Potential difference of capacitor in circuit
In summary, the conversation is about understanding potential difference in parallel circuits, specifically in the context of capacitors and dielectrics. The potential difference is the same between two points in parallel circuits because it is independent of the path. However, the potential difference between the plates of a capacitor may be different from that between the points in the circuit, but it is usually negligible. The potential difference between two points in a wire may be different if there is an outside charge affecting it, but in real circuits, this scenario is unlikely to occur.
iampaul
93
I'm having a problem with this although I just finished the chapter about electric potential and potential energy in University physics by young and freedman and I need to understand this because the next chapter is about capacitors and dielectrics and there is an example just like this:
(((((((((((--------ll---------
A-------l--------ll---------l--------B *The paretheses are just for spacing * I can't paste the pictures
The three capacitors are in parallel and the potential difference between A and B is V, what is the potential difference across each capacitor. I know that the potential difference across each branch must be equal to V but i don't understand it clearly. I think i have read something about the potential difference being independent of the path. So my first question is why is the potential difference the same when in parallel. The second one is about the potential difference between the plates of the capacitor. Potential depends on distance. Let's say the potential is computed from a point charge q beyond A. The distance between A and B is different from the distance between the plates of the capacitor so the difference between potentials must be different? What I am trying to say is something like this:((((((((((((((((((((((((((((((((((((((( --------ll---------
((((((((Q(((((((((((((((((((( A-------l--------ll---------l--------B
(((((((((((((((((((((((((((((((((((((((((--------ll---------
The point charge q causes a potential difference between A and B but that potential difference must be different from that between the plates of the capacitors. (This chapter is before resistance and current in the textbook I am using ). I always get stuck at something in almost every chapter. Help please
hi iampaul! :smile:
yes, potential difference is independent of the path :smile:
it's like height … if there are three roads between A and B on a hill, then the roads will have different lengths, but they will all go up by the same height
similary, the potential difference (the voltage drop) between any two points A and B is the same for any route between them :wink:
(in series, the voltage drops are different because they're measured between different points :wink:)
electric fields are additive
the field caused by two (or more) objects is the sum of the individual fields
similarly, electric potential is additive …
in this case, you add the potential difference caused by the charge q to the potential difference caused by the emf in the circuit :smile:
My first question is now cleared up but the second one still confuses me. Shouldn't the potential difference between A and B be different from that experienced by the capacitor because they are measured in different points? The potential difference between the plates of the capacitor is measured between the plates and it must be different from that between A and B but in circuit problems we use the potential difference between A and B for the capacitor.
hi iampaul! :smile:
the potential difference (voltage drop) along ordinary wires is so small as to be negligible
(if it wasn't, we'd just use wires with less resistance! :biggrin:)
so yes, the potential difference is different, but the difference is far less than the accuracy of the measurements we make :wink:
What i really mean is something like this:
What if we have a wire with end points A and B and that the potential difference between A and B is caused only by a point charge q beyond A. The Capacitor is placed along the wire at a point between A and B. Because the potential on a point in the wire depends on its distance from q, the potential difference between A and B due to the charge q is different from that between the plates of the capacitor which are separated only by a very small distance. If the wire is short then the potential difference b/w A and B is just about equal to that b/w the plates but if it is long then there should be a big difference. Sorry for my bad english
in that case, yes you're right, there is a difference :smile:
but I've never come across an exam question that combines an electric circuit with a outside charge, and i don't think it happens intentionally in real circuits
have you come across it?​
In a conductor, that potential difference will be 0. If there was a potential difference,
there would be an electric field, and charges would immediately move to cancel the field,
and with it the potential difference.
hi willem2! :smile:
willem2 said:
In a conductor, that potential difference will be 0. If there was a potential difference, there would be an electric field, and charges would immediately move to cancel the field, and with it the potential difference.
in equilibrium, yes, the charges in a conductor will "immediately" move to cancel the field
but does that still apply while the capacitor is charging or discharging? :confused:
tiny-tim said:
hi willem2! :smile:
If you bring a positive charge near one end of a wire with a capacitor in the middle, then negative charge will move towards the end of the wire with the positive charge, and the capacitor will charge somewhat, and you will get a potential difference, even after equilibrium is reached.
In an actual circuit, not separated in two by capacitors, charge will distribute, so the external field will get canceled in the conductors, and the external charge will only produce a potential difference in the circuit for a very short time.
