Atmospheric pressure to gas pressure in the apparatus
In summary, atmospheric pressure is the weight of the Earth's atmosphere exerted per unit area and is typically measured in millibars or inches of mercury. It can affect gas pressure in an apparatus by exerting a force on the surface of the gas or liquid inside. The relationship between atmospheric pressure and gas pressure is inversely proportional. Atmospheric pressure can be measured using a barometer or pressure gauge. It is important to consider atmospheric pressure when conducting gas experiments to ensure accuracy and account for any changes in gas behavior.
kaitlynclark
If the atmospheric pressure is 745 mm Hg, what is the gas pressure in the apparatus in atm?
(Hint: the gas pressure is not equal to atmospheric pressure. Which is greater Pgas or Patm?)
Be careful with your units, 10.2 cm is equal to 102 mm
P=H+G
P=102+0.98
P=102.98
We don't know the apparatus, we don't know what you add to what, we don't know the units. There is no way we can help or comment on the problem itself.
Related to Atmospheric pressure to gas pressure in the apparatus
1. What is atmospheric pressure?
Atmospheric pressure is the force per unit area exerted by the weight of the Earth's atmosphere. It is typically measured in units of millibars or inches of mercury.
2. How does atmospheric pressure affect gas pressure in an apparatus?
Atmospheric pressure can affect the gas pressure in an apparatus by exerting a force on the surface of the liquid or gas inside the apparatus. This can cause the gas pressure to increase or decrease depending on the level of atmospheric pressure.
3. What is the relationship between atmospheric pressure and gas pressure?
The relationship between atmospheric pressure and gas pressure is inversely proportional. This means that as atmospheric pressure increases, gas pressure decreases, and vice versa.
4. How can atmospheric pressure be measured?
Atmospheric pressure can be measured using a barometer, which measures the height of a column of mercury or other liquid that is supported by the atmospheric pressure. It can also be measured using a digital or analog pressure gauge.
5. Why is it important to consider atmospheric pressure when conducting experiments with gas?
It is important to consider atmospheric pressure when conducting experiments with gas because it can affect the accuracy and reliability of the results. Changes in atmospheric pressure can also impact the behavior of gases and may need to be taken into account when analyzing data.
