that the body has a mass exactly equal to R*3*G/(c^2). In other words the radius of the body is the same as the photon sphere radius for that mass and density. A photon sent from the clock at the start of the tape measure will orbit the body without any need for a fibre optic to guide it and return to the clock.
100 seconds. Note that ideal rigid bodies (ideal tape measures) don't actually exist, but since the tape measure isn't under any stress, it doesn't really matter in this case. If you wanted to be formal, I think that you could specify that the tape measure is "Born rigid.
b) What period would be measured by the clock of a distant observer.The gravitational body is non rotating and perfectly spherical. There is no atmosphere around the gravitational body. The original measurement of the tape measure was made in a inertial frame i.e. non-accelerating. The clocks are as near ideal as can be made. The "distant observer" is sufficiently far from the surface of the body that the gravitational field is assumed to be negligible.
You forgot one rather important point. How do you define the "period according to a distant observer"?
The purist POV is that this is a coordinate dependent quantity, it depends on what coordinates the distant observe adopts. The period according to a distant obserer would just be the difference in the time coordinates he adopts for the two events. This could be any number.
Now, there are some logical choices of coordinate system, or operational methods, that one can use in this particular case to define what one might mean by "the period of a distant observer". One could, for example, have an omnidiriectional light flash emitted which reaches the distant observer along a radial path.
Then, when this light pulse returns to its starting point, a second omindirectional light flash is emitted which also reaches the distant observer.
The interval along the distant observers worldline, according to his clock, is now a proper time measurement rather than a coordinate time measurement. This makes the answer to this problem independent of the coordinate system. It's not just the difference between two coordinates, it's an actual proper time measurement of a particular clock.
The reason that this approach works is that the "trip time" of the photon from the surface to the distant observer is expected to be constant, because the geometry is static. If the geometry wasn't static, this approach wouldn't work.
I've sort of skipped over the fact that there could be multiple paths (multiple flashes) observed from the single original flash that take different paths to the remote observer. The argument about the stationary aspect of the geometry still applies, however, as long as we can make sure by some means that the comparison process involves comparing two flashes that take the same path through the stationary geometry.
In this particular problem many of these side issues are not fundamentally important, but if/whenyou try to extend the result to non-static geometries, they become crucial.
BTW, the answer to your second question making these assumptions is 173 seconds, unless I've made a numerical error.
Yes
Yes, yes
Agreed
Hi Pervect,
Thanks for keeping the conversation at a level us mere mortals can understand (really, no sarcasm intended :wink: ) I agree with your thoughts on how a distant observer would measure the orbital period. Perhaps the method could be refined by having a laser timing signal aimed directly at the distant observer to avoid the multiple path/ signal problem. I also agree that the period measured by the distant observer would be greater by a factor of 1.73 as calculated from the relativistic gravitational gamma factor of [tex]\gamma= \frac{1 }{ \sqrt{1-\frac{2 G M}{R c^2}}}[/tex]
However, without knowing what radius the distant observer measures, it is still not possible to deduce if the speed of light as measured by the distant observer is slower by a factor of [tex]\gamma[/tex] or (as suggested by Meopemuk). [tex]\gamma^2[/tex]
The simplest solution is that there is no length contraction (at least horizontally) and that light appears to move slower by a factor of just gamma. However I suspect it not as simple as that and it will be necessary to factor in some gravitational calculations to see which interpretation is most consistent.
If rulers shrink in a gravitational field then stating the expression for the photon orbit as
[tex] R = \frac{3 G M}{c^2} [/tex]
begs the question “R as measured by whom?”
I think what Kip Thorne says is this:
In a gravitational field, either a) rulers do not shrink but space is curved/warped or b) space is flat but rulers shrink.
