Calculating Turn Time for a Banked Airplane
In summary, we discuss the free-body diagram of a plane in level flight and calculate the force of gravity and lifting force. We then introduce a turn by banking the wings at a 7.5 degree angle, which decreases the lifting force and allows the plane to turn in a circle without descending. We are asked to calculate the time it takes for the plane to make one turn at a constant velocity of 200 km/hr. Using the formula Time=Distance/Velocity and the circumference of the circle, we can find the time it takes for the plane to complete the turn.
ataglance05
43
Airplane Free-body diagram!
A plane with mass of 1090 kg is flying straight and level at an altitude of 1100 meters & a constant velocity of 200 kg/hr (55.55m/sec). Assuming that the acceleration due to gravity is 10 m/sec^2, the force on the plane due to gravity is 10900 Newtons. Since the plane is in level flight, the net force in the y direction is 0 & the lifting force provided by the wings equals the weight of the plane. The piolot now banks the wings at a 7.5 degree angle w/ respect to the vertical in order to make a turn. Part of the lifting force of the wings is now used to make the plane turn in a circle & there's less lift to counteract the force of gravity.
How long will it take the plane to make one turn of 360 degrees at a velocity of 200 km/hr (55.55 m/sec)??
Vf=Vo+aT
S=Vo(T)+1/2(a)(T)^2
s=theta(r)
Time=Distance/radius
A free-body diagram of the situation:
NO CLUE! HELP!
All I know is that the value that the lift should be increased so that the plane doesn't decend is 10994 Newtons and that the radius of the circle that the plane will fly w/o loosing altitude w/ constant velocity of 200km/hr is 2343 m.
anyone?:cry: :cry: :cry:
Well, if you know the radius of the circle, you can easily find the circumference of the circle. What does that give you? You also know the plane's speed. You can put these two pieces of information together to find out the time it takes to complete the turn.
The circumference is 7326.194 and the velocity is 55.55 m/sec. what equation would i use though??
Double check your calculation for the circumference, I got a different value. You know the circumference (ie total distance) the plane travels in one turn, and the speed during the turn. What's the definition of speed? Use that and solve for t.
I stand corrected; C=14714.04
Alright so I'm now leaning towards Time=Distance/Velocity with the distance being the circumference. Am i correct?
Sounds good to me!
thanks!
1. What is a free-body diagram for an airplane?
A free-body diagram for an airplane is a simplified diagram that shows all the forces acting on an airplane in flight. This includes the weight of the airplane, lift force, drag force, and thrust force. It is an important tool for analyzing the forces and motion of an airplane.
2. How do you create a free-body diagram for an airplane?
To create a free-body diagram for an airplane, you first need to identify all the forces acting on the airplane. This includes the weight of the airplane, which is always directed downwards, lift force, which is directed upwards, drag force, which is directed backwards, and thrust force, which is directed forwards. Then, you can draw arrows to represent the magnitude and direction of each force.
3. Why is a free-body diagram important for understanding the motion of an airplane?
A free-body diagram is important for understanding the motion of an airplane because it allows us to see all the forces acting on the airplane and how they are balanced. By analyzing the free-body diagram, we can determine the net force and acceleration of the airplane, which helps us understand how it moves through the air.
4. Can a free-body diagram be used to calculate the performance of an airplane?
Yes, a free-body diagram can be used to calculate the performance of an airplane. By analyzing the forces acting on the airplane, we can determine the lift-to-drag ratio, which is a key indicator of an airplane's performance. This can be used to compare different airplane designs and make improvements.
5. Are there any other factors that should be considered when creating a free-body diagram for an airplane?
Yes, there are other factors that should be considered when creating a free-body diagram for an airplane. These include the angle of attack, air density, and airspeed. These factors can affect the magnitude and direction of the forces acting on the airplane, and should be taken into account for a more accurate free-body diagram.
  • General Engineering
