Question about the tether scene from the movie Gravity
In summary, the conversation discusses a scene from the movie "Gravity" where two astronauts are joined by a rope. One astronaut accelerates and pulls the other, causing the rope to tense and give a jerk. The rope then loosens until the accelerating astronaut gains enough velocity to tense it again. The question is raised about what would happen if the object being pulled had very little mass, and how to determine if the rope remains tense or loosens. There is also a discussion about the elasticity of the rope and how it would affect the movement of the two astronauts. The conclusion is that the rope would oscillate if there is any stretching, and the intensity of this effect would depend on the elasticity of the rope.
fereopk
Question about the tether scene from the movie "Gravity"
In the movie there's a scene where two astronauts are joined together by a rope. One is accelerating to pull the other. The astronaut would accelerate, the rope would tense and give a jerk to the other astronaut. Then the rope would loosen again until the accelerating astronaut gained enough velocity to tense the rope again, giving another jerk.
If something had very little mass, I believe the rope would simply remain tense. My question is, how do you determine if the rope remains tense or loosens? How much more velocity does the astronaut being pulled gain over the accelerating astronaut such that they loosen the rope?
I haven't seen the movie. But if there are no external forces acting on either astronaut (there is just the tension in the rope), then by Newton's third law, the tension in the tether must result in equal and opposite forces (ie. the tension) being applied to both astronauts for the same time. So, if one astronaut pulls on the rope, absent any forces other than the pull on the rope, the two astronauts to move toward each other and keep moving together until they collide. When they collide, if one or both of the astronauts push off against the other, the two astronauts will move apart until the rope becomes tight and stops them.
AM
Think stretchy rope like a bungee cord.
As I see it you have two astronauts initially moving apart. I suspect that when the rope tightens it acts like a spring so there will be an elastic collision. What happens next depends on the relative masses and velocities (any damping/shock absorbing properties of the rope?)
AM
One of the astronauts is actually continually accelerating using his booster to pull the other. When he gets far enough, the rope tenses and then de-tenses, pulling the other astronaut.
There were plenty of technical flaws in the movie but the tether action was not among them.
If he would accelerate under constant thrust for a while, the rope would stay tense at some point.
Likes 1 person
Yes I was just looking for an explanation.
If he was tethered to something with very little mass, like a paperclip, and started accelerating, intuitively the rope would just remain tense, right? But if it was something like a planet, there would be a sort of jerk that would pull him back, loosening the rope? How do you know what will happen?
If the connection is perfectly elastic there will be endless oscillations. If the connection is perfectly inelastic there will be no oscillation.
Instead of jerking around, wouldn't it make more sense to pull the rope, come together, grab each other and then use the booster?
It was very in-elastic, there was almost no stretching. Even if there was stretching, wouldn't it remain tense as long as the constant acceleration is applied? Why would it oscillate if the same force that brought it to that stretch is still there?
If there's any stretching at all, then disturbances at one end of the tether will take some non-zero time to propagate to the other end and you'll get some sort of wave behavior; for example, it's surprisingly hard to swing an object by an elastic band while maintaining a fixed extension of the band.
The intensity of this effect will depend om many factors: How much energy is dissipated in internal friction within the tether; the mass of the tether; the elasticity of the tether; and how quickly and smoothly the force is applied.
Seems like the biggest challenge would be avoiding spinning.
There would be tension on the tether - they got it almost right (although I think the tension was exaggerated - and wrong direction? not sure). Why? Assume they are static, no stretch rope or wave theory. Assume the station was in a stable orbit. An object is in orbit when the centrifugal force acting on it is equal and opposite to the gravity it's subjected to. That's why a person in orbit feels truly weightless. Our heroes were traveling at the same speed as the ISS, but were at a different altitude (by the length of the tether & rope), and thus there would be a slight difference between the centrifugal and gravitational accelerations - therefore they would drift apart.
I'm pretty sure George would have to let go, else we wouldn't have been treated to the 'sunrise on the Ganji' line.
Welcome to PF horrido.
The Newtonian forces on an orbiting body are not balanced. Since the centrifugal force is not a real Newtonian force it cannot balance gravity.
A person free-falling straight down to the Earth through space would feel the same thing (ie. until they hit the atmosphere). So it is not because of rotation or because the forces are balanced that the person feels weightless. It is the fact that all parts are accelerating at the same rate (so that there are no perceptible tension within the astronaut's body resulting from this acceleration) that creates the feeling of weightlessness. This applies to anybody on whom the only forces acting are gravitational forces that do not change materially over the entire body.
AM
This tether problem is not only relevant in space. Using a rope to tow another car can present big problems if the driver of either car is heavy footed on brake, clutch or accelerator. It may not be very exotic but it's a problem that any of us might find ourselves landed with.
I think I'd rather be tethered to Sandra Bullock, though.
1. What is the purpose of the tether scene in the movie Gravity?
The tether scene in the movie Gravity serves multiple purposes. Firstly, it creates a sense of tension and suspense as the characters struggle to stay connected to each other in the vastness of space. It also showcases the importance of teamwork and communication in a life-or-death situation. Additionally, the scene highlights the themes of hope and determination as the characters refuse to give up on each other.
2. How realistic is the tether scene in terms of scientific accuracy?
The tether scene in Gravity is generally considered to be one of the more scientifically accurate scenes in the movie. The concept of using a tether to stay connected in space is based on real-life spacewalk procedures, and the depiction of the characters' movements and reactions in zero gravity is also fairly realistic. However, there are some minor discrepancies, such as the length of the tether and the speed at which the characters are able to maneuver themselves back to the spacecraft.
3. How did the filmmakers create the visuals for the tether scene?
The visuals for the tether scene in Gravity were created using a combination of CGI (computer-generated imagery) and practical effects. The actors were suspended on a rig that simulated zero gravity, and then CGI was used to enhance the movement and appearance of the tethers. The end result is a visually stunning and intense scene that feels both realistic and cinematic.
4. What was the significance of the tether breaking in the scene?
The tether breaking in the scene symbolizes a breaking point for the characters. It represents the loss of hope and the realization that they may not make it back to safety. It also serves as a turning point in the story, as the characters must now find a new way to survive and make it back to Earth.
5. Did the actors perform their own stunts in the tether scene?
While the actors did have to undergo rigorous training for the movie, they did not perform all of their own stunts in the tether scene. Some of the more dangerous and physically demanding stunts were performed by professional stunt doubles. However, actors Sandra Bullock and George Clooney did perform some of their own stunts, such as the opening sequence of the scene where they are floating freely in space.
  • Classical Physics
  • Classical Physics