Both viewpoints make the same prediction such that you will need more rulers when you measure the length between two points in a gravitational field
mendocino said:
Yes, you can say a) space is curved or warped and rulers do not shrink or b) space is flat but rulers shrink in a gravitational field. Both viewpoints make the same prediction such that you will need more rulers when you measure length in gravitational field
I agree that both both viewpoints give the same prediction, but I am not sure that either viewpoint gives the correct prediction. In other words I am not yet certain that more rulers would be required. An alternative explanation of the Shapiro time delay could be simply that light slows down in a gravitational field from the point of view of a distant observer. A local observer would not notice the slow down of light as the clocks of the local observer would tick slower than the clocks of the distant observer. In other words all the observed effects in a strong gravitational field could be accounted for by warping of just the time dimesion in the 4 dimensional spacetime.
I am also not sure if the "length contraction" (if any) is the same in the vertical and horizontal directions. (Vertical and horizontal have a clear definition in a gravitational field)
Pervect gave the answer 173 seconds for the orbital period of a photon as observed by a distant observer in the thought experiment. Since the photon takes 173 seconds to travel a distance of 100 light seconds as measured by the tape measure we can conclude that light appears to move slower in a deep gravity well from the POV of a distant observer. The local observer measures 100 seconds for the orbital period because his clock is advancing slower by a factor of 1.73 relative to the clock of the distant observer. No shrinking of rulers or warping of the spatial dimensions is required, at least as far as that thought experient is concerned.
In a gravitational field, either a) rulers do not shrink but space is curved/warped or b) space is flat but rulers shrink. Both viewpoints make the same prediction such that you will need more rulers when you measure length in a gravitational field
I think that's a good way of looking at it. Note that the idea of rulers shrinking or growing can be traced back at least as far as Einstein, who proposed considering rulers on a non-uniformly heated disk as an example of a non-euclidean geometry. Based on the local temperature, the rulers would expand or contract, making the measured geometry of the disk non-Euclidean.
It seems ultimately more productive to me to deal with the geometry itself - this is the "modern" approach to general relativity. However, in very early works on relativity and also in popularizations aimed at a lay audience, one still does see the idea of rulers shrinking and expanding used, as a way to avoid considering non-euclidean geometries and instead think of expanding/contracting rulers in a familiar Euclidean geometry. This sort of explanation of GR via "expanding rulers" becomes somewhat problematical for extreme cases such as black holes (in my opinion, this sort of formulation might have helped mislead some of the earlier scientists into their false notions of the nature of the event horizon as being singular, when in fact it is not). However, if one stays away from such extreme examples, the idea can be made to work.
Black hole orbital period
Hi again Pervect,
While looking around the forums on this subject I came across this old post of yours here (Black hole orbital period ) https://www.physicsforums.com/showthread.php?t=117893
In that thread you derived the following expression for the orbital period around a black hole as measured by a clock co-moving with the orbiting object (proper time).
[tex]\tau = \frac{2 \pi r}{c} \sqrt{\frac{2r}{r_s} -3}[/tex]
Here [itex]r_s[/itex] = 2GM/c^2 is the Schwarzschild radius of the black hole.
I thought you might be interested in this alternative derivation obtained by adapting Newtonian physics:
We start with the classic Keplerian equation for the orbital period
(Eq 1) [tex]T = 2 \pi \sqrt{\frac{R^3}{G M} }[/tex]
The period [tex]T_L[/tex] measured by a local stationary clock at the same altitude as the circular orbit will be shorter by a factor of [tex] \sqrt{1-\frac{2 G M}{R c^2}}[/tex] giving
(Eq 2) [tex]T_L = 2 \pi \sqrt{\frac{R^3}{G M} (1-\frac{2 G M}{R c^2})} [/tex]
which simplifies to
(Eq 3) [tex] T_L = \frac{2 \pi R }{c}\sqrt{(\frac{R c^2}{G M}-2)} [/tex]
The time [tex]T_p[/tex] measured by a co-moving orbiting clock is subject to a further time dilation factor of [tex] \sqrt{1-\frac{v^2}{c^2}} [/tex]
(Eq 4) [tex]T_p = \frac{2 \pi R }{c} \sqrt{(\frac{R c^2}{G M}-2)(1-\frac{v^2}{c^2})} [/tex]
To simplify this further we need to express v/c in terms of G, M and R.
