Need a cheap binary AM transmitting circuit
In summary, an RF remote control kit would be a better option than trying to make your own transmitter.
hxtasy
112
Need a cheap "binary" AM transmitting circuit
I'm posting this in a forum because I'm not really sure what to search for online. I need a circuit that transmits a one or a zero, basically I have a sensor and i want it to turn something on or off remotely. I was thinking about using an AM oscillator crystal, the range does not have to be far, like 20 feet. Most circuits I looked at were transmitting a frequency, carried on the AM - so I'm not really sure how I would just transmit an on/off state. I guess i could transmit like <1kHz for off and >2kHz for on, but I'm sure there is an extremely easier way to do this.
Any Ideas?
Any Ideas?
I googled RF Remote Control Kits, and got lots of good hits. Here's one of the first:
http://store.qkits.com/category.cfm/RC
It's not a good idea for you to try to make your own RF transmitter -- too easy to violate FCC rules, and cause interference with other radio receivers (like Police / Fire / EMS radios). Using a kit should give you a transmitter that meets the TX rules.
I have seen modules for 433.9 MHz that would be suitable. You get a pair of one transmitter and one receiver for about $20.
This is a legal frequency for low powered low interference devices in some countries (although it was swiped from the 432 MHz ham band!).
It would be better to have a signal present all the time because you could get noise when the transmitter is not turned on.
If you wanted to make it bulletproof, you could have modem chips at each end.
One is the TCM3105 which was used for Packet Radio and may still be available.
These chips give specific audio frequencies out for digital input and produce digital output from the same audio frequencies.
Might be an overkill if you only want simple signalling..
Related to Need a cheap binary AM transmitting circuit
1. How does a binary AM transmitting circuit work?
A binary AM (amplitude modulation) transmitting circuit is a type of electronic circuit that encodes binary data (0s and 1s) into an amplitude modulated carrier signal. This signal is then transmitted through a medium, such as radio waves, to a receiver where it is demodulated and decoded back into its original binary form.
2. What components are needed for a cheap binary AM transmitting circuit?
The main components needed for a cheap binary AM transmitting circuit include a power source, a microcontroller or other circuitry for encoding the binary data, a modulation circuit to generate the carrier signal, and an antenna for transmitting the signal.
3. Can I build a cheap binary AM transmitting circuit myself?
Yes, it is possible to build a cheap binary AM transmitting circuit yourself with the right components and knowledge of circuit design. However, it is recommended to have a basic understanding of electronics and the necessary tools and equipment before attempting to build one.
4. What is the range of a cheap binary AM transmitting circuit?
The range of a cheap binary AM transmitting circuit can vary depending on the power of the transmitter and the type of medium used for transmission. In general, it can range from a few meters to several kilometers.
5. Are there any safety precautions I should take when using a cheap binary AM transmitting circuit?
Yes, it is important to follow safety precautions when using any type of electronic circuit, including a cheap binary AM transmitting circuit. This may include properly grounding the circuit, using appropriate insulation and protective equipment, and following instructions carefully to avoid any potential hazards.
  • Electrical Engineering
