Block compresses spring, find coefficient of kinetic friction
In summary, a 2.5 kg block is pushed against a horizontal spring with a spring constant of 200 N/m, compressing the spring by 18 cm. When released, the block slides across a tabletop and stops 90 cm from where it was released. The block-table coefficient of kinetic friction is being sought, and calculations for potential and thermal energy have been made, with a request for further help.
Nick-
You push a 2.5 kg block against a horizontal spring, compressing the spring by 18 cm. Then you release the block, and the spring sends it sliding across a tabletop. It stops 90 cm from where you released it. The spring constant is 200 N/m. What is the block-table coefficient of kinetic friction?
Having trouble finding the initial and final mech energy (sum of kinetic and elastic potential energy - I don't know how to find the velocity so I can't find the kinetic energy, would you set up energy equations?)
Using the spring constant I found: F=-k(d) = -200N/m (.18m) = 36 N
Elastic potential energy = 1/2kx^2 = 1/2(450N/m)(.18m)^2 = 7.29 N
The change in thermal energy = Fk(d) = (Uk)(Fn)(d)
Normal Force = mg = 24.5 N
Also, initial mech energy - change in thermal energy = final mech energy
That's pretty much all I got, any help would be much appreciated, thanks
Welcome to PF.
You know how much potential energy is in the spring just before it's released.
So what force acting over the 90 cm distance will have absorbed the PE that went into the object's KE? Won't that work equal the Potential it had when it was on the spring?
Based on the given information, we can use the principle of conservation of energy to find the coefficient of kinetic friction. The initial mechanical energy of the block-spring system is equal to the final mechanical energy of the block-table system. This can be expressed as:
Initial mechanical energy = Final mechanical energy
The initial mechanical energy includes both the elastic potential energy stored in the compressed spring and the kinetic energy of the block as it is released from the spring. The final mechanical energy includes only the kinetic energy of the block as it slides across the table. We can write these equations as:
Initial mechanical energy = Elastic potential energy + Kinetic energy (1)
Final mechanical energy = Kinetic energy (2)
We can use the given information to solve for the elastic potential energy and the kinetic energy in these equations. The elastic potential energy can be calculated using the formula 1/2kx^2, where k is the spring constant and x is the compression distance. Plugging in the values, we get:
Elastic potential energy = 1/2(200N/m)(0.18m)^2 = 3.24 J
To find the kinetic energy, we can use the formula 1/2mv^2, where m is the mass of the block and v is the velocity of the block. We can use the fact that the block stops after sliding 90 cm to calculate its velocity. We know that the distance traveled is equal to the average velocity multiplied by the time, and the time can be calculated using the formula d = (1/2)at^2, where a is the acceleration. In this case, the acceleration is due to the force of friction, which is equal to the normal force multiplied by the coefficient of kinetic friction. Putting these equations together, we get:
90 cm = (1/2)v(t) (3)
and
a = μkFn (4)
Substituting (4) into (3) and solving for the time, we get:
t = √(2d/a) = √(2(0.9m)/(μkFn)) = √(1.8/μk(24.5N)) = 0.06/μk (5)
Now, we can use (5) to solve for the kinetic energy in equation (2):
Final mechanical energy = Kinetic energy = 1/2mv^2 = 1/2(2
1. What is a block compresses spring?
A block compresses spring is a physics concept where a block or object is placed on top of a spring, causing the spring to compress due to the weight of the object. This is often used to study the relationship between force and displacement in a spring.
2. How do you calculate the coefficient of kinetic friction in a block compresses spring scenario?
The coefficient of kinetic friction can be calculated by measuring the force needed to keep the object in motion on the compressed spring and dividing it by the weight of the object. This can be repeated with different weights to get an average coefficient of kinetic friction.
3. Can the coefficient of kinetic friction change in a block compresses spring?
Yes, the coefficient of kinetic friction can change in a block compresses spring scenario. This can be due to factors such as changes in surface roughness, temperature, and pressure.
4. What are the units for the coefficient of kinetic friction?
The coefficient of kinetic friction is a dimensionless quantity, meaning it has no units. It is simply a ratio of two forces.
5. How can the coefficient of kinetic friction be used in real-world applications?
The coefficient of kinetic friction is a crucial factor in many real-world applications, such as designing brakes for vehicles or determining the amount of force needed to move objects on different surfaces. It is also used in engineering designs for safety and efficiency purposes.