In Newtonian terms centripetal acceleration is defined as [tex]{v^2}/{R}[/tex] and gravitational acceleration is defined as [tex]{G M}/{R^2}[/tex]. In a stable orbit we can equate the two as:
(Eq 5) [tex] \frac{v^2}{R} = \frac{G M}{R^2}[/tex].
Assuming that everything in a gravitational field moves slower by the gravitational time dilation factor of
[tex] \sqrt{1-\frac{2 G M}{R c^2}}[/tex] we can modify Eq 5 to allow for gravitational time dilation and obtain
(Eq 6) [tex]\frac{v^2}{R}(1-\frac{2 G M}{R c^2}) = \frac{G M}{R^2}[/tex]
Rearrange
(Eq 7) [tex]v^2=\frac{G M c^2}{R c^2-2 G M}[/tex]
Divide both sides by c^2 to obtain a new expression for [tex]{v^2}/{c^2}[/tex]
(Eq 8) [tex]\frac{v^2}{c^2}=\frac{G M}{R c^2-2 G M}[/tex]
Substitute this new expression for [tex]{v^2}/{c^2}[/tex] into Eq 4 and multiply out the brackets to obtain
(Eq 9) [tex]T_p = \frac{2 \pi R }{c} \sqrt{\frac{R c^2}{G M}+\frac{2 G M-R c^2}{R c^2- 2 G M}-2} [/tex]
Since [tex] \frac{2 G M-R c^2}{R c^2- 2 G M} = -1 [/tex] Eq 9 simplifies to
(Eq 10) [tex]T_p = \frac{2 \pi R }{c}\sqrt{(\frac{R c^2}{G M}-3)} [/tex]
which is the result we are looking for.
I hope that is correct as I worked that lot out by hand on paper.
Not that this obtained using only the gravitational and inertial time dilation factors and that distance (radius and circumference) and mass are measured the same from the point of view of local and distant observers.
We can also obtain the radius of the photon orbit by substituting [tex]c^2[/tex] for [tex]v^2[/tex] in Eq 6 to get
(Eq 11) [tex]\frac{c^2}{R}(1-\frac{2 G M}{R c^2}) = \frac{G M}{R^2}[/tex]
Rearrange
(Eq 12) [tex] R (1-\frac{2 G M}{R c^2}) = \frac{G M}{c^2}[/tex]
Simplify
(Eq 13) [tex] R = \frac{3 G M}{c^2}[/tex]
which is the accepted equation for the photon orbit.
Actually, I don't think we can quite say that.
You have chosen a rather interesting "hybrid" way to determine the speed of light. You've imported a local ruler near the event horizon to measure distances, by physically carrying a meter stick to the surface of your planet to measure distances, but rather than also carrying a clock along with the ruler to the surface of the planet to measure time, you've chosen to use a distant clock for your time reference rather than a local clock.
I call the measurement "hybrid" because you are mixing together a local concept of distance with a coordinate concept of time.
Note that if you carried a clock to the surface of the planet to measure time, you'd find that the speed of light did not change - it was 'c' for the distant observer, and when the distant observer carries his clocks and rulers to the surface of the planet, he still gets 'c'.
What's lacking from this description is an "equal treatment" of distance and time. You've chosen one approach (importing a ruler) to deal with distance, and another approach to deal with time (you've rejected carrying along a clock to measure time, though you think it's perfectly fine to carry around a ruler!).
I agree I appear to have done what is called frame jumping in Special Relativity. :smile:
However in post post #19 I asked "Also, would the surface observer and distant observer agree on the measured geometrical and gravitational radius of the body, if we ignore strictly optical effects?" and again in post #21, I mentioned "However, without knowing what radius the distant observer measures, it is still not possible to deduce if the speed of light as measured by the distant observer is slower by a factor of gamma or (as suggested by Meopemuk) gamma ^2.
No one has yet given an answer to what the apparent radius and circumference of the gravitational body would be to the distant observer and without that information we cannot be sure what the apparent speed of light is to the distant observer.
So I simply made the assumption that the radius and circumference would measured the same by the distant and local observers to see where that assumption takes us, which is why I used 100 light seconds for the circumference as measured by the distant observer.
