Question on assumptions made during variation of parameters
In summary, the variation of parameters formula for an nth degree equation involves assuming that the sum of the derivatives of the solution functions is equal to 0 for k < n-1. However, if we instead assumed that the sum equaled a constant, it would make the equations more complicated to solve. This is because there are an infinite number of solutions to the original differential equation and simplifying assumptions reduce the set of possible solutions.
NoOne0507
I was recently trying to prove the variation of parameters formula for an nth degree equation, and I have come up with a question about the assumptions made during the derivation.
During the derivation we assume that: u1'y1(k) + u2'y2(k) + . . . + un'yn(k) = 0
for k < n-1.
It leads to the matrix form: WU' = X, where W is the Wronskian, U' is a column vector consisting of the derivatives of each ui, and X is the solution vector that has f(t) in the nth row, and 0 in all the others.
My question is on the assumption: u1'y1(k) + u2'y2(k) + . . . + un'yn(k) = 0, k < n-1.
How would this the results of our solutions change if we instead assumed the left hand sum equaled some constant? It would have the same effect when the derivative is taken at each step, as the constant would go to 0 consistently.
I see it would lead to different values for u, as the solution to the system would be different. Would the answers simplify to the same values as assuming the sums are 0? Would it lead to different answers, and then be forced correct when applying initial conditions? Any thoughts?
for k < n-1.
It would make the equations more difficult to solve! The point is that there are an infinite number of solutions to the original differential equation and we are looking for one. We can make pretty nearly any simplifying assumptions we want. That just reduces the set of "possible" solutions we are looking for.
What is the variation of parameters method?
The variation of parameters method is a technique used in solving linear differential equations. It involves finding a particular solution to a non-homogeneous differential equation by varying the parameters of a general solution to the corresponding homogeneous equation.
What assumptions are made during the variation of parameters method?
The main assumptions made during the variation of parameters method are that the differential equation is linear, the coefficients of the equation are continuous functions, and the functions involved are differentiable.
Why is the variation of parameters method used?
The variation of parameters method is used because it provides a general solution to non-homogeneous differential equations, which cannot be solved using other methods such as the method of undetermined coefficients or the method of integrating factors.
What are the steps involved in using the variation of parameters method?
The first step is to find the general solution to the corresponding homogeneous equation. Then, a particular solution is guessed by varying the parameters of the general solution. The parameters are then determined by substituting the guessed solution into the original non-homogeneous equation. Finally, the general solution is obtained by combining the particular solution with the general solution to the homogeneous equation.
What are the limitations of the variation of parameters method?
The variation of parameters method can only be applied to linear differential equations with continuous coefficients. It also requires a lot of algebraic manipulation and can be time-consuming for more complex equations. Additionally, it may not always yield a closed-form solution and may require numerical methods to obtain an approximate solution.
  • Differential Equations
  • Atomic and Condensed Matter
