Thermodynamics: Amount of work required to increase pressure at constant volume
In summary, the problem involves using a hand pump to inflate a tire from 0 psi to 35 psi, with a constant volume of 3.5 ft^3. The question asks for the amount of work done on the air pump, assuming adiabatic processes and STP conditions. To solve this, the formula pV^(gamma)=constant is used, along with dW=pdV and ΔQ=nC_vΔT. The correct answer can be found by calculating the volume of the air before it was put in the tire and using the formula W=∫pdV. The value of gamma for air is 7/2.
Bill Foster
338
By means of a hand pump, you inflate a tire from 0 psi to 35 psi (overpressure). The volume of the tire remains constant at [tex]3.5 ft^3[/tex]. How much work must you do on the air pump? Assume each stroke of the pump is an adiabatic process and that the air is initially at STP.
[tex]pV^\gamma=constant[/tex]
[tex]dW=pdV[/tex]
[tex]\Delta{Q}=nC_v\Delta{T}[/tex]
[tex]pV=nRT[/tex]
I can't use [tex]dW=pdV[/tex] because the change in volume is 0.
[tex]p_0V^\gamma=p_1V^\gamma[/tex]
Since V is constant, that implies [tex]p_0=p_1[/tex]
So I'm left with [tex]\Delta{Q}=nC_v\Delta{T}[/tex] and [tex]pV=nRT[/tex]
Combining them, I get [tex]\Delta{Q}=\frac{C_v\Delta{p}V}{R}[/tex]
The problem is I don't know what [tex]C_v[/tex] is.
Since the value isn't given in my book, I assume that I'm suppose to calculate it.
I know that [tex]C_p=\frac{5}{2}R[/tex] for monotomic gas and [tex]C_p=\frac{7}{2}R[/tex] for diatomic. I assume air is a mixture of both.
But when I plug in the numbers (R=8.314) it just doesn't come out correctly.
The correct answer is [tex]8.1\times{10^3} ft\cdot{lb}=10982 J[/tex]. Working backwards from that answer I can see that [tex]C_v=3.82[/tex].
So what am I missing?
You have written that change of volume is zero. Change of which volume? The gas in the cylinder of the pump is getting compressed.
The air which is inside the tyre is definitely compressed, so there must have been a change in volume.
Now think which formula you can apply.
Show me.
Here's the thing about this problem: you want to track the amount of gas being pumped into the tire. The air in the tire starts at 1 atm absolute (the pressures given in the problem are gauge pressures) and ends at 1 atm + 35 psi . The volume remains at 3.5 ft^3 . I think we may have to assume that while the process is adiabatic, the temperature of the air in the tire reaches equilibrium at STP. What you want to find is how many moles of air are injected into the tire and then find what volume that air originally occupied. That would give you a way of assessing the adiabatic work done in getting the air into the tire.
Air is treated as entirely diatomic, BTW (it's predominately nitrogen and oxygen). Also [tex]c_{V} + R = c_{P}[/tex]
Trying to calculate the volume of the air before it was put in the tire:
[tex]p_1V_1^\gamma=p_2V_2^\gamma[/tex]
[tex]V_1=V_2(\frac{p_2}{p_1})^\frac{1}{\gamma}[/tex]
[tex]W=\int{pdV}[/tex]
[tex]p=p_1\frac{V_1^\gamma}{V^\gamma}[/tex]
[tex]W=\int{pdV}=\int{\frac{p_1V_1^\gamma}{V^\gamma}dV}=\frac{1}{\gamma-1}p_1V_1(1-(\frac{V_1}{V_2})^{\gamma -1})[/tex]
I'm still getting the wrong answer.
Maybe I'm using the wrong value for [tex]\gamma[/tex].
All the problems in the book as well as the examples suggest [tex]\gamma = 1.4[/tex]. So that's what I've been using.
Well, even though it's driving me crazy, I've got to forget about this. I'm taking the GRE subject test in physics tomorrow and I still have to go over electromagnetics and oscillations. It's been 20 years since I've had undergrad physics!
Hi Bill,
Your calculation is correct, even though it's better to eliminate V1 from the final expression since that’s the unknown but that’s immaterial, since you are putting the value of V1 later. I converted everything to MKS and got the result as 437213 Joules. The arithmetic is very messy, and there’s no guarantee that the number is correct.
And gamma is 7/2 for air.
What is thermodynamics?
Thermodynamics is the branch of physics that studies the relationships between heat, energy, and work. It deals with the behavior of systems at the macroscopic scale and how they respond to changes in temperature, pressure, and volume.
What is the amount of work required to increase pressure at constant volume?
The amount of work required to increase pressure at constant volume is given by the equation W = PΔV, where W is the work, P is the pressure, and ΔV is the change in volume. This means that the work done is directly proportional to the change in pressure and the change in volume.
How does increasing pressure affect the amount of work required?
If pressure is increased at a constant volume, the amount of work required will also increase. This is because the system is being compressed and more energy is needed to maintain the constant volume.
What other factors can affect the amount of work required to increase pressure at constant volume?
The amount of work required can also be affected by the nature of the gas, the initial pressure and volume, and the temperature of the system. In some cases, the type of container used can also impact the amount of work required.
What is the practical application of understanding the amount of work required to increase pressure at constant volume?
Understanding the amount of work required to increase pressure at constant volume is important in many industrial processes, such as in the compression of gases for storage or transportation. It also has applications in the design of engines and other machinery that involve changes in pressure and volume.
