More than one dielectric ibetween a parallel plate capacitor
In summary, the capacitance of a parallel plate capacitor can be calculated by using the Electric flux=e0*er*E equation and the Surface area=A equation.
rusty009
69
Hey, I am having some troubles with this question, the question asks me to calculate the capacitance of a parallel platecapacitor where the plates are separated by 3mm, and in between the are three layers of dielectric 1mm thick with different relative permitivities. Do I find the total by adding the three permitivities together :S?
P.S I am also given the area of capacitor and the values of the permitivities
Thanks in advance
Welcome to the PF. The way to approach this problem is to envision floating metal plates of zero thickness, placed at the 2 interfaces between the 3 dielectrics. Is that enough of a hint?
thanks for the reply, I still don't understand the problem :S.
What can you say about the charge distribution on each of these plates placed at the interface?
If your still struggling, try sketching the set up.
Hey, I have set it up but I am still having no luck, I have read through all my notes as well but I can't find anything about it. In reply to Hootenanny's post, I think that the charge will be equally distributed along the plates.
Have you sketched the set-up? If so, what does it remind you of?
Ok, I have been reading up a lot, and have encountered the notion of electric flux across the dielectrics, but the thing is I need to know the charge of the capacitor to work with electric flux and I do not have it. I have sketched it up but I am not familiar with this kind of problem.
Doesn't it remind you of three parallel plate capacitors?
I thought that a parallel capacitor needed to be between two conductors, but arnt there four capacitors ?
Metals don't conduct? :confused: There are four plates, but only three capacitors since a capacitor is formed by a pair of plates.
Hey, Ok I think I might be starting to understand it, but I have 5 plates, 3 dielectrics between two parallel plates. do I then use C=e0erA/d on each capactor then add them up? Thanks for your help.
but the capacitors would be in series so I would have to add them up with 1/c=1/c1 ... , is tis the right method?
No if you have drawn it correctly, you should only have four plates, one plate on the boundary between the three dielectric (this makes two plates) and two plates on the outside.
Indeed, you can treat the capacitors as if they are in series.
Ok, instead of the previous idea I decided to use a diffeent method and I think it worked. I'm basing this formula on electric flux, and that electric flux will stay constant throughout the capacitor so that Electric flux= e0*er*E , so for three different relative permitivities I have three different electric field stregths so that,
e0*er1*E1=e0*er2*E2=e0*er3*E3 where er1 er2 and er3 are the three different permitiities
the e0's will cancell eachothr out giving,
er1*E1=er2*E2=er3*E3
now with this relationship we can assume that
E1=&/e0*er1 E2=&/e0*er2 E3=&/e0*er3 where & is sigma ( charge per length)
and from this we have a consistent set of equations where we can use the formula
E= V/d to get an equation for the voltage across the capactor:
V=E1*d1+E2*d2+E3*d3= &/e0( d1/er1 + d2/er2 + d3/er3 )
and finally I used the formula C=&A/(d1/er1 + d2/er2 + d3/er3 ) where A is teh surface area of the plates on the capacitor.
so this method can provide the capacitance of a parallel plate capacitor with virtually infinite permitivites, assuming you know what they are and you know A. I thought I should share this method withthe forum for any future questions that relate to this one :D
FAQ: More than one dielectric ibetween a parallel plate capacitor
1. How does having more than one dielectric affect the capacitance of a parallel plate capacitor?
Having more than one dielectric between the plates of a parallel plate capacitor increases the overall capacitance. The dielectric materials serve as insulators, reducing the electric field strength and allowing for more charge to be stored on the plates.
2. What factors affect the capacitance when there are multiple dielectrics between the plates?
The capacitance is affected by the dielectric constant, thickness, and arrangement of the dielectric materials between the plates. The dielectric constant is a measure of how well the material can store electric charge, while the thickness and arrangement determine how much of the electric field is affected by the dielectrics.
3. How do you calculate the effective dielectric constant when there are multiple dielectrics between the plates?
The effective dielectric constant is calculated by taking the weighted average of the individual dielectric constants, where the weight is determined by the fraction of the total area of the plates that is covered by each dielectric material. For example, if 60% of the plate area is covered by a material with a dielectric constant of 5, and 40% is covered by a material with a dielectric constant of 3, the effective dielectric constant would be (0.6*5) + (0.4*3) = 4.2.
4. Do the dielectric materials need to be the same for the parallel plate capacitor to function properly?
No, the dielectric materials do not need to be the same for the parallel plate capacitor to function. However, using different materials can affect the overall capacitance and electric field strength, so it is important to consider the properties of each material when designing a capacitor.
5. Can having too many dielectrics between the plates cause problems with the parallel plate capacitor?
Having too many dielectrics between the plates can potentially cause problems, such as increasing the distance between the plates and decreasing the capacitance. Additionally, if the dielectrics are not arranged properly, it can result in uneven distribution of the electric field and lead to capacitor failure. Therefore, it is important to carefully consider the number and arrangement of dielectrics for optimal performance.
