Does nature behave according to the right hand rule?
In summary, there are two conventions for determining the direction of magnetic forces: the right hand rule and the left hand rule. The labels of "north" and "south" poles for magnetic fields are arbitrary but must be consistent. The right hand rule is based on positive charges and north-to-south field lines, while the left hand rule focuses on negative charges or south-to-north field lines. The direction of the magnetic field is what is important, not the label of the poles. In nature, electric currents are generated to maintain a constant flux, which is the basis of electricity generation.
jaydnul
558
I already know that the right hand rule could just as well be the left hand for the rotational motion vectors like torque and angular momentum, but what about magnetism? It seems like nature behaves strictly "right handedly" for magnetism. Is that true, or could you use the left hand rule, just as long as you were consistent with it?
You can use whatever convention you wish as long as you remember to point your fingers the way nature works :smile:
A left hand rule for EM would work just as well.
Well this is where I'm confused. If I did an experiment where I shot a proton from right to left, through a uniform magnetic field that is pointing downwards (the north pole is above the proton, the south pole is below), the right hand rule would tell me that it would force the proton towards me, away from the screen. If I use the left hand rule, it says the proton is forced away from me, into the screen. But if I actually did the experiment, I would find that it went either one way or another, right? So only one rule could be valid. Where am I going wrong?
How did you decide which pole is north and which is south?
Oh ok, so the poles are arbitrary? Why do they say that on earth, the north pole is really the south magnetic pole? Why would that matter if it were arbitrary?
Long ago, before we understood about opposite poles attracting and matching poles repelling, we observed that one end of a magnetized needle would reliably point to the the left when we were facing the rising sun. Because we were already in the habit of calling that direction "north", we naturally called that end of the magnetized needle the "north" end. Then when we learned about magnetic poles and opposites attracting, we realized that the end of the needle that we called "north" was being attracted to and pointing towards a magnetic pole that we called "south" even though it was at the Earth's north pole.
The definitions of the poles is arbitrary, but we do need to be consistent and differentiate between them. As long as all north-seeking poles have the same name (be it north, south, positive, negative, or gloop) and all south-seeking poles have a different name, we are fine.
The right-hand rule focuses on positive charges and north-to-south field lines; a left-hand rule using the same fingers and motions would focus on negative charges or south-to-north field lines.
The label that you attach to poles doesn't really mean much. What is important is the direction of the magnetic field. If you switch your handedness from right to left then you reverse the directions of your magnetic fields. The reversed direction of the magnetic field and the left-handedness of the force law gives the force in the same direction.
EDIT: I should have read the responses first, looks like I am just echoing Nick O's post!
You put it more clearly and simply than I did.
Nature abhors a change in flux (at least when it comes to E&M). Nature will "create" electric currents such that the change in magnetic flux through all open surfaces is zero. This is, of course, the premise behind all modern electricity generation. Spin giant magnets near wire loops or wire loops in magnetic fields and you induce an EMF in the wire loop. Somehow, you have to provide the spin though!
1. What is the right hand rule in nature?
The right hand rule is a principle in electromagnetism that describes the relationship between the direction of current flow, the direction of magnetic fields, and the direction of force. It states that if you point your thumb in the direction of current flow, your fingers will curl in the direction of the magnetic field, and your palm will face in the direction of the resulting force.
2. How is the right hand rule used in nature?
The right hand rule is used to determine the direction of force on a moving charged particle in a magnetic field, the direction of current flow in a wire in a magnetic field, and the direction of the magnetic field produced by a current-carrying wire. It is also used in many other applications in physics and engineering, such as in motors and generators.
3. Is the right hand rule always accurate in nature?
While the right hand rule is a useful tool in many situations, it is not always accurate in nature. In certain cases, such as when dealing with more complex electromagnetic systems or non-uniform magnetic fields, the right hand rule may need to be modified or may not apply at all.
4. Can the right hand rule be applied to other areas of science?
Yes, the right hand rule can also be applied in other areas of science, such as fluid dynamics and structural mechanics. In these fields, it is used to determine the direction of forces and moments acting on a body or fluid based on the direction of motion or flow.
5. How is the right hand rule taught and learned in science?
The right hand rule is typically taught and learned through visual demonstrations and hands-on experiments. It is also often included in textbooks and lectures as a fundamental concept in electromagnetism. With practice and application, it can become an intuitive concept for scientists and engineers to use in their work.
  • Other Physics Topics
  • DIY Projects
  • Electromagnetism
  • General Engineering
