Newton's third law is absurd: argue why this isn't true.
In summary, the law is absurd because it does not take into account the opposing force between two objects.
Trooper100
If the forces in Newton's third law are equal and opposite, they cancel, and thus nothing can ever accelerate, so the law is absurd.
Argue why this isn't true.
This is from my textbook, a very strong argument.
Hey I'm in intro-physics, so my knowledge is very limited.
But I would argue that if an object was moving at constant velocity, and impacted a wall with equal opposing force, then object would stop accelerating immediately. If this law is absurd, then we would not be able to identify the counter force coming from the wall. Thus, we would conclude the object just stops moving.
anyone got a great argument? Please feel free to add/correct anything.
This is not true. My explanatory abilities are limited, but think about it this way. If for example you jump in the air, you are applying a force on the earth, and the Earth is applying a force on you.
Lets assign this force an arbitrary value..30 N. F=ma. Let's say you have a mass 60kg. when you jump with a 30 N force you will have an acceleration of 0.5 m/s^2.
Now look at the force you apply to the earth. 30N/5.98E24kg gives it an acceleration so insignificant it is unnoticable.
Apply this to other bodies..differing masses allow for accelerations to exist when forces are equal and opposite.
Of course, if you don't believe Newton's second law either, then that argument is no good.
This is veering off in the wrong direction...
A significant aspect of Newton's Third Law is that while the forces are opposite in direction and are equal in magnitude, they act on different objects, so there is no "cancelling out".
This would be better off as an example of Newton's First Law. In any case, "impacted a wall with equal opposing force" does not make any sense. Rather, the object exerts a force on the wall when it hits the wall, and the wall exerts a force on equal magnitude on the object as well.
Also, the object was not accelerating in the first place. It is the impact/ the force exerted on the object by the wall that causes the object to decelerate to rest.
Netwon's third law has 3 characteristics,
1. Equal magnitude.
2. Different direction.
3. Acts on different bodies.
So if I push you, I exerted a force on your body. By Netwon's third law, your body exerted a force on my hand. You still fly away because no opposite forece exerted on your body.
1. Equal magnitude.
So isn't it when equal opposing force? If you push me, is there an equal opposing force? I think your force is greater, so therefore, I move forward. But the law says the object does not accelerate, with opposing and equal forces.
Thanks to all for your help.
If anyone else can contribute, it will be appreciated.
you've got what you need to understand this concept here. fightfish has explained it well. there is an equal and opposite force, but the opposite force is applied on a different object than the equal one. There is no greater force.
when you say the law says that the object does not accelerate with "equal and opposing force". that doesn't make a whole lot of sense. let's say i punch the side of my house. when i hit the wall, the wall stops my hand almost immediately by applying a force opposite the direction of my punch. but because the wall is applying that force, my hand is also applying the same force to the wall. my hand ends up decelerating from whatever speed i was punching with, to 0. but since the wall is so large, and connected to all my other walls, it doesn't move at all. the force dissipates through the molecular structure of the house. Imagine you and I are skating on ice. if you stand right in front of me, and you push me, I am going to go backwards, but so are you. that is because whatever force you have applied to my chest, my chest has applied back to you. keep asking questions if you are still unclear. it will help us pinpoint your issue.
I think everyone has covered this pretty good. Yes the forces at a boundary are equal and opposite, but they act on different objects so they don't cancel. An interesting way to look at Newtons 3rd law is to apply Newtons 2nd law at the boundary or surface between two objects to get:
F1+F2=ma
Since this surface is essentially a plane for flat boundarys it has no thickness. Likewise if it has no thickness then it has no mass. So it follows that:
F1+F2=0
or
F1 = -F2
So you can see that indeed our two forces are in fact equal and opposite from the application of Newtons second law. It is also interesting that even if the system has some acceleration the forces will still be equal and opposite because the mass is zero.
thank you everyone!
Related to Newton's third law is absurd: argue why this isn't true.
1. Is Newton's third law really absurd?
No, Newton's third law is not absurd. It is a fundamental law of physics that has been proven to be true through countless experiments and observations.
2. Why do some people argue that Newton's third law is absurd?
Some people may argue that Newton's third law is absurd because they misunderstand or misinterpret it. It may seem counterintuitive or contradictory at first, but this is due to a lack of understanding of the law.
3. Can you explain Newton's third law in simple terms?
Newton's third law states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
4. How is Newton's third law applied in everyday life?
Newton's third law can be seen in many everyday situations. For example, when we walk, our feet push against the ground and the ground pushes back with an equal force, allowing us to move forward. It also explains how rockets work by pushing against the ground or air to propel themselves forward.
5. Are there any exceptions to Newton's third law?
No, there are no exceptions to Newton's third law. It applies to all objects and forces, regardless of their size, shape, or speed. It is a universal law of nature that governs the behavior of objects in motion.
  • Classical Physics
9K