EDIT I guess the distant observer would have to measure the distance to the body and angle subtended by the body when viewed through a telescope to calculate the radius and circumference of the body. This measurement would than have to adjusted to allow for optical gravitational lensing that would make the object appear larger than it "really" is. I hesitate to use the word real as this is a very subjective quality in modern physics :P A formula was given in an early post for calculating the optical gravitational lensing magnification effect. END EDIT
I am working on the implications of that assumption to see if things are consistent and there appear to be some difficulties when we compare the acceleration of gravity as measured by local and distant observers and when calculated from orbital velocities and from dropped objects. I will try to express those problems more clearly in a following post as it is a little tricky ;)
In the meantime, could you have a look at post #25 as it might be of particular interest to you?
You might have missed it, as we posted at about the same time.
Pervect correctly pointed out that I simply assumed distance would be measured the same by the local and distant observer. Since neither Pervect or anyone else has suggested what radius would be measured by the distance observer, I present here a table of various choices of length contraction in a gravitational field to investigate the implications of those choices.
[tex]
\begin{array}{| l | c | c | c | c | c | c |}
\hline
Observer & Local & \multicolumn{5}{|c|}{Distant } \\ \hline
Option & & A & B & C & D & E \\ \hline
Ruler & L_0 & L_0/y^2 & L_0/y & L_0 & L_0.y & L_0.y^2 \\ \hline
ClockRate & T_0 & T_0.y & T_0.y & T_0.y & T_0.y & T_0.y\\ \hline
Circumference & D_0 & D_0/y^2 & D_0/y & D_0 & D_0.y & D_0.y^2 \\ \hline
Radius & R_0 = D_0 / (2 \pi) & R_0/y^2 & R_0/y & R_0 & R_0.y & R_0.y^2 \\ \hline
Mass & M_0 = R_0 c^2 / G & M_0/y^4 & M_0/y^3 & M_0/y^2 & M_0/y & M_0 \\ \hline
c & c & c & c & c & c & c \\ \hline
c_v & c & c/y^3 & c/y^2 & c/y & c & c.y \\ \hline
Orbital Period & T_0 & T_0.y & T_0.y & T_0.y & T_0.y & T_0.y \\ \hline
Acceleration(Gravity) & a_g = G M_0 / R_0^2 & a_g & a_g/y & a_g/y^2 & a_g/y^3 & a_g/y^4 \\ \hline
Acceleration(Centripetal) & a_c = c_v^2/R_0 & a_c/y^4 & a_c/y^3 & a_c/y^2 & a_c/y & a_c\\ \hline
\end{array}
[/tex]
In the table y is the gravitational gamma factor [tex] \frac{1}{\sqrt{1-\frac{2 G M}{R c^2}}}[/tex] and [tex]c_v[/tex] is the apparent speed of light as measured by the distant observer.
To explain how I arrived at the figures given in the table I will show the calculations for option B where rulers shrink by a factor of 1/y.
To the local observer the circumference is 100 light seconds and the radius is [tex]100/(2 \pi)[/tex] light seconds. From the point of view of the distant observer the circumference smaller by gamma (about 59 light seconds) and the radius is reduced by the same factor.
The speed of light to the local observer is the circumference divided by orbital period of the photon = 100 light seconds / 100 seconds = 1 light second/second which is c. (about 300,000,000 m/s). The apparent speed of light [tex]c_v [/tex]of the orbiting photon from the distant observer’s point of view is 59 light seconds / 172 seconds = [tex]c/y^2[/tex] light seconds /second. (about 100,118,544 m/s). The orbital periods of 100 seconds and 172 seconds for the local and distant observers respectively were given by Pervect.
Using the relationship between centripetal acceleration and gravitational acceleration [tex] c_v^2/R = GM/R^2[/tex] the local observer calculates the mass of the body as [tex]M_0 = R c_v^2/G [/tex] which works out as 6.44E+36 Kg. The mass according to a distant observer is a little bit more difficult to calculate as it involves the gravitational gamma factor [tex] \left1-\frac{2 G M}{R c^2}\right [/tex] which assumes the mass is already known. Here, I cheat a little and simply assume gamma is 1.73 as used by Pervect to calculate the orbital period. So by assuming [tex] \sqrt{1-\frac{2 G M}{R c^2}}[/tex] = 1.73 we can calculate the mass as measured by the distant observer as 1.24E+36 kg which is less than the mass measured by the local observer by a factor of [tex]1/y^3[/tex].
