allym.iftikha
- 2
i am working on GE GAS TURBINE's Torque converter beginners understanding ... em so confused into a clutch and torque converter ... Can u please briefly make me understand the function of both ... and importance ...
A torque converter is a type of fluid coupling used in vehicles with automatic transmissions. It connects the engine to the transmission and allows the engine to continue running while the vehicle is at a stop. Inside the torque converter, there are three main components: the impeller, turbine, and stator. The impeller is connected to the engine and spins the transmission fluid, which then turns the turbine. The turbine, in turn, is connected to the transmission input shaft and helps to transfer the power from the engine to the wheels. The stator redirects the fluid flow, increasing the torque produced by the converter.
A clutch is a mechanical device used in manual transmissions to connect and disconnect the engine from the transmission. Unlike a torque converter, a clutch is a direct connection between the engine and transmission and does not use fluid to transfer power. When the clutch pedal is pressed, it disengages the engine from the transmission, allowing the driver to change gears. When the clutch pedal is released, it engages the engine to the transmission, allowing the vehicle to move.
The answer to this question depends on personal preference and the type of driving you do. Torque converters are easier to use and provide a smoother driving experience, making them ideal for daily driving and stop-and-go traffic. Clutches, on the other hand, offer more direct control over the vehicle's power and are better suited for high-performance driving or towing heavy loads.
Yes, some vehicles with automatic transmissions also have a clutch. This is known as a semi-automatic transmission, where the clutch is controlled electronically rather than by the driver's foot. This allows for smoother gear changes and improved fuel efficiency.
It is possible to replace a torque converter with a clutch, but it would require significant modifications to the vehicle's transmission and drivetrain. It is not a common or recommended practice, as it could affect the vehicle's performance and potentially cause damage. Additionally, most vehicles with automatic transmissions are not designed to accommodate a clutch, making it a difficult and costly conversion.