Thanks for the replies.
Not yet, :)
So if the potential difference between A and B and the potential difference between the plates of the capacitor are not necessarily equal, why is it that we use the potential difference between A and B for V in C=Q/V when V should be the Potential difference between the plates? In my book capacitance comes after the chapter about electric potential and, Current, resistance , EMF and circuits aren't yet discussed, that's why i need to understand it with concepts only involving electric potential.
To clarify what my problem really is, i will give another example:
Suppose that we have a wire with endpoints A and B, and the potential difference of these points is Vab. Let's take two other points c and d between A and B. Because potential varies with the distance r ( I am just a beginner so i understand potential only in terms of V=q/4εor, i think Vab is not equal to Vcd. Now if c and d happens to be the plates of a capacitor with a given capacitance and we wish to compute for its charge, we only know Vab but not Vcd. But in examples that i have seen Vab is used as Vcd and i can't understand why. I really need some help with this.
same as the reason why we assume that all strings have zero mass, that g = 9.81 and not the more accurate figure, and so on …
it makes no practical difference! :smile:
The problem is that you can't use this equation to compute the potential, because the point charge will make charges in the wire move, and you'll need to add the potentials due to those charges as well.
If you have a single wire without a capacitor, the potential difference will be 0 after the wire reaches equilibrium. You should have learned already that with static electricity all parts of a conductor are always at the same potential.
If you use a capacitor in the wire there will be a potential difference across the capacitor, but it will be much lower than you would expect from V=q/4εor[/QUOTE]
(lower for a bigger capacitor)
The precise value will be much too hard to calculate at this point, involving a partial
differential equation for charge distribution in the wire, to make the electric field
in the wire 0 everywhere except between the plates of the capacitor.
i think i need to read the whole chapter again, i forgot a lot of concepts. I tried finishing the chapter too fast, i remembered nothing. Thanks for your replies :)
I'll try to get back here if I am still confused. Thanks again
Ok i think i get it
Vab= Vac+ Vcd+ Vdb
Vac= Vdb=0 because they are in the conductor so:
Vab=Vcd
I had this same confusion, and it drove me nuts. I still don't know if I fully understand it, so someone correct me if I am wrong.
With a capacitor fully charged and no current is moving, the electric field for all electrons is a net zero. This is not to say that electrons are not bouncing all over the place, because they definitely are, at high velocities. But this is just random motion, so while there are corresponding net electric fields causing the random acceleration of each electron, it is not a net acceleration in one direction creating a flow. Or simply, momentum is conserved, and the over all field is said to be zero. There is a potential difference over the plates though because there are no longer any electrons with their own repulsive force to cancel out the ones on the surface. It is the surface itself, or the material that is holding them back, and thus allowing for a potential difference. So the way I see it, the surface limit is what forces the electric field inside to be zero (electrons can't leave/pass the surface), but in doing so, there is charge built up on that surface. If you were to disconnect the charging device and connect the two places, charge would distribute itself until the potential yet again, over the now single conductor, is the same.
1. What is the definition of potential difference in a capacitor?
The potential difference in a capacitor is the difference in electric potential between the two plates of the capacitor. It is measured in volts and represents the amount of energy stored in the capacitor per unit charge.
2. How is the potential difference of a capacitor calculated?
The potential difference of a capacitor can be calculated using the equation V = Q/C, where V is the potential difference, Q is the charge on the capacitor, and C is the capacitance of the capacitor. It can also be calculated by dividing the energy stored in the capacitor by the charge on the capacitor.
3. How does the potential difference of a capacitor change in a circuit?
In a closed circuit, the potential difference of a capacitor remains constant. However, when a capacitor is connected to a voltage source, the potential difference across the capacitor will increase as it charges and decrease as it discharges.
4. What factors affect the potential difference of a capacitor in a circuit?
The potential difference of a capacitor is affected by the capacitance of the capacitor, the charge on the capacitor, and the voltage applied to the circuit. It is also affected by the type of dielectric material used in the capacitor and the distance between the plates.
5. How is the potential difference of a capacitor used in electronic circuits?
The potential difference of a capacitor is used in electronic circuits to store and release electrical energy. It is commonly used in filtering and smoothing circuits, as well as in timing circuits and energy storage devices such as batteries.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