The acceleration due to gravity measured by the local observer [tex]a_g[/tex] is simply [tex]G M_0/R_0^2[/tex]. The acceleration due a distant observer is [tex] G (M_0/y^3) /(R^2/y^2)[/tex] which is the same as[tex] a_g\sqrt{1-2GM/(Rc^2)}[/tex].
Now to review the options:
Option A: [tex](R=R_0/y^2) [/tex]
This is the only option that both local and distant observers measure the same acceleration due to gravity. One way to do this would be to drop an object from short distance and measure the drop time and final velocity of the falling object. Is it a requirement of the equivalence principle that local and distant observers measure the accleration?
On the downside, the apparent speed of light to a distant observer is slower by a factor of [tex]y^3[/tex] which I think disagrees with measurements made in timing the Shapiro delay. (Too slow)
Option B: [tex](R=R_0/y) [/tex]
In this option the apparent speed of light measured by the distant observer is [tex]c/y^2[/tex] which is the factor often quoted on the internet but I can not find an reliable source. The shorter rulers would make the apparent Shapiro light path seem longer and combined with the slowdown of light by gamma squared, would probably result in a greater Shapiro time delay than is actually measured.
Option C: [tex](R=R) [/tex]
This is the “no length contraction” option. This is the only option where centripetal acceleration [tex] v^2/R[/tex] and gravitational acceleration [tex]GM/R^2[/tex] are equivalent from the point of view of both local and distant observers. This is a strong point in its favour. However, it has to agree with measurements made in actual experiments. The apparent speed of light in this option is only slower by a factor of [tex] \sqrt{1-2GM/(Rc^2)}[/tex]. Is this slow enough to account for the measured Shapiro delay?
Option D: [tex](R=R.y) [/tex]
The apparent speed of light to a distant observer is the same as that measured by a local observer. This would appeal to those who like to think that the speed of light is everywhere and anywhere the same as measured by anyone in inertial or non-inertial frames of reference. That is about all this option has going for it. The expansion of rulers would make the physical distance measured by those rulers in a Shapiro type experiment less than the simple calculated geometric distance. The shorter measured distance and constant speed of light make it difficult to explain the delay measured in the Shapiro experiments.
Option E: [tex](R=R.y^2) [/tex]
The mass measured by the distant observer is the same as the mass measured by the local observer in this option only. However, the speed of light is measured as moving faster than c by the distant observer (bad), the Shapiro light path is even shorter than in option D making this option an unlikely candidate.
So out of all the options my personal favourite is the option with no length contraction (Option C) mainly because this is the only option where all observers agree on the equivalence of centripetal and gravitational acceleration. (Assuming I am using the right formulas for the calculation of acceleration. Is there an alternative relativistic version of them?) At this time I have been unable to ascertain if it agrees with measured Shapiro delay.
Is it fair to assume a distant observer would measure some radius for a gravitational body? Is anyone brave enough to state what radius the distant observer would measure in the thought experiment?
I do not believe there is a unique notion of distance as defined by a distant observer. The biggest issue is that there are multiple notions of simultaneity that the distant observer can use. In our particular example, this won't cause much problem in our particular example, but in other cases (for instance rotating platforms) it can become important.
I also think that the clearest expression of the physics involved is to say that the speed of light in General Relativity is always constant, but only when one uses local clocks and rulers. This usually gets the basic idea across without a lot of philosophical discussion, which can be quite time consuming.
I also think that the clearest expression of the physics involved is to say that the speed of light in General Relativity is always constant, but only when one uses local clocks and rulers...
Stating that the speed of light is constant from the point of view of a local observer resolves nothing as I assumed that in all 5 of the schemes I presented (and there are infinitely many more permutations). However, since you also stated that you did not believe there is a unique notion of distance as defined by a local observer I won't press you any further.
