Number of ways to select M cohyperplanar points in finite space
In summary, the conversation discusses the problem of counting the number of subsets of size n in Z^{d}_{3} that have at least m mutually cohyperplanar points. An example is given for n=5, m=3, d=2 and the specific case of m=7, d=3 is mentioned. The question is posed of how many ways there are to select n points in Z^{3}_{3} such that any 7 are mutually coplanar. There is also a discussion about the number of points needed to guarantee that the set of selected points contains every point on two parallel lines.
Nick O
158
(I don't like the title, since it is a bit misleading. But, I couldn't think of a more descriptive title that fit in the length restrictions.)
A recurring theme in a problem I am exploring is counting the number of subsets of size n in [itex]Z^{d}_{3}[/itex] that have at least m mutually cohyperplanar (dimension d-1) points.
For example, if n=5, m=3, d=2, the question is: "How many ways are there to select 5 points from a 3x3 plane such that any 3 points are mutually collinear?" Because 5 points guarantee a complete line in [itex]Z^{2}_{3}[/itex], the answer is the same as 9 choose 5, specifically 126.
The specific case I am currently interested in, but most likely not the last, is the case with m=7, d=3. So, the question is: "How many ways are there to select n points from [itex]Z^{3}_{3}[/itex] such that any 7 are mutually coplanar?", where n is a variable.
Is it too much to expect that there should be a fairly simple combinatorial answer to this? So far I have not been able to derive it, but I feel that it should exist.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Hello, Greg!
No new developments so far. I posted this while I was taking summer classes, and I am working full-time until school starts again next week. I will probably start working on the problem again at that time.
But, I may later be able to post more old information on my approach that may inspire someone else to fill in the blanks.
Ī completely misunderstand “5 points guarantee a complete line…” stuff, and preceding question looks bizarre. First of all, in affine space over an arbitrary field any two distinct points unambiguously define a line. Also, in an affine space over ℤ3 (whichever dimension, 1 or more) a line always consists of exactly 3 points. Three distinct points can be collinear over ℤ3. More than three distinct points can’t be collinear over ℤ3 in an affine space.
Thanks for the response.
There are 27 points in Z33.
If you choose two of these points at random, you can define a line through those points. However, the set of points you have selected does not contain every point on that line.
You must choose five points to guarantee that the set of points selected contains every point on at least one line.
The question was this: how many points must be selected in order for the set of selected points to contain every point in two parallel lines? The answer is at least six, because it must contain at least the six points in the two lines.
1. What is the significance of selecting M cohyperplanar points in finite space?
Selecting M cohyperplanar points in finite space is important in many fields of science, such as geometry, computer graphics, and physics. It allows for the study and analysis of geometrical structures and patterns, as well as the creation of accurate representations and simulations of real-world objects and phenomena.
2. How many ways are there to select M cohyperplanar points in finite space?
The number of ways to select M cohyperplanar points in finite space can be calculated using combinatorics. It is equal to the number of combinations of M points out of the total number of points in the space, multiplied by the number of possible orientations of those points in a hyperplane. This can be represented by the formula MchooseN * (N-M+1), where N is the total number of points in the space.
3. Can the number of ways to select M cohyperplanar points be infinite?
No, the number of ways to select M cohyperplanar points in finite space is always a finite number. This is because there is a finite number of points in the space and a finite number of possible orientations of those points in a hyperplane.
4. How does the dimension of the space affect the number of ways to select M cohyperplanar points?
The dimension of the space has a direct impact on the number of ways to select M cohyperplanar points. As the dimension increases, the number of points and possible orientations also increases, resulting in a larger number of ways to select M cohyperplanar points.
5. Are there any real-world applications of selecting M cohyperplanar points in finite space?
Yes, there are many real-world applications of selecting M cohyperplanar points in finite space. Some examples include creating 3D models and animations in computer graphics, analyzing molecular structures in chemistry and biology, and studying the behavior of particles in physics simulations.
  • Linear and Abstract Algebra