For anyone still interested I have one additional observation that clinches the issue (for me). In the original table the orbital period was simply calculated from the circumference divided by the apparent speed of light. There is another way to calculate the orbital period and that is using the Kepler expression for the orbital period. In an earlier post I believe I showed that the Kepler expression is still valid in strongly curved spacetime. I have added the numerical evaluation of the orbital period using both methods and only the "no length contraction" option (Option C) gives the same answer using both methods. This IMHO is another strong pointer to Option C.
[tex] \begin{array}{| l | c | c | c | c | c | c |} \hline Observer & Local & \multicolumn{5}{|c|}{Distant } \\ \hline Option & & A & B & C & D & E \\ \hline Ruler & L_0 & L_0/y^2 & L_0/y & L_0 & L_0.y & L_0.y^2 \\ \hline Orbital Period (D_0/c_v) & 100s & 173s & 173s & 173s & 173s & 173s \\ \hline
Kepler Period (2 \pi \sqrt{R^3 / (G M)}) & 100s & 58s & 100s & 173s & 300s & 520s \\ \hline
\end{array} [/tex]
The Kepler orbital period T = [tex]2 \pi \sqrt{\frac{R^3 }{G M}}[/tex] is calculated using the radius and mass as measured by the observer.
  • #31
You then applied gravitational and velocity time dilation to get
Your result is correct for a circular orbit and I think the steps are correct too. The only non-rigorous part is the 'leap of faith' that one can in fact take the Keplerian period, apply time dilations and get the relativistic period. This only works for perfectly circular orbits in Schwarzschild geometry (other orbits have to deal with spatial curvature too), so it by no means a general truth and should be used with care.
-J
  • #32
Hi Guys
I've been really interested reading your posts, and wating to see what happens when you feed in some quantitive experimental evidence on actual 'Shapiro' delays. The problem is there are discrepancies, and wrestling with relativity or, I had to smile, slowing down the speed of light, won't solve them. The first, Venus, result was 200ms, fine just for a curved track. The later Jupiter one didn't quite seem to work, but did when a vector for Jupiter was adden in. So that was ok then! Was it!?
But now we're doing it in deep space we might of course expect the delays to run into minutes perhaps, or even hours!
Think again. How about months. Do your homework on systems like B1600+434.
I came at this problem from another angle, sorting a beautifully simple unification theory that worked apart from throwing up a couple of bizarre predictions. This was one. In fact they both panned out!
Unfortunately physicists won't respond or read it. Even journal editors! I think they're still arguing with Capernicus, or too busy tied up with string theory and doing maths I expect. Shame. could have saved them so much work.
I might get a webpost organised some time so keep a look out.
Canticle
  • #33
The speed of light is 'c' because it's entirey constant guys. Gravity red shifts it but doesn't slow it down. Yes of course there's a paradox in the Shapiro delay, giving inconsistent results with galactic lensing, just like the time paradox in special relativity.
I'm told there's now an answer to these, ('these'?) but it's still being worked on. Hmm. Watch this space I suppose.
C
  • #34
What time paradox ? I must have missed something because I've not heard of any such paradox.
  • #35
What paradox in Shapiro delay? I must have missed something too.
GR predicts that the coordinate speed of light slows down according to :
[tex] c ' = c \left( 1- \frac{2GM}{R c^2} \right) [/tex]
and that is exactly what Shapiro (and others) measured in an actual experiments.
The greater the mass M and the smaller the distance R from the mass the greater the slow down or delay.
George Jones posted this nice derivation a long time ago https://www.physicsforums.com/showpost.php?p=928277&postcount=19 for the round trip time ([itex] \tau [/itex]) taken for a photon to travel from the location (R) of the observer, down to a mirror located at ([itex] r_m[/itex]) and then back up the to the observer, as measured by the wristwatch of the observer:
[tex] \tau = \sqrt{1-\frac{2GM}{R c^2}} \left( \frac{4GM}{c^3} \ln \left( \frac{R - 2GM/c^2}{r_m -2GM/c^2} \right) + \frac{2(R-r_m)}{c} \right) [/tex]
I have added G and c constants to try and get the correct units for time. Could someone check that?
